2 DOF arduino , sabertooth , moteur essui glace 24v
Discussion in 'DIY Motion Simulator Projects' started by zigzag49, Feb 16, 2015.
  1. zigzag49
    zigzag49 Active Member
    726Coins
    Tout sur le nouveau forum, je vous présente maintenant mon DOF simulateur 2 ou un peu plus d'un moment de fabrication et en constante évolution.
    La structure est la base en bois et un support métallique ne est placé à l'arrière du siège pour la fixation des rotules.
    matériel:
    - Carte Arduino Uno
    - Sabertooth 2x25
    - 2 Moteurs 24v
    - PSU 24v power supply
    - Volant T500RS
    - Logitech Z906 5.1 Surround
    - Ecran Samsung 121 cm
    - Boite H fait maison
    Construction of the shelf and the wooden base:
    Here all the pieces are sticking plate, no screws and rounded sides has the router.
    Pedal bracket and two large holes is to lighten the shelf.
    Wheel support and the collars of the seat.
    manufacture of the base.
    The plate mounted on the gimbal.
    Tie rod, cut and welded to the rods.
    I was forced to add a reinforcement to the back as the front of a simulator that was moving faster.
    which I also permi setting fan and put rubber feet (abut door).
    • Like Like x 9
  2. michto35
    michto35 Member
    france
    92Coins
    Salut ZigZag
    Je te connaissais déjà du forum RFR mais je me lasse pas de regarder ton simu, il est vraiment très réussi, beau travail.
    Hi ZigZag
    I already knew thee RFR forum but I get tired of watching your sim, it is really very successful, good work.
    153,812Coins
    +11,150 / 57 / -2
    Thanks for sharing both the photos and video of your sim in action, great work.
    I am guessing the U shaped foldable bracket at the front is there to keep the sim supported when un-powerd?
    I like the shifter. Was there a reason you chose to not have a shift knob on it?
  4. zigzag49
    726Coins
    Thank you Indeed the simulator remains off right with a bike crutch made. The box H has no head because it is not finished yet, I want to adapt the sequential function.
    153,812Coins
    +11,150 / 57 / -2
    Thanks for the update, please do add further details when you further modify the shifter and anything else.
    Just a thought for consideration. I am guessing from the fans that the motors are working pretty hard and could get hot. Perhaps a higher connecting point above the COG would help reduce the load on the motors a bit.
  6. Wanegain
    Wanegain Active Member
    Bruxelles
    2,018Coins
    Je connais (bien) zigzag aussi :p ! J'aime beaucoup son simulateur et ses petites astuces toute simple mais tellement efficace !
    I know zigzag too ! I like his rig and its little details all simple but so effective! :thumbs
  7. zigzag49
    726Coins
    :thumbs:thumbs
    Wanegain thank you and michto35 I will put more detail, its been a post test for the pictures but its going
  8. zigzag49
    726Coins
    The engines will be changed for already a lot of time (recovery) they have the game for more powerful.
  9. momoclic
    momoclic Active Member
    Retraité
    Nantes - France
    2,773Coins
    DC motor, Arduino
    Zigzag49 a brave boy who allowed me to test the simulator.
    I affrirmer you that mind-blowing ...
    And more, it gave me the first piece of the one I'm building: a universal joint.
    Zigzag49 un brave garcon qui m'a permis de tester son simulateur.
    Je peux vous affrirmer qu'il décoiffe...
    Et en plus il m'a offert la première pièce de celui que je vais construire : un joint de cardan.
  10. zigzag49
    726Coins
    merci momoclic , ton simulateur en cours de construction va bien promettre aussi ;)
    momoclic thank you, your construction simulator goes as promised.
  11. zigzag49
    726Coins
    More details on the H box
    Manufacture of aluminum plate made with drill bit 10, jig saw, chamfer for speed passage router.
    Grid finished with hit numbers.
    Details on the mechanism.
    Two rolling support for the left / right tilt of the lever.
    Finishing and painting the elements of the mechanism.
    The support of the box.
    And voila or all is in place with wood screws + 2 on the left.
    Feedback mechanism in the center of the lever.
    The gearshift contacts.
    For the locking mechanism of the lever, I're inventing anything, just copy a member (tortueG) RFR.
    The encoder used, which also will serve me for a boite a button.
    http://www.smallcab.net/encodeur-jo...sb-joueur-cosses-28mm-p-274.html#.VOOAOi6j-p2
    • Like Like x 5
  12. eaorobbie
    20,503Coins
    Video not a working. ?
  13. zigzag49
    726Coins
    I do not understand why there is little play the video, I see it.
  14. leaedman
    leaedman Active Member
    Valenciennes, France
    470Coins
    Superb, I read your thread on RacingFR well. superb finish :)
    (Superbe, j'avais lu ton thread sur RacingFR également. Superbe finition)
  15. zigzag49
    726Coins
    Thanks you.
  16. zigzag49
    726Coins
    Adding photos hoping that everything displays home.
    153,812Coins
    +11,150 / 57 / -2
    Yes the photos are excellent and provide far more detail of your work than mere words.
  18. zigzag49
    726Coins
    Simtool passage today is a pure pleasure, video soon;)
  19. leaedman
    470Coins
    Super ! Vivement la vidéo :popcorn
  20. zigzag49
    726Coins
    New video with simtool test sway and surge effect.
