New Project
Discussion in 'SimTools compatible interfaces' started by manocito, Jan 11, 2008.
  1. manocito
    manocito New Member
    0Coins
    After all I decided to do a DIY project cabin.
    My first question is about interface. I´ve reading about solutions and will choose one of this options:
    1º Roboteq Ax500 Price 159$ + p.p
    Pros: All in one, controller 115000 bps + 2x8 continuos amp dc pwm control (15a pike)
    Cons: Maybe 8 amp per channel isn´t enought and ax1500 goes to 291 $ + p.p (30a pike, 16 continuos)
    2º Picaxe 28x1 Starter kit + 2x hb-25 motor controller
    Pros: 30 amp x channel, 4 analog out an price, 160$ + p.p
    Cons: I´ve got no idea about programming it¡¡¡
    Someone helps me?
    Thanks¡¡¡
  2. manocito
    manocito New Member
    0Coins
  3. manocito
    manocito New Member
    0Coins
    At last, I just bought picaxe 28x1 starter kit, in a week it will be at home. Hope with your help I could program it¡¡¡
    Thanks to all¡¡¡
  4. EvanF
    EvanF Member
    Multimedia Producer
    New Zealand
    423Coins
    Greetings Manocito,
    Ian of Buggiesbuiltforfun has already written a .bas file for the 28X1, you can download it for free here. http://buggies.builtforfun.co.uk/Sim/sim-downloads.html It was written with MD03 controllers in mind so a little bit of tweaking maybe required for your motor controllers.
    Here is the key to reading the data
    'Wait for the start signal from the PC PID controller - the input values are ignored but the program
    'will wait here until the PC controller sends a serial packet
    serin 7, N9600_8, (AB), b4, b5, b6, b7, b8, b9
    The trick is writing a translator program to convert the game data to meaningful information the 28X1 can work with. Ian calls his FlightSim utility the BFF driver.
    I have a 28X1 waiting in the shadows for just such a car-sim utility. I am using Simple-H power switches at moment but would need to check if I can use them with the Picaxe.
    If sirnoname can help guide you with how to read the serial info using x-sim software into a picaxe chip then I will follow this thread very closely indeed!
    EvanF
  5. manocito
    manocito New Member
    0Coins
    thanks, i´ll try when it arrives. Hope I could communicate with x-sim too.
    Bye¡¡
  6. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
  7. EvanF
    EvanF Member
    Multimedia Producer
    New Zealand
    423Coins
    Moved, what has moved?
  8. egoexpress
    421Coins
    Simulator projects -> controllers^^
  9. manocito
    manocito New Member
    0Coins
    As I saw in picaxe web page I think it will be no problem to communicate with USO.
    meanwhile here is a 3dsmax file about my motion platform XDDD
    Okay okay I know I´m a 3dsmax pro¡¡¡
    The motor will be placed under the seat and the pivot joint of x axis are not at the same level to recreate a effect like r´n´r or something like that.
    Regards¡ [/img]
