OCSM Sim (2dof + traction loss) project
Discussion in 'DIY Motion Simulator Projects' started by Overclockersmania.it, Feb 15, 2015.
  1. Overclockersmania.it
    Overclockersmania.it Member
    Cagliari, Sardinia
    20Coins
  2. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    I have same 90ZYT-155 motors with same MCP4 25:1 gearbox that you linked, also bought from Motion Control Products.
    The motors specs are as following:
    Voltage: 12v
    Current: 23a
    Speed: 5000rpm
    Diameter: 90mm
    Length: 155mm
    So with 25:1 you will have 200 RPM.
    Unfortunately for me, I've never could make them work with JRK controllers. The specs, if they are true, are saying 23A, but I think they draw A LOT more under load and motion changes and that was trouble for JRK boards. @Avenga76 had similar problems with his motors drawing over 70 Amps at moments and JRK's choking up, and he has 60:1 gearboxes. He needed to slow down the motors and motion to make them work with JRKs with minimum errors.
    But there are also other people who are using ZYT90 motors, they can share more thoughts on it. I think @Erwan960 ?
  3. Wanegain
    Wanegain Active Member
    Bruxelles
    2,018Coins
    You can use them with a big sabertooth 2x60 and an Arduino. It's a good choice for this price!
  4. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
  5. bsft
    the higher rpm motors may be causing an issue, but that doesnt mean toss the jrk away.
    As Avenga has done, slow the motors down and work with motion, PID and things, (same thing I had to do) or find slower RPM motors.
    see if you can chase up motors under 4000 rpm.
    @Roadster2 , got any slower motors?
  6. Roadster2
    Roadster2 Member
    1,197Coins
    Sorry Dave, the motors I had were the same and I only have a couple of 50:1 ratio gearboxes now. The spec. sheet for the ZYT90 motors (attached) state 23 Amps but a spec. sheet for a "90ZYT155 12V" states 27.8 Amps. Either way, I assume that this is under "no load" conditions. If so then given the task that they're fulfilling on a motion platform then they would indeed draw a much higher current.
  7. bsft
    @noorbeast , how hard do you thrash your motors?
    Whats your PID and motor settings?
    153,728Coins
    I currently run P: 0.25977 I: 0 D: 0.5, PID period:15, Integral Limit 10000.
    For the motors I am currently running:
    Max duty: 300
    Max accel: 600
    Brake duration:0
    Max current: 0
    Current: 120
    Max DC out of range 600
    I will revisit these when I remake the front pivot bar to move the connecting point forward. If you look carefully at the recent photos and video you will see I currently have it reversed to increase the leverage. Initially I was driving the motors pretty hard and they were getting hot, now they barely get warm. It is amazing how much of a difference a little more leverage makes.
  9. Erwan960
    Erwan960 Active Member Gold Contributor
    3,832Coins
    As far as I'm concerned, I currently use :
    P : 0.47
    I : 0
    D : 0.67
    period : 10 ms
    Integral limit : 5000
    Max duty : 400
    Max accel : 300
    brake : 0
    max current : 35.7
    current : 140
    max dc out of range : 400
    During a 1h race, I find no error in the report of the JRK software.
    Motors : ZYT-90 155 : 3200 rpm / 0.6 Nm
    Gearboxes are : 60:1
  10. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    Hi guys and thanks for your feedback!
    It's really helpful to read your comments and go back to your projects (I've spent A LOT of time on them) finally understanding why some points were so important.
    By the way, tomorrow I will weld the complete frame so various things about movements will be finally clear and measured.
    Regarding motors, in my first attempt I will try to move the structure with my current motors driven at 16V (12V+3.3V from two pc power supplies) and an arm of about 15cm. Curious to see what will happen.
    Next step will be to finally buy decent motors and in case, proper electronics.
    And I have to say, most probably I'll go for the ZYT-90 with 25:1 gearbox and Sabertooth, using the current Motomonster in the future to drive the traction loss.
    Stay connected!
    Marco:)
  11. bsft
    150mm CTC lever, on what motors?
    even on larger motors you are looking at issues with actually having too much travel and reduced torque.
    Been there, done that. Shorten the levers right down, even with bigger motors.
    It will not move the frame.
  12. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    after a productive day the frame has been almost completely welded. Not big issues so far..
    But from now the challenge will be harder! Can't wait to see the sim moving!
    @bsft, thanks, definitely 150mm CTC is too much, i will look for another solution…
  13. bsft
    if you are going to use 25:1 boxes, and a full frame, go no more that 40mm CTC levers.
  14. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    Here I am again.
    Thanks for your kind interest bsft! :cheers
    Unfortunately this week-end just a few improvements and some new questions:
    Has anyone ever tried to use a long screw (like this http://www.bricoman.it/negozio/ferr...a-friulsider-m12x1m-acciaio-zincato/10009913/) and those joints (http://www.ebay.it/itm/221474536259?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649) to link structure and motor? Would it be weak in your opinion?
    Second question relates to Hbridge. I'm thinking to build my own Hbridge capable of driving the ZYT90 motors with 25:1 gearbox. Does anyone have tried to do the same?
    Thanks in advance
    Marco:thumbs
    153,728Coins
  16. RacingMat
    21,081Coins
    hello Marco
    M12 rod should be fine! Is it a shoulder mounted setup? or feet mounted setup?
    my 2DOF shoulder mouinted was Ø12 (but not threaded)
    For the unijoint, you have to check if their angulation meets the angulation needed by your sim.
    Ebay didn't specify the angulation...
  17. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    Thanks a lot noorbeast and RacingMat!
    Pit's idea is absolutely smart! I'll go with it to give power to those hungry ZYT90 motors!
    Regarding unijoints, mine is a shoulder mounted setup. Sorry Mat I cannot understand which angulation you mean. Would you mind to indicate me which one is it?
    At the moment my Sim hasn't any definitive solution to place and hold the motors.
  18. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    Again thanks to everybody spending their time to give me help.
    I hope to be able to share my acquired knowledge in the near future.
    Well, long story short, during this week (and wainting for next week WRC!) I will be trying my actual setup.
    Unfortunately I haven't bought new motors so I'm using that old and slow motors I already had.
    Here's the point: sometimes (especially with more reactive cars in Assetto Corsa) during hard and fast changes of direction the (I suppose) motomonster cuts the current supply to motors. At about 0:55 of this video () you can see what I mean..a strange sound (like tack tack) and then a fan (from the PSU) increases its RPMs, like it is going to protection mode or so.
    What seems strange to me is that I've stacked two MM for each motor and I'm just using a 5cm CTC lever.
    Is this behaviour just related to my actual loved up motors?
    What's your opinion?
    Thanks in advance
    Marco:cheers
    153,728Coins
    Design wise your pivot point is well below the seat and on a full frame that means the distance between the two becomes a lever once the seat moves past perpendicular. On a full frame that adds a lot of strain on the motors and the greater the axis movement the more the negative effect.
    Can you confirm if the rig was balanced with all peripherals and yourself on board?
    There seem to be additional holes in the motor lever, what is the shortest CTC and have you tried it?
  20. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    Thanks noorbeast! yes I can confirm I've carefully checked the balance with me myself on board and the peripherals.
    However, as far as my simulator is adjustable in lenght and it is thought to be used by many, the pivotal position couldn't be always that precise.
    That said, this strange behavior has happened (more or less) in all the CTC positions, including the shortest, 3.5 cm.
    At the moment and in the video, the CTC is 5cm.
    Another strange condition that makes me think about faulty motors is that the left motor isn't capable of holding the weight as the right is.
    I can manually move the left motor arm but I cannot absolutely do the same with the right one.
    And the two motors are supposed to be identical.
