SimTools Presets 2DOF with 24v dc motors and Arduino Nano
Discussion in 'Game Engine Interface presets' started by Raulmerlos, Jul 27, 2014.
  1. Edson Lourenço Bezerra
    Edson Lourenço Bezerra Edson Bezerra - Desenvolvedor Open Source
    Analista de Sistema
    Jundiaí
    147Coins
    2DOF, 3DOF, DC motor, Arduino, Motion platform, 4DOF
    Olá, @Pit Gostaria de compreender a postagem. Talvez haja uma falta de interpretação por minha parte, já que meu Inglês não é tão fluente.
    Grato.
  2. Pit
    30,497Coins
    My English is not the best but I do my very best. Please use Google translator.
  3. Raulmerlos
    Raulmerlos Member
    Mecanico maquinaria calzado
    Monóvar (Alicante) España
    132Coins
    3DOF, Arduino
    ok, Pit.
    Jajaja I also use google translate
  4. Raulmerlos
    Raulmerlos Member
    132Coins
    3DOF, Arduino
    Hello Lourenço, not quite understand what you mean me, my English translate it in google.
    qreo that you warm the engines hum, me too by Esso have not made him a fan pc and it works perfect heat anything, I've put 4 engine.
  5. Edson Lourenço Bezerra
    Analista de Sistema
    Jundiaí
    147Coins
    Perdoe-me mais como as vezes a tradução fica sem sentido da minha lingua para o Inglês fico sem saber bem ao certo se me compriende.
    Desde já agradeço ao Sr. Pit e também ao Sr. Raulmerlos.
  6. Raulmerlos
    Raulmerlos Member
    132Coins
    3DOF, Arduino
    [MEDIA = youtube] m4uQbZ6edGE [/ MEDIA]
  7. Edson Lourenço Bezerra
    Analista de Sistema
    Jundiaí
    147Coins
    Forgiveness seems to have been offended as the comment, but just wanted to share the idea of using types of rails in place of a A wind as cross. "I do not know for sure the name you know the installed part. Its design is one of the most richly detailed and surprisingly well executed.
    Thank you.
  8. bsft
    Not sure what you mean by 150 laps.....
    yes thats normal for the motors to slump when not under electric power.
    You do realise you are restricting motion with the gas struts. They are designed to hold and also gas struts absorb shock, so finer motion may not be felt.
    Its like the springs to help maintain a level platform when its not under power. Its for looks mostly and comfort. Not for sim use.
  9. Raulmerlos
    Raulmerlos Member
    132Coins
    3DOF, Arduino
    No heno Que Nada perdonar Lourenço, ESTAMOS Here for baño Todo Lo Que podamos ayudarle, Qué SIGNIFICA no exactament contradictorio.
    Flechas Última estas?
  10. Raulmerlos
    Raulmerlos Member
    132Coins
    3DOF, Arduino
    BSFT Ok, no entiendo muy bien la traducción, están reduciendo vuelats 150, 45 vueltas, funciona bastante bien.
    Quería comprar Motorreductores 45 vueltas, pero no puede financieramente, estos me la regalo de un amigo.
  11. Edson Lourenço Bezerra
    Analista de Sistema
    Jundiaí
    147Coins
    Trying to do some test to with my arduino and SMC3, this returning me the following bug compilation:
    SMC3.ino: In function 'setPwmFrequency void (int, int)':
    SMC3: 259: error: 'TCCR2B' was not declared in this scope
    SMC3.ino: In function 'void InitialisePWMTimer2 (unsigned int)':
    SMC3: 296: error: 'TCCR2B' was not declared in this scope
    Some error code or hardware
    grateful
  12. Raulmerlos
    Raulmerlos Member
    132Coins
    3DOF, Arduino
    That is SMC3.
  13. Raulmerlos
    Raulmerlos Member
    132Coins
    3DOF, Arduino
    Si usted puede pasar me Fotografías.
  14. JayceTeng
    JayceTeng New Member
    非政府组织的专业软件测试员
    - 86Coins
    2DOF, DC motor, SCN6, Arduino, Joyrider, Motion platform, 4DOF, 6DOF
    I have a question: SimTools 2.0 Input Settings - using Serial, but my emulator isn't moving, what's wrong?If it is convenient, please give me an InterfaceAssignments configuration file, thank you!
  15. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    com port is ready/ conected?
  16. pinthi
    pinthi Member Gold Contributor
    - 119Coins
    le faite de mettre des barre modulable et le réglage de l'écrans
    bon travail
  17. paulopsx2
    brasil
    647Coins
    In english please
  18. Pramuuditha Kumara
    Pramuuditha Kumara Member
    61Coins
    nice work and good design, i got some idea for my rig...
    thank you..
  19. Wayne Thebus
    Wayne Thebus Member
    CNC Machinist/Programmer
    Cape Town
    145Coins
  20. Wayne Thebus
    Wayne Thebus Member
    Cape Town
    145Coins
    I've got the same error. Did you manage to fix the issue, please let me know.
    Many thanks
