Showroom 1/20 model of a 2DOF simulator for software and electronic tests
Discussion in 'DIY Motion Simulator Projects' started by petrus, Jan 6, 2015.
  1. petrus
    petrus Member
    146Coins
    I'd like to build a simulator but unfortunately, for the moment I live in an apartment and I don't have enough room for it. I can't get this project off my head so I am working on the part that doesn't require much room, the electronics.
    In order to test the electronics and firmware, I built a simple 1/20 scale model of a 2DOF simulator :
    The black plastic parts are 3D printed, it uses cheap RC servos with the original electronics removed. The positioning is made by the microcontroller, it reads the servos potentiometer and drive the H bridges through a PID algorithm.
    The electronics is all custom designed and built, for the moment an atmega128 development board, LCD + buttons board and two H-bridges that I designed for a battle robot (it's the white one) :
    And here is the sketchup file if you want to print the model : www.xsimulator.net/community/attachments/maquette-zip.18160/?temp_hash=d59b586e19ea9e56baad290924809ec6
    • Like Like x 7
  2. eaorobbie
    20,480Coins
    Neat , this should scale up very easily , have you been able to test run it with SimTools yet ?
  3. bsft
  4. petrus
    petrus Member
    146Coins
    It is not meant to be scaled up, it's just to test the electronics.
    I still have some work to do on the firmware, but I already tested it with SimTools, it works well with the test sliders, but it's less responsive in live for speed.
    Btw, what is the scale for the different values ? For the angle it would logically be +/- 180° for +/- 100%, but for g forces 100% represent how many gs ?
    That's a nice compact simulator bsft, but I would like to build a joyrider-like simulator with wide motion angle (target : +/- 45°) and that takes much more space.
  5. bsft
    not sure about scales, cannot help there
    Ok, joyrider sim. cool
  6. petrus
    petrus Member
    146Coins
    The lack of response I noticed in Live for Speed was just due to the global slider that was not set to 100%, once set to 100% it's super-responsive :)
    And I added two vibration motors :
    A small one to simulate tire slip and a big one to simulate shocks.
    I use the traction loss value for the small vibrations, but in live for speed it only works in one direction. For example, if I start full throttle and brake heavily, the value barely change, but if I make a 90° turn, and do the same thing, it works fine.
    To drive the big motor, I use a derivative of the 3 acceleration forces, if this value exceed a threshold it drives the big motor for a certain amount of time.
  7. bsft
    good idea using the vibrator thingys , that would be a different idea to bass shakers
  8. hooshang
    hooshang Active Member
    275Coins
    good idea but deferent from bass shakers,and the question is which values suit these motors for vibration?
  9. petrus
    petrus Member
    146Coins
    Since the traction loss value doesn't work very well (at least in LFS), I now use the derivative of the sum of the 3 accelerations(absolute values) to drive the small motor, if this value exceeds a threshold it switch the motor on. This strategy works well for small vibrations like driving on grass and gear shifting but not for tire slip.
    The bigger motor is driven the same way, but with a higher threshold so only big shocks will trigger it.
  10. welen123
    welen123 Member Gold Contributor
    HongKong
    35Coins
    I'm very interesting with your mini simulation ,how to wiring the steering engine to the arduino uno ? I want to build it too .:):):):)
  11. hooshang
    275Coins
    @petrus
    as I learned so far bass shakers or butt kickers works with sounds like motors sound, and the RPM value can do
    the same with vibrators and this has nothing to do with grass.
    regards
    Hooshang
    151,979Coins
    +11,061 / 56 / -2
  13. welen123
    HongKong
    35Coins
  14. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,796Coins
    Weld a sledgehammer to an arm of a Worm Drive motor for "Impact" simulation...
    It could spin and whack the "frame"
    Or for monster vibration weld half a rotor disc to a worm drive shaft.
    Likely shake the house of it's foundations!
    :p
    • Funny Funny x 3
  15. bsft
    Yep, that 'll do it, aussie ingenuity
  16. welen123
    HongKong
    35Coins
    I have build a RC model today,it looks will be OK,but there is somgthing wrong with the servo,I will check it tomorrow to find the problem, I used the RCModelDebugMode by @eaorobbie , hope i can fix the servo problem and run it.
    151,979Coins
    +11,061 / 56 / -2
    Neat model @welen123.
    It would be helpful if you started your own thread, explained what the servo issue is and others can then help you get it sorted.
  18. petrus
    petrus Member
    146Coins
    I traced some curves using sway, surge and heave values while driving a straight line on road and grass.
    road :
    grass :
    As you can see on the last curve, by choosing the correct threshold, the vibrations can be turned on during gear shifting and driving on grass and not while driving on the road. The big spikes at the en are when the car hit the wall :)
    151,979Coins
    +11,061 / 56 / -2
    So what were you using as the base game for your testing @petrus?
  20. petrus
    petrus Member
    146Coins
    I used live for speed
