Bernax cockpits
Discussion in 'Commercial Simulators and Peripherie' started by bartez81, May 17, 2014.
  1. bartez81
    bartez81 i like amps
    Kraków
    - 2Coins
    2DOF, 3DOF, DC motor, AC motor, SCN6, Arduino, JRK, Motion platform
    Mdf, fiberglass and a lot of fun :)
  2. bsft
    Nice, like hyperstim. I think someone did plans to build it somewhere.....
  3. michto35
    michto35 Member
    france
    102Coins
    hi bartez,
    what paint you use for this?
    have you got a plan of your simulator ?
    nice work
  4. Roadster2
    Roadster2 Member
    1,194Coins
    Preparation is really the key with MDF but difficult to get a good paint finish on the MDF now owing to paint manufacturers having to remove the lead content to please the idiots in Brussels. Some companies can now powder coat MDF but this will probably be expensive. The best finish I've seen on a Hyperstim was having been sprayed by an auto body spray shop using a two-part paint. Another idea worth investigation would be to 'wrap' it in vinyl,as they do with cars and the fancy graphics on vans.
  5. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,796Coins
    Full Bentley or just a wheel off one in the background there??!
  6. eaorobbie
    20,473Coins
    Trick I have found with MDF is that you need to seal it with a wood dope then you have a nice surface that you can paint with anything, a good mat under coat works well too as the MDF absorbs it like a sponge.
  7. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,943Coins
    Another way of doing a good painting is the
    Water Transfer Printing - Hydro graphics - Wassertransferdruck ...
  8. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    I have a buddy who does this and powder coating.
  9. eaorobbie
    20,473Coins
    Yes totally agree the ultimate if you can afford, very very expensive here.
  10. speedy
    Alexandria , Egypt
    7,943Coins
    Not so much expensive with respect to the output quality ...
    Here is a home made version of this printing style with Epson and HP printers ...
    there prices are fair enough for the $3 per sheet of A4 paper ...
    http://www.prostreetgraphix.com/
    http://www.prostreetgraphix.com/store/products/#product_category=-1&order=price-asc&page=undefined
    and for the DIY activator formula see this vid ...
    • Informative Informative x 3
    151,467Coins
    +11,041 / 56 / -2
    The second video is a workshop in my State that I did not even know existed...great find @speedy!
  12. insanegr
    insanegr !N$@n€
    Athens
    16,721Coins
    another way for painting things
  13. BlazinH
    16,661Coins
    Nice cockpit! It is not a problem painting MDF if you want to go that way though. Go to your paint store and ask for a bonding primer. I prefer an oil-based product due to its leveling abilities but with new technologies today there are good water based bonding primers out there too. Actually, I suggest just one coat of a standard oil based primer, as it is usually sufficient to do the job. But, with MDF, you will need to apply several coats of primer to all the edges if you want it to look good when finished because its porous edges are hard to seal. Give it a good sanding with 220-grit sandpaper between coats and try not to sand thru the primer on the corners on the last sanding. Then you can paint it with just about anything other than a lacquer product. If you did want to spray lacquer on it, then I suggest using water based bonding primer first or the finishes recommended priming product for MDF.
    ps I don't know much about wrapping. Can it be made to look good around the corners of your MDF?
  14. ferslash
    ferslash Active Member
    4,798Coins
    man if you have plans for the wood cutting i would be a grate share :D
  15. ferslash
    4,798Coins
    nice final pic :D
  16. speedy
    Alexandria , Egypt
    7,943Coins
  17. speedy
    Alexandria , Egypt
    7,943Coins
  18. bartez81
    Kraków
    - 2Coins
    If someone wants the cockpit in any color of the chair just send priv
    in our beautiful country they are doing a lot of things
    whether it's good or bad ...
