help me ........
Discussion in 'DIY Motion Simulator Projects' started by dualclick, Dec 4, 2014.
  1. dualclick
    dualclick
    Meanwhile I wanted to thank you for your patience and professionalism of all the participants of the forum.
    A problem arose, I would build a 2 DOF motion, I began to buy various electronic parts but the store instead of sending your Arduino one rev 3, sent Arduino Leonardo. my question is can I do all steps listed for the construction of 2 dof or different card from the card arduino rev 3 I can create problems? thanks to excuse the language
  2. bsft
  3. SilentChill
    20,592Coins
  4. RacingMat
    21,050Coins
  5. dualclick
    dualclick
    Thanks a lot guys
  6. hamdy2000
    hamdy2000 New Member
    348Coins
    2DOF, JRK
    why not going to jrk? it's better and easy to work with.
  7. bsft
    mostly because its cheaper and they may have more time to work with ard
  8. Pit
    30,490Coins
    neither better nor easier. Each system has its pros and cons.
    • Agree Agree x 3
  9. Nick Moxley
    For some one who knows Nothing about ARD code, And after looking a bit into it on many of occasion's, there is a Simplicity factor in dealing with JRK's that isn't there with ARD there's no question. I would actually be curious as to know the specific Up's and down's to the "other side", But That will always turn into mines better than your's and that's a pointless debate that's futile.
    152,117Coins
    +11,066 / 56 / -2
    Mine is simple:
    Pro - JRK simple graphical setup and robust operation.
    Con - Can't control RC servo, in other word less flexible in what you can do with it, which is where the Arduino shines.
