Ioni Servo Driver! Sub 200
Discussion in 'DIY peripherals' started by shannonb1, Jan 23, 2015.
  1. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Just got a facebook note going with Granite Devices...going to do the Direct Servo Motor FFB......Argon is 600$+ to the US....The ioni is going to be less then 200$!! This means that for less then 600$ total we can build a servo drive motor!!!
  2. eaorobbie
    20,473Coins
    Ok so what the torque avail.
    Is the driver an easy one to drive as most require a 12v signal , not a 5v we can get from the Ard.
    I have run one before on a K8055, driver required a 24v signal for direction (0v - CW , 24V - CCW) and a 24v pulse which can be achieved on the K8055, pricey little exercise considering motor had only 4NM of torque, useless but we could make it run very accurately.
  3. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    nO, wasnt thinking about motion. The ioni is a server drive that can run the MIGE...if you follow the whole opensimwheel project you can see the details....the Argon drive that folks use now is around 630 us $ shippied. This is a perfect fit for that motor.
    10- 20 new meters of force..this is the DIY version of the accuforce that goes for around 1800 us $
  4. Nick Moxley
    17,056Coins
    Ya i heard they were releasing a MUCH cheaper version for us Guys, Awesome to hear its already here, When it is available ? ask your contact.
    Lol buddy's whole RIG is shaking from the FFb
  5. eaorobbie
    20,473Coins
    Cool if you don't mind break wrists , no thanks.
  6. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Im 240...squat 600lb and bench 425lb.....I got this.....and you can crank it down...the finite movements tha tyou get from this...the resolution....its just butter...have you seen the reviews for accuforce?
  7. kopper
    kopper Member
    Kansas
    3,343Coins
    Note to self - do not piss @shannonb1 off! haha
    • Funny Funny x 3
  8. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    LOL, naa, Im harmless, but good for helping people move stuff!
    • Friendly Friendly x 2
  9. RacingMat
    21,040Coins
    Hi, can you share the facebook link please ? I cannot find it
    yes, it was meant to be cheaper than (old) VSD @240€
  10. bberger
    bberger Member
    306Coins
    Not so fast. You'll need an expensive DC PSU for the IONI (36V/9A+ -> 100$+) and if you want to power it with more than 200W of power you'll afaik need to build an external power stage first.
    It WILL be a little cheaper but firmware wise it won't be that flexible. There are pro/cons involved with IONI vs. Argon.
  11. abs
    consultant
    Montreal
    774Coins
    3DOF, SCN5
    hello BBerger, i d like an advice . I decided to go the diy route even thouw i own the accuforce . the Ioni is not an hassle free solution if i understand . a newbee (somewhat) like me for less problem should go the argon route?
    thanks
