New build, arduino, motomonster, 2dof
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by substatica, Jan 2, 2015.
  1. substatica
    substatica Member
    882Coins
    Coming along. Have boxes for the Arduino, Motor Monster and Raspberry Pi B+ which will run version 1.0 of this thing. Using a 12v case fan and a chunk of an old mac heat sink to cool the Motor Monster, a 12v -> 5v USB car adapter to power the RasPi which will in turn power the Arduino. Slowly but surely.
  2. Blame73
    Blame73 Well-Known Member
    8,303Coins
    Sorry, I surely missed something. What will you use Raspberry Pi for? Apart from powering the Arduino
    151,461Coins
    +11,038 / 56 / -2
  4. substatica
    substatica Member
    882Coins
    The RaspPi will power the Ardunio, program the Arduino, allow serial communication with the Arduino for motor control as well as provide WiFi connectivity potentially a web interface, etc. As @noorbeast mentions version 1.0 of this rig won't run SimTools but a combination of custom Arduino and Python code.
  5. substatica
    substatica Member
    882Coins
    Wiring complete, fired it up with some test code and thankfully no mistakes -- though one pot is taking a beating I think ;)
  6. Nick Moxley
    17,056Coins
    Appears both pots are doing a little jiggle.....I would investigate that a little further.
    151,461Coins
    +11,038 / 56 / -2
    The 'Cribulator'...a whole new genre of motion simulators!
  8. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
  9. substatica
    substatica Member
    882Coins
    Barg, I think I blew a channel on my Motor Monster, I was changing some code and one motor just stopped, upon the second try I thought I heard a pop now that channel of the Motor Monster doesn't seem to function.
    At first the direction indicator lights were both on, but having removed the heat sink and checking for damage (which there doesn't seem to be any on any components aside from the "something's burnt" smell) that channel still doesn't work, and the direction lights are off. Don't these things have protection?
    • Dislike Dislike x 1
  10. Nick Moxley
    17,056Coins
    o boy, "that" smell is Never a good thing.
  11. Pit
    30,482Coins
    smell = blown
  12. Pit
    30,482Coins
    Why are you changing some code? If you change the code you have to change the wiring as well. Did you run into any problems?
  13. substatica
    substatica Member
    882Coins
    Not changing any of the wiring code, I'm writing my own controller code for the Arduino, I was working on some acceleration/deceleration code not sure why it would've blown anything I guess it can't handle 255 PWM with my setup as that's the maximum it would ever receive.
    What would cause this and how do I prevent it from happening again?
  14. Pit
    30,482Coins
    I am not a programmer, but there exist 3 very good and working codes, so why you write an other code...:) The code of @RufusDufus (SMC3) has some security routines included, which (should) prevent the motors from any damage if something goes very wrong...
  15. substatica
    substatica Member
    882Coins
    I won't be using this code with SimTools to start, plus I would like to understand from the ground up how everything is working. How is one suppose to know the upper limits unless they're tested? I'll impose a lower max PWM now, but still don't know what the actual max is or what it would've blown in this instance.
  16. substatica
    substatica Member
    882Coins
    So let me ask this, what's the max PWM the Monster Motor can handle with these crab pot motors using ultrasonic PWM code?
    I see @RufusDufus code has 100 as a limit,
    int PWMmax1 = 100;
    int PWMmax2 = 100;
    int PWMmax3 = 100;
    Is that generally what folks are using as an upped limit? I really don't want to burn another MM.
  17. RacingMat
    21,039Coins
  18. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,199Coins
    Hi substatica,
    Those settings in the SMC3 code are just the default values for first time use. They can be changed using the Windows SMC3 Utils setup program and the new values are stored in EEPROM and used from there.
    The PWM sets the duty cycle, 100% (255 if you are using 8bit PWM) means that the H-Bridge is permanently on. In other words the Power Supply remains connected directly to the motor until the PWM changes.
    Whether the H-Bridge can support a continuous 100% duty cycle or not depends largely on whether the current drawn from the motor in this state is within the H-Bridge limits.
    In reality though as it is a max PWM value, for motion sims using PID feedback, the output wouldn't normally remain in this state for long - only ms at a time.
    100% duty cycle should only be necessary to get the motors moving then it would typically drop and be very dynamic.
    Make sure the H-Bridge has good cooling, it is usually overheating due to excessive current that causes them to fail.
  19. substatica
    substatica Member
    882Coins
    The H-Bridge, the Monster Motor Shield from Sparkfun in this case, has thermal paste, a large heat sink across both chips and a PC case fan on the enclosure (pictured below). I was working on some code to accelerate (raise the PWM) when beginning a travel and decelerate back down when approaching the target, something was off and I suspect the motor got 255 PWM for potentially a couple of seconds. When I get a new H-Bridge I'm going to set a hard PWM limit to 100 I think.
    The power supply is a converted HP server which many folks seem to use.
  20. Pit
    30,482Coins
    are you sure there is no possible short circuit?
