simulador 2dof arduino inicio
Discussion in 'SimTools compatible interfaces' started by Claudemir, Nov 22, 2013.
  1. Claudemir
    33Coins
    Thanks for the quick response! ;)
    I did the tests with the multimeter and has no contact with the motor hull.:sos
    I will send photos of my equipment.:)
    20150216_125009.jpg 20150216_125018.jpg 20150216_125028.jpg 20150216_125037.jpg
  2. insanegr
    insanegr !N$@n€
    Athens
    16,721Coins
    have you tried to power on your electronics with no motors connected to see what happens?
    if it works ok try connecting one motor at time. if not try another power supply at 12V without motors connected again.
  3. Claudemir
    33Coins
    When I turn on the plates only works!
    But when you connect the source to the motor does not work.
    I have 2 sources of 50A 24V, 4 engines of this that in the photo.
    I've only had all the components even the Arduino.
    Also changed the H bridge to see what was happening and nothing!
    did not fail to test the connected source without running the engine and ran everything, but when I turn on the engines and the SMC3 GameEgine works for about 2 seconds or less and giving the message that something caused the GameEgine stop working !
  4. insanegr
    insanegr !N$@n€
    Athens
    16,721Coins
    if i can understand right you are saying that when you turn on your motors power supply with motors disconnected everything works ok and when you connect them, then SMCutils crashes?
    have you done what @Pit advised you as @noorbeast said earlier?
  5. Claudemir
    33Coins
    Yes that's right!
    So I did the tests but the engines are ok!
    No contact with the wires in motors (the land is not giving contact in the engine block)[/QUOTE]
  6. Claudemir
    33Coins
    Good afternoon staff? @insanegr @bsft
    I did the tests with a crush notebook I have and everything works normally!
    I'll format my conputador, may be something wrong with the windows7 64bit?
  7. Claudemir
    33Coins
    Goodnight everyone?
    @noorbeast @bsft
    how do I get the platform movements is smooth?
    My engines are 24v 250wts Reduction 1/25.
    The movements are very sharp especially in NoLimits game.
  8. eaorobbie
    20,473Coins
    Ok at a guess you need to tune the Min and Max in the Tuning centre.
    151,467Coins
    +11,041 / 56 / -2
    Can you please post pictures of your Settings and Tuning Center in the SimTools Game Engine.
  10. Claudemir
    33Coins
    thanks for the reply!
    is how you give me a hint on how to set the Tuning center?
    how do I save? did not quite understand this part!
    • Optimistic Optimistic x 1
    151,467Coins
    +11,041 / 56 / -2
    The basic info for Tuning Center settings is here: http://www.xsimulator.net/tuning-centre/
    Keep in mind that the Tuning Center is working with whatever % you set in the SimTools Game Engine.
    Increasing the Min/Max numbers will slow how fast the rig reacts for that force and decreasing them in value makes the rig respond quicker. By unchecking the tick you can set the Min/Max at different values, which is useful for simulating things like gear shift.
    So you can increase the numbers for whatever force feels too sharp, Sway, Surge or Heave.
    The simplistic approach is pause the game, follow the steps 1-6 in the link, test it, then tweak individual axis settings one by one. However the best approach is to set the % and tweak each axis settings one by one.
  12. bsft
  13. Claudemir
    33Coins
    friends has a video showing how to do this?
    please.
  14. Claudemir
    33Coins
    Good afternoon?
    @bsft You could make a video of how to change the tuning center.
    Sorry but I'm struggling on how to proceed even reading the manual!
    To give you an idea motors are moving so fast that broke my structure!
    I tried to reduce the SMC3 in PWMmax and PWMmin, but then the engines do not realize lift the weight! please:(:sos
  15. Pit
    30,482Coins
    @Claudemir you have to raise up the values in the tuning center, meaning you begin with 20 and then reduce step by step.
  16. bsft
    No I do not have time to do a video, others here have almost explained word for word in different ways. Figure it out.
    Thats and yo obviously cannot read, my signature says I do not know arduino. So why the hell are you asking!
  17. Pit
    30,482Coins
    @bsft lol, mate cool down. :cheersI think sometimes we are too helpful, so some guys do not bother reading the basics. I wonder how to build a sim if someone cannot read the manuals and all the hints given by the very helpful users.
  18. bsft
    reading the manual is fine, then asking questions about something thats not even on the manual is wrong, especially when I find out they are also getting advice from people whom do not know.
    Dont worry @Pit , you are one of the knowledgeable ones
  19. Claudemir
    33Coins
    Thank you all for the answers!
    I know I can be being inconvenient and annoying.
    Also peopl apologize for not knowing how to read or properly understand the manual.
    I do not have the same ease of interpreting and understanding the programs as well as many of you, and even adimiro patience who are having me hope that I can finish my project because it is my dream.
    I am Brazilian and Brazil does not have the same attitude
    Congratulations thank you!
  20. dualclick76
    dualclick76 Active Member
    italia
    11Coins
    good job
    • Dumb Dumb x 2
