Motor can be stopped by hand when controlled by Monster Moto
Discussion in 'Motor actuators and drivers' started by Ralph Manuel, Jan 3, 2015.
  1. Ralph Manuel
    Ralph Manuel Member
    600Coins
    Hi! I'm currently facing a problem where when the motor is connected with the monster moto, the motor can be stopped by a hand but when I directly connect a power supply to the motor, I cant stop it. I think monster moto reduces the power of the motor. What do you think?
    Here is my hardware:
    -12V 30A PSU
    -wiper motor
    -Monster Moto
    -Arduino Mega
  2. bsft
    Unless I am wrong, any h-bridge, JRK included will let the motor go soft when the power is off.
  3. Ralph Manuel
    Ralph Manuel Member
    600Coins
    the motor go soft when connected to h-bridge even it is turned on?
  4. bsft
    ok, not sure on ard code and interface settings, but I know with JRK settings, yes the motors dont hold unless they are told to in the interface settings. And yes, thats with power on as well
    Id guess the Ard settings would have a similar thing in game engine interface.
    as long as it holds in game, there should not be an issue too much
    perhaps @Pit can enlighten us here.
  5. Pit
    30,510Coins
    Moto Monster does only what Arduino is "saying". To my knowledge you are using the SMC3 code, please have a look at PWMmax. If this value is too low, the motor is going too weak. Could you honestly post SMC3 screenshots?
  6. Ralph Manuel
    Ralph Manuel Member
    600Coins
    @Pit, No, I am not using SMC3, I am using @RacingMat 's arduino code.
    I've tried SMC3, but no luck, I can't make it work. lol
  7. Pit
    30,510Coins
    You have run into issues using SMC3 code, and now into RacingMat code - IMHO the problem is not the code...@RacingMat is the best who can give any help about his code, still I ask you about the parameters you have changed within the code like #define pwmMax.
  8. Pit
    30,510Coins
    Code deleted by request
  9. RacingMat
    21,082Coins
    hi!
    there is something weird here :confused:
    motomonster should not "reduce" the motor power
    can you give us more details about your setup?
    - I guess you didn't connect the potentiometer yet... it's fine for the first tests
    - did you try with only 1 motor running?
    - did you change anything in the code?
    - my guess would be a wrong wiring... can you share some pictures?
    yours
    Mat
  10. Ralph Manuel
    Ralph Manuel Member
    600Coins
    No, I didn't change anything on the code of RacingMat,
  11. RacingMat
    21,082Coins
    @Pit : please don't post whole code -> if I have to publish a newer version, people could get messed up with older versions scattered in posts.
  12. Ralph Manuel
    Ralph Manuel Member
    600Coins
    -the wiring is good, all pins are connected right.
    -the motor, together with the attached potentiometer is running smoothly when I use axis testing(DOF output and Axis output) .
    Please wait and I'll post some pictures and videos. Thanks
  13. RacingMat
    21,082Coins
    maybe one VNH is burnt...
    is it the same behaviour on both outputs (motor1 and motor2)?
  14. Ralph Manuel
    Ralph Manuel Member
    600Coins
    i did not try the other VNH yet cause I don't have my soldering iron(can't solder wires to the other VNH).
    But in the beginning of testing(not using racingmats code yet), I've tried to run the MM with the sample codes I've seen on the web and it is the same. The motor is not that hard enough.
  15. Ralph Manuel
    Ralph Manuel Member
    600Coins
    Hi! Here are some pictures and videos. Kindly check it out.
    As you can see, every time I stopped the motor, the PSU fan is noisy because the PSU has a built-in control circuit according to working to temperature. So, stopping the motor adds some load to the PSU.
    I don't have materials needed that's why there are tapes, plywoods and recycled materials. LOL
  16. Scratch
    Scratch Active Member
    281Coins
    Very strange. I cannot help much, but I have identical psu and I'm using it for both motors through Monster Moto. It starts it's cooling fan rarely and for a short period of time when rig is in use. So it seems that something shorts when you apply pressure to your motor and it quickly heats up your psu. You could go through your wiring with a multimeter and track voltage/current while pressing/releasing the lever. Does your Monster Moto heat up? Have you opened your Wiper motor and checked the wiring inside? Or checked that no wires coming from your motor are connected to the motorcasing?
  17. Pit
    30,510Coins
    I have one remark, if all electrical connections are not perfectly soldered you will run into issues as well.
  18. Scratch
    281Coins
    Hey, looking at your pics, if you have not isolated your wiper motor casing from the ground wire, it could be possible that it shorts through your pot connection, if you don't have multimeter, try to remove pot from the axle of your motor and try to run it that way!
  19. Pit
    30,510Coins
    Thank you again for this hint, we should once and for all make a pinned FAQ thread where this issue should be considered as first!
  20. Ralph Manuel
    Ralph Manuel Member
    600Coins
    Hi, MM does not heat up when the motor is running.
    I did not open yet my motor and I dont know how to isolate earth ground in motor.
    I will do some research about it. That maybe the cause of my problem.
