Showroom Blame73's 2DOF Seat Mover
Discussion in 'DIY Motion Simulator Projects' started by Blame73, Nov 20, 2014.
  1. Blame73
    Blame73 Well-Known Member
    8,304Coins
    I don't really know. I told him so many times...
    Next time I'm gonna use some ropes :)
  2. bsft
    Ive noticed that as well when people use my rides, some people tend to lean forward as I guess they are probably not used to a motion seat so they prefer to lean off it a bit to get used to it.
  3. Blame73
    8,304Coins
    Leaning off you got pedals closer so it's even more difficult to drive, at least in my rig that has got fixed pedals.
    It's amazing how people don't drive racing games as they drive real cars, even if I say it's a simulator so they should change gear, take corners as they would in real life. But no, they keep pushing the gas as if they're running away from the devil, never braking, never changing gear.
    People is so much used to arcade games
    152,117Coins
    +11,066 / 56 / -2
  5. bsft
    agreed, thats why arcade games are on my dual racers, just watch the videos
  6. Blame73
    8,304Coins
    New entry.
    gotta build the box now.
  7. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    looks like your wheel and pedals are to close together causing him to scruntch up. I also use a 5 point harness which makes people sit back
  8. Blame73
    8,304Coins
    I got an TM1638 Module for Arduino that I use with AssettoCorsa, it has 8 leds but just 1 color - red - for led (there are modules with two colors for led: red and green)
    I use the Arduino software from one AC member that you can find here: http://www.assettocorsa.net/forum/i...2-1-3-for-ac-v1-0-rewrite-auto-updater.14172/
    Leds can be lit in one or two sequences, so 8 leds or 16 leds (two times 8 leds), but are thought for the two colors modules, so I changed the sequence to anyway use the two sequences but with just one color:
    the first sequence it lits up one led at a time from left to right, the second one lits the leds always from left to right but keeping 'em all lit.
    A video is better than my confused words :)
    Edit:
    This is the code I used:
    PROGMEM prog_uint16_t ledsLong[2][17] = {{0, 256, 512, 1024, 2048, 4096, 8192, 16384, 32768, 256, 768, 1792, 3840, 7936, 16128, 32512, 65280}, {0, 1, 2, 4, 8, 16, 32, 64, 128, 1, 3, 7, 15, 31, 63, 127, 255}};
  9. Blame73
    8,304Coins
    One month ago I broke a motor's arm by (not very well) drilling an hole in it. Since then I took it to have it welded, since I don't have a welding machine.
    They kept it on their table saying they were going to work on it, "just a couple of days"...
    I got sick and tired I took it back, I'll take it somewhere else. Meanwhile I ordered a new one on the bay, so I'm gonna have three motors soon.
    Who said 'traction loss'? :D
  10. Blame73
    8,304Coins
    So my new motor is here and with a big grin on my face (I got no motion for two months now...) I mounted it to just discover that:
    - 1) 1 pot died. Well, not that big deal, 10 minutes of work
    - 2) the mini usb from one JRK is giving me a lot of problems, if I almost touch it it stops working
    I think i read someone had the same problem, maybe @bsft @shannonb1 or @Nick Moxley , don't remember for sure.
    Is it fixable? Because being in Italy and having bought it via ebay I think it would be a pain going for a replacement.
    152,117Coins
    +11,066 / 56 / -2
    I had a usb cage come off a JRK. If you had a steady hand and good eyes I expect you could solder it before it breaks. If it was purchased new on Ebay you may still want to notify Pololu that it is a problem, as a potential manufacturer warranty claim.
  12. Blame73
    8,304Coins
    Thanks for the tip. Being 41 my near-sight is not that good anymore and soldering is becoming a problem but I'll give it a try,
    Let's see what Pololu says
  13. Nick Moxley
    Pololu is pretty awesome for helping out the customer, Where is the USB disconnecting ? on the JRK itself of the USB into the PC ? are you using a USB hub ? or directly into the PC ?
  14. Blame73
    8,304Coins
    They already answered me. The problem is on the JRK itself, is a bit loose, I gotta check if it has any bent pins and let them know.
  15. bsft
    nice job with the dash
  16. Blame73
    8,304Coins
    Hmmm, this is not born under a good star: the other JRK, not the one with the USB connector problem, don't see the pot anymore, already tried with the other working pot but nothing, it says is not connected.
    Maybe when the previous pot died it killed the JRK too :( some kind of short circuit, I don't know.
    I have to go back to Arduino and MM, that I would have used for the other project I was going to start.
    I hope I can fix the two JRKs, or it's going to be a lot of wasted money :(
  17. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    First time hearing about pot killing JRK, usually it will give you the feedback errors in JRK Utility if something with pot is wrong. They are built to stand spikes up to 40 Amps and 16V, I kinda doubt a pot could kill it.. Maybe it's something else that you missed, overlooked?
  18. bsft
    @Blame73 , have you contacted Pololu or not!
    Or are you just assuming.
  19. Blame73
    8,304Coins
    yes I did, they asked me a couple of question that I answered and now I'm waiting for them to contact me again.
  20. bsft
    Copy that. At least you did. It surprising how.many people do not and then just blame a product
