value1
NoLimits Rollercoaster Simulation Plugin 2.0.1.17
SimTools game plugin for NoLimits Rollercoaster Simulation
  1. noorbeast
    152,591Coins
    +11,087 / 56 / -2
    The numbers keep changing.
    The strange thing is when I kept restarting NLR2 to capture the sequence of numbers in the pictures below it worked on the 5th go and I had motion, then it stopped again when I closed then reopened NLR2 again.
    The worst type of bug, an inconsistent one!
  2. value1
    15,078Coins
    152,591Coins
    +11,087 / 56 / -2
    I am happy to give it a go @value1, but it will be tonight. My father is coming over to test P3D in a few minutes (he will be on it for hours I expect) and then I am going over to his place to set up the DK1 Rift on my old rig for him.
  4. Wanegain
    Wanegain Active Member
    Bruxelles
    2,010Coins
    Thank you for this plugin !
    Just to be sure, when sway values are positive (go to right in Output testing/virtual axis), my seat should lean on the right or left ? :confused:
  5. value1
    15,078Coins
    Whatever feels better for you is right! Try both settings and decide.
  6. Wanegain
    Bruxelles
    2,010Coins
    That's my problem! I tried both and I prefer sometimes one and sometimes the other...
    152,591Coins
    +11,087 / 56 / -2
  8. value1
    15,078Coins
    Thank you, @noorbeast Good work :thumbs
    What concerns me though is that these numbers are exactly the numbers that are used by the plugin.
    Does it help if you run the GameManager in Admin mode?
    152,591Coins
    +11,087 / 56 / -2
    Yes @value1 I do get the same error if I run Game Manager in Admin mode.
  10. value1
    15,078Coins
    Hi @noorbeast
    Please try this plugin and let me know, if you see motion.
    It only works with NLS V2.1.0.0 x64 (non-steam).
    152,591Coins
    +11,087 / 56 / -2
    I have only had a limited time for testing @value1 but so far the plugin seems to work just fine.
    The only thing odd that I noted, and I am not sure it is related, my system clock was set back over a day.
  12. value1
    15,078Coins
    Thanks for the feedback. I have some potential culprits in mind for the problems with the original plugin
    Hmmm… coincidence?
  13. noorbeast
    152,591Coins
    +11,087 / 56 / -2
    It could indeed have been a coincidence @value1.
  14. value1
    15,078Coins
    152,591Coins
    +11,087 / 56 / -2
    I broke NL2 again :(
    I updated all my plugins when I grabbed the new War Thunder one this morning and now I am back to the motion not supported messages in NL2. I will have a go at rolling back to the plugin I had been using and see how that goes.
  16. value1
    15,078Coins
    I'm just wondering: was there an update > V2.1.0.0?
    152,591Coins
    +11,087 / 56 / -2
  18. noorbeast
    152,591Coins
    +11,087 / 56 / -2
    I had another bash at totally removing then reinstalling the NL2 plugin but still get the motion not supported message, any ideas @value1 and would it help if I ran through the Cheat Engine steps again?
  19. value1
    15,078Coins
    Is it still V2.1.0.0?
    152,591Coins
    +11,087 / 56 / -2
    Yes it is still V2.1.0.0, I triggered the problem when I used the last update.
    I have unpatched, removed entries from the directory, reinstalled, repatched but still get the error. I must be missing some entry somewhere :think
