Arduino lessons
Discussion in 'Forum and Website' started by kanuk, Feb 5, 2015.
  1. kanuk
    kanuk If it ain't moving, it ain't simulating...
    Eng
    Melbourne Australia
    2,380Coins
    Could one of you kindly point me to where I could go to properly read up about an Arduino setup for a 2 / 3 DOF?
    I have done a search but there is too much coming up without clarity
    I want to find out if I have to use a particular type of Arduino board or are all of them suitable etc.
    Thank you kindly!
    152,571Coins
    +11,087 / 56 / -2
  3. kanuk
    Eng
    Melbourne Australia
    2,380Coins
    @noorbeast
    I did indeed sir. But it doesn't state which board exactly, I believe the 328's are all that are needed but I thought maybe the ATmega2560's may be better? Not sure so I thought I would ask....
    I want to experiment with this setup so that I can use independent motor bridges to power bigger if I need to.
    152,571Coins
    +11,087 / 56 / -2
    I am about to start playing with Arduinos as well, just got 2 more today.
  5. kanuk
    Eng
    Melbourne Australia
    2,380Coins
    Oooo..... Keep me in the loop! :)
  6. ferslash
    ferslash Active Member
    4,798Coins
  7. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    hello what kind of motor do you intend to use ?
    snc5?
  8. kanuk
    Eng
    Melbourne Australia
    2,380Coins
    @abs
    motor specs.jpg Not the Scn-5's...
    Its a worm drive 50/60:1 ratio gearbox at 52nm torque.....
    Here it is
  9. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    hello
    so sorry not familiar with this motor. however it is important to know wat you inteneted to drive with the arduino. someone more knowinng will help
    good luck with this project
  10. kanuk
    Eng
    Melbourne Australia
    2,380Coins
    No probs @abs
    Its not really any different form the other motors used here... just a more industrial. A little tougher than the norm....
  11. RacingMat
    21,059Coins
  12. kanuk
    Eng
    Melbourne Australia
    2,380Coins
