Asseto Corsa plugin
Discussion in 'SimTools Plugins' started by hyper1966, Jan 4, 2015.
  1. hyper1966
    hyper1966 Domenic
    Edmonton QLD Australia
    833Coins
    2DOF, JRK
    Hi has anyone updated asseto corsa to version 1.0? and is plugin working correctly?
    As I don't seem to have much motion anymore ,since updated thanks Domenic
  2. value1
    15,082Coins
    @hyper1966: The current plugin works fine. Just the name ("Assetto Corsa EA") needs updating. But this doesn't harm.
    Maybe check your MaxMin settings in Tuning Center.
  3. bsft
    yes I have current version and yes plugin works, try deleting old plugin out of the respective simtools program folder and re-install the plugin.
  4. hyper1966
    hyper1966 Domenic
    833Coins
    2DOF, JRK
    thanks for all your help, I try later ,and let you know thanks domenic
  5. hyper1966
    hyper1966 Domenic
    833Coins
    2DOF, JRK
    YES I got it working, thanks everyone, for all your help domenic
  6. Hobbs77
    Hobbs77 Active Member
    Connecticut, USA
    815Coins
    2DOF, SCN5
    Not sure what you mean about " just the name needs updating" Thanks!
  7. f1simgames
    f1simgames Member
    516Coins
    hello...a question....how can i install the plugin for AC guys?...
    thank you very much!
    152,664Coins
    +11,088 / 56 / -2
    Here you go @f1simgames:
    You purchase download access with forum or real coins: http://www.xsimulator.net/community/faq/how-to-download-plugins.2/
    Download Assetto Corsa: http://www.xsimulator.net/community/marketplace/asseto-corsa-plugin.10/
    Open the Simtools Game Plugin Updater.
    Drag the downloaded AC zip file onto the Simtools Game Plugin Updater and it will install.
    Have a read of the SimTools documentation on how to go through settings and game calibration: http://www.xsimulator.net/simtools-complete-documentation/
  9. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    have you checked out all of the tutorial files?
  10. azertyclub
    azertyclub New Member
    TECHNICIEN
    LESCAR
    210Coins
    normalement sa devrait fonctionner correctement puisque tu as des mouvements, tu as plus qu'a les régler .
  11. Simon Husum
    Simon Husum Member
    Electrician
    Viborg, Denmark
    217Coins
    2DOF, DC motor, JRK, SimforceGT
    I'm having big trouble getting the plugin to work :(
    Project Cars worked right after patching and recognized the game..
    This Assetto Corsa plugin recognizes the game after patching..
    But no motion in game :(
    Others with the same problem?
    Thanks in advance.
    Regards Simon
    152,664Coins
    +11,088 / 56 / -2
  13. Simon Husum
    Simon Husum Member
    Electrician
    Viborg, Denmark
    217Coins
    :blush
    Again noorbeast..
    I have read all the quickstart manual about the plugin and so on..
    Thought that the tuning center was from an old version of simtools and that yoy could only change the settings in the plugin in the var from 0-100%.
    But the values in the tuning center was all saying 32xxx..
    Changed it ..And now.. WOW..
    What a difference in all my games after correcting the values in tuning center..
    Thanks again noorbeast for always providing a quick usable answer..
    This software really rocks..
    Awesome :):):):)
  14. Nick Moxley
    Hey @value1 a little heads up, Assetto is planning on releasing a 64bit version in the next update.(end of month) So if there's some quires as to why it doesn't work come the end of the month, Now you know. ;)
    • Informative Informative x 4
  15. Blame73
    Blame73 Well-Known Member
    8,305Coins
    Do you know anything about improvements from testers?
  16. Nick Moxley
    Do you watch Stefano's streams ?
  17. Blame73
    8,305Coins
    Sometime in the "Chit Chat" room I read from people who follows him
  18. Nick Moxley
    i might know of a beta tester, that Might leak a little info from time to time.......:think
