Ville Pesonen
War Thunder Plugin 2.0.0.0
SimTools plugin for War Thunder
  1. value1
    15,032Coins
    War Thunder Plugin - SimTools plugin for War Thunder
    Any feedback is very welcome. I'm still a horrible pilot :D
    • Winner Winner x 3
    152,111Coins
    +11,065 / 56 / -2
    This is my father's favorite, can't wait to give him a go, thanks so much @value1.
    I had a highly tweaked setup for the DK1 and War Thunder, but Gaijin really botched the DK2 support. I did contribute a tweak to at least work around some of the worst DK2 issues, but put WT aside in favor of other better DK2 flight options. Now I have a reason to go back and see if more can be done to improve WT with the DK2, as my father would rally enjoy WT with motion and the DK2.
    152,111Coins
    +11,065 / 56 / -2
    No joy for me @value1, I am not getting any telemetry data registering in the Virtual Axis, other than Yaw which goes to 0% when War Thunder is launched and stays there. War Thunder does connect in Game Manager.
    There was a War Thunder auto update from the 26th which came after you released the plugin and before I tried it today, which may be an issue: http://devblog.warthunder.com/category/changelog/?hl=en
  4. value1
    15,032Coins
    Looking at the frequency, how often they update the game, this might be a no go.
    Looks like I have to withdraw this plugin.
    @noorbeast Thanks for making me aware
    152,111Coins
    +11,065 / 56 / -2
    War Thunder is a bit like that @value1.
    If you can talk me through the Cheat Engine stuff, much as you did with Nolimits2, I would be happy to give it a go in terms of tracking changes if that would help.
  6. value1
    15,032Coins
    I quickly checked and we'll find a way to easily keep the plugin updated!
  7. value1
    15,032Coins
    152,111Coins
    +11,065 / 56 / -2
    I have Yaw output @value1, but nothing else. Anything I can do to fault test?
  9. value1
    15,032Coins
    Explode.gif I had a funny feeling, this might be the case…
    I need to investigate more. Sorry!
    152,111Coins
    +11,065 / 56 / -2
    Please let me know if I can help in any way @value1 .
    I am using the downloaded version of War Thunder, if that makes any difference.
  11. value1
    15,032Coins
    Hi @noorbeast
    Did you run GameManager in admin mode while playing. GameManager needs to be in admin mode to catch the data.
    152,111Coins
    +11,065 / 56 / -2
    Yes @value1 GameManager is started in admin mode and I do have Yaw data, but nothing else.
  13. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    @noorbeast
    I've just tried it, with latest version 1.45.11.86 and I got all the data and motion, used the Test Flight mode in game.
    EDIT:
    @value1
    Found the problem, it is in "Cockpit View" - There is only Yaw data in cockpit, in third person view is all other.
    IMHO, it would be better to have all data in Cockpit view, while it's more immersive and realistic view, rather than third person view.
    152,111Coins
    +11,065 / 56 / -2
    Thanks @prodigy.
    I have to agree, while a lot of mouse users play War Thunder in third person view in cockpit is what suits simulation.
  15. value1
    15,032Coins
    Good information from both! Thanks!
    How do I switch to "Cockpit View"?
  16. prodigy
    Croatia
    6,698Coins
    Menu - Game Options - Main Parameters - Default view
    152,111Coins
    +11,065 / 56 / -2
    You can select the view type on the first menu when test flight is launched @value1.
  18. noorbeast
    152,111Coins
    +11,065 / 56 / -2
    I tested @prodigy's observation and yes there is motion in 3rd person view, which is one you really don't want to use for simming and one your definitely don't want to use with the Rift, unless you want to be very ill. To complicate matters there is the cockpit view and the virtual cockpit view, with the latter being the default for bombers, as they do not have rendered cockpits.
  19. value1
    15,032Coins
    152,111Coins
    +11,065 / 56 / -2
    Works great @value1, in both cockpit and virtual cockpit views, you can even switch between them with no problems.
    If at all possible at sometime in the future can roll be set up for WT on Extra 2, as you did with FSX/P3D? For me I find that far more realistic with the Rift.
