Showroom Project going from wood to steel 2DOF platform
Discussion in 'DIY Motion Simulator Projects' started by dedas, Apr 2, 2014.
  1. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    Had the Mjoy board laying around, but what is the "bonar board" ? (link?)
  2. bsft
  3. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
  4. bsft
    fine , good luck with tronics stuff.............
  5. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    Thanks :thumbs
  6. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    Got my self a real racingseat, so the old school (bus)seat has got to go :rolleyes:
    The new seat fits perfectly and gives you more of a feeling driving a racecar.
  7. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Holy steep angle on those actuators
  8. bsft
    should be ok, if they struggle, fix later.
  9. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Well, yeh, that would be the case now lol....i noticed the seat is far back on the pivot and he is also using belts...meaning a lot of weight towards the rear....no pun....up to him, just my observation
  10. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    A minor upgrade:
    Made a simple robust solution to connect the pot to the axle of the motor by using a aluminum parts (see photo)
    made by a friend of mine, with screw-thread on one site and 5 mm hole (for the pot axle) on the other site.
    Works great!:thumbs
  11. Pit
    30,490Coins
    IMO not very long life made - the axle is bowed, isn't it?
    • Agree Agree x 4
  12. dualclick76
    dualclick76 Active Member
    italia
    11Coins
    the seat is very nice
  13. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    Your right, i've shorten the aluminum bushes so the pot axles fit (without the steep angle) so they last longer :).
  14. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    Latest update for the rig, got myself a nice Logitech G25 set.
    Works great!! give's better feedback and is robust.
  15. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    My ongoing quest for a digital dashboard i stumbled on "simracing-tools.de", this guy has build a amazing pice of software and its free!
    I've got some old android phones that i can use as a digital dash, works great, no soldering required. :grin:D
  16. grooste_lwd
    grooste_lwd Active Member
    Nederland => Friesland => Leeuwarden
    123Coins
    Hello everyone.
    I have three same IBT 2 H Bridges.
    I forum sought after as much as possible but could not find a complete drawing for three of the adapters with Aduino. I also read here about no mass together.
    I have tried to draw a picture. Will someone check if this can work. Or anywhere that needs to be restated.
    152,003Coins
    +11,061 / 56 / -2
    I am just posting this in the hope that members with Arduino experience such as @Pit, @RacingMat, @BlazinH or @RufusDufus could perhaps help out and review the wiring for you.
  18. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    The new seat is definitely nicer then the bus seat. Your rig is improving all the time and im sure you will continue to make improvements as time goes on. Nice job.
  19. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    Hi grooste_lwd (hoe gaat het? (dutch:))
    I've checked the wiring, and its looks ok to me. i would connect the ground pins 8 from the IBT's with the ground pin of the Arduino (i tested both, but preferred the all grounded solution). i had some troubles with the IBT's but could always solve it :grin. Works fine for me (working flawless for more than a year now, even don't need a cooling fan.)
  20. grooste_lwd
    123Coins
    Hello Dedas, Thanks for your response. I've already started to build. I'm going to build everything in one box with plugs on it. Ben now plugs on the search that meet my will. I want the potentiometers, power supply, and can connect motors with connectors because they then become universal cabinet, where everything can be easily and simply adjusted. Photo I have to make a little longer.
