simulador 2dof arduino inicio
Discussion in 'SimTools compatible interfaces' started by Claudemir, Nov 22, 2013.
  1. bsft
    what problems are you having and as you are using arduino, whos code are you using
  2. Claudemir
    33Coins
    Boa tarde!
    Eu estou usando o Arduino R3 com o H Ponte BTS 7960.
    Estou usando 250wts 24v motores 15A.
    O código que estou usando é o que mostrou ufusDufus me. http://www.xsimulator.net/community...3dof-motor-driver-and-windows-utilities.4957/
    O problema é que quando se aumenta a potência do motor por SMC3 a ponte H esquenta e funcionando!
    Gostaria de saber qual H Ponte poderia estar usando para motor com grande amperagem!
    Vou postar uma foto do motor que eu quero usar.
  3. bsft
    do you have heatsinks on the big chips or some fan cooling on the h-bridge?
    Otherwise, as on SMC thread.
  4. Claudemir
    33Coins
    Thanks for the rapid responses! @bsft
    Is bridge has a large sink beneath them!
    So I'll have to put a heatsink on the right BTS70760?
    Between the BTS and the sink have to put some thermal paste as well?
  5. bsft
    Photo please
  6. Claudemir
    33Coins
    [QUOTE = "BSFT, post: 65,841, Membro: 4876"] Foto por favor [/ QUOTE]
    esta é a ponte H eu estou usando! 20141206_225107[1].jpg 20141206_225156[1].jpg 20141206_225107[1].jpg
  7. bsft
    oh , ok then , there is a heatsink on the bottom. Maybe try raising the board up higher and get a stronger fan to try to cool it.
    And ask on the SMC thread as well
  8. Claudemir
    33Coins
    Good evening! @bsft @eaorobbie @RufusDufus
    Personal'm having an error with the GameEgine.
    (GameEgine Error stopped working) then the GameEngine closes.
    It works normally for a short periudo and.
    To back up and running have to remove the USB cable and reconnect Arduino again and reopen the gameEgine!
    You know how I can fix this?
  9. Pit
    30,482Coins
    @Claudemir : did you do something especially before SimTools stops working? Which Arduino code are you using?
    Please UPLOAD all your settings, we cannot do anything if no information is given.
  10. Claudemir
    33Coins
    @Pit
    I'm using the SMC3 v0.7 with SMC3Utilsv0,63.
    Arduino R3 MODE2 24v engines.
    image of the following errors below! configuração arduino.png configuração arduino.png erro SMC3.png
  11. Claudemir
    33Coins
  12. Claudemir
    33Coins
  13. Pit
    30,482Coins
    First please use only smc 0.63 code and utility. Second your smc settings are very extreme, Fpid 10 instead of 1 or 2, kp 815? Or it is 315? If 815 it is way too much. ks, ki, kd - do you need such high values? Are you sure what you are doing? And Pwmmax and min, same values here makes no sense.
    PS: please check the com port baud rate, too.
  14. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,200Coins
    I would try to disconnect the 24V power to the H-Bridges and see if everything works ok (except of course the motors won't move)
    For the windows program to crash I suspect you have got some earthing issues?
  15. Claudemir
    33Coins
    good night @RufusDufus
    I disconnected the source of 24v and the SMC3 works !!;)
    but when I turn on the source, the SMC3 to go again!:(
    The problem is in the earth connection?:sos
    How can I solve this problem?:sos
  16. bsft
    did you earth isolate the motor casings? Was it wipers you are using?
  17. Claudemir
    33Coins
    @BSFT Engines'm sweating are not cleaners are identical engines but are used in outomação. (In ospitalares beds)
    How and how I I isolate the engines?
  18. Claudemir
    33Coins
    good night @eaorobbie @bsft @Historiker @ RufusDufus :(
    how do I isolate the engines?
    I have segunte problem:
    when I'm turning off the source everything works, but when I turn on the source programs as SMC3 and GameEgine stop working.
    I am using an Arduino R3, brushes Engine 24v 250wts used in automation.
    Please helped me !! :sos :(:(:(:(:(
    151,467Coins
    +11,038 / 56 / -2
  20. Pit
    30,482Coins
    from the FAQ: First test with a multimeter(buzzer Ω) that you don't have any contact between the case (body of motor) and three cables.if you don't hear anything you are OK if you hear the buzzer on the multimeter you have to isolate the motors
