Game Data Input No Limits 2 - No Value
Discussion in 'SimTools DIY Version' started by ullypot501, Feb 15, 2015.
  1. ullypot501
    ullypot501 New Member
    276Coins
    3DOF, AC motor
    Hi everyone,
    We are starting a simulator project that will use inputs from the No Limits 2 and SimTools softwares.
    Unfortunately, I cannot seem to set up the two to communicate correctly because no values are displayed in the Game Data Input in Game Engine. I would like to ask for assistance in addressing this problem.
    Thank you
    153,728Coins
    Can you post pictures of you Interface and Axis settings as well.
  3. ullypot501
    276Coins
    3DOF, AC motor
    Hi noorbeast,
    thank you for your reply.
    I am still trying to figure out how to set up the interface.
    Is it possible to get the Game Data Input in a graph format?
    force vs time perhaps?
    153,728Coins
  5. ullypot501
    276Coins
    3DOF, AC motor
    is it possible to skip the interface setting?
    we will build the simulator from scratch and we are planning to
    use PLC to control the VFD and AC Motors.
    so we dont have that information yet.
    153,728Coins
    The interface settings is how SimTools interfaces with your hardware and there are handy presets for common setups. Perhaps you can explain exactly what it is you have and are trying to do.
  7. ullypot501
    276Coins
    3DOF, AC motor
    for now, all we have are no limits and SimTools plus plugins.
    But we are planning to use PLC instead of arduino to control the
    VFD and AC motors once we are confident that we can implement it.
    What I am trying to do right now is to get Game Data Inputs from No Limits.
    I am able to see the values that I need from NL2 but I prefer to be able to see it using Game Engine Tune Center. also It would be helpful if I can log the forces so that I can plot it in a force vs time graph. This will help me better appreciate the movement of the roller coaster.
  8. value1
    14,236Coins
    @ullypot501: Would you take the little effort and read in the forum, you would come across this post…
  9. ullypot501
    276Coins
    3DOF, AC motor
    I apologize if it seems that I am not reading through the forum. But believe me, that is all I've been doing since
    Wednesday. Of course, I can only read during my off hours because I have a day job so I can only cover as much.
    This is exactly what I am afraid of. I have been delaying the posting of this thread since friday night because I am
    worried someone might find my queries stupid. Please bear with with me I am just excited with this project.
  10. ullypot501
    276Coins
    3DOF, AC motor
    Thank you for all your help.
    I am now able to see the values for the Game Data Input.
    I have read from one of @value1 post that you should run the game first
    then run the SimTools and it worked. Now, I am just concerned with the discrepancy in the
  11. value1
    14,236Coins
    So Speed is in [km/h] while Extra1 is the same value in [m/s]
    Vert. G-Force is the same as Heave. 1.4 vs 1.355. This is a rounding error.
    Aceleration is the same as Surge. Again 0.0 and 0.02 is a rounding difference.
    Horz. G-Force is the same as Sway. What is not shown in your screenshot is the exponent of Sway. I'm sure the value is -0.04 or so.
    (Sway might be -(Horz. G-Force) because of force convention reasons)
  12. ullypot501
    276Coins
    3DOF, AC motor
    Yup. thank you for all of your help.
    @value1 :)
    regarding my question about plotting the force and speed values vs time.
    is it possible?
  13. value1
    14,236Coins
    The plugins do not log telemetry data. However you can write a little program that logs the data you receive via the description
  14. ullypot501
    276Coins
    3DOF, AC motor
    got it.thanks.
    hope to contribute in the future.
    once we have our rig running.
