3DOF for the Motion Flight Simulator
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by hunijjang, Feb 2, 2015.
  1. noorbeast
    153,758Coins
    Perhaps if you do a sketch of where the parts go. The rod ends I understand. I am not sure how you plan to use the harden tapped shafts and pillow block.
  2. hunijjang
    hunijjang She is my wife :) Gold Contributor
    Operator
    Seoul, Korea
    1,164Coins
    Hello, noorbeast.
    because, my plan files very terrible. :) as you know that is not the details.
    I'll be update my plans again, by today or by tomorrow.
    and I want make for the sizes, horizon size : 1.4m, vertical size : 1.2m, aluminium plates for both board.
    by the way, I will order motor x 3 in today and also for aluminium plates.
    https://www.motiondynamics.com.au/worm-drive-motor-12v-24v-200w-180-rpm-20nm-torque.html
    or
    https://www.motiondynamics.com.au/1...ve-geared-motor-200w-21-256-rpm-7.5-45nm.html
    also, Could you recommended power supply for those motor? ;)
    153,758Coins
    If the motors are going to have limited leverage, like my sim, then you want either 50 or 60:1 gearboxes, which are numbers 11 or 15 in the chart on this page: https://www.motiondynamics.com.au/1...ve-geared-motor-200w-21-256-rpm-7.5-45nm.html
    HP server PSUs are cheap on Ebay, powerful and easy to mod for motion simulator use, here is a tutorial by @Slider: http://www.xsimulator.net/community/threads/how-to-modify-a-server-power-supply-for-12v.5774/
    Again it would be good to see a plan before you order anything, that way community members can give you proper advice. It does not matter if the plan is just a photo of a hand drwn picture, as long as it is clear about what you would like to build.
  4. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    Hello, noorbeast.
    yes and I keep the asked for advise.
    by the way, I will some testing in the tomorrow.
    I just orderd for 3 x 47:1 metal gear motor(120 rpm, toque 50 oz-in stall is 2.2A) and potentiometers(several different types : 9 pcs) and etcs, because, I want to be some testing thats before making the actual scale size.
    Thanks again advised. :)
  5. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    noorbeast, How about this motor? I found this on ebay.
    http://www.ebay.com/itm/SWF-VALEO-N...-DC-/400605321964?pt=Tore&hash=item5d45f01aec
    Rated Torque 8Nm to 16Nm is great and price me. because I needs to 3 x motors. :rolleyes:
    153,758Coins
    Those motors have been used before for motion sim building, however the best choice of motor really depends on knowing the rig designs and dimensions. I know I keep saying it but your really should do a design sketch and post it here, so that members can then know what to advise on what may or may not work best.
  7. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    Hello, noorbeast.
    you will understand better than my drawing picture or such as making like powerpoint program, What I want platforms design.
    however, my plafform is differences weight and sizes also motors.
    1.4m x 1.2m box and about 50cm heights also expecting to the max payload is 150kgs.
    both, youtube is 3dof and pitch roll and heave.
    Thanks many advised to me. :)
    153,758Coins
  9. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    Hello, @noorbeast.
    Sure, already, I checked it and as I told to you it is great.
    as you know he is 95% done.
    I just fowarding it working video. ;)
    also, In thisweek, I will testing for about 1/10 scale(What I want be my platform) then I'll stating post in the DIY Motion Siulator Projects board. :)
    by the way, there is 3 o'clock 17min at AM :D
    go to sleep, it is too late :)
    Thanks again for advsied and kindness. :cheers
  10. Jugle
    Jugle New Member
    Bored Witless
    Bairnsdale, Victoria, Australia
    43Coins
    DC motor, JRK, Joyrider
  11. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
  12. bsft
    @hunijjang , Id say he has one motor for each.
    Look at the BFF link and you can see how he has copied the motor lever design.
  13. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    Hello, bsft. :)
    You gave me the first time you put a comment in my post.
    Thanks and I found this video
    also, already I checked the links and but there is maybe mixed designs joyrider + bffs motor chain gear designs.
    but I didn't see that(like : Jugles motion platform) working on x-plane.
    Best Regards,
    hunijjang
  14. bsft
    The BFF design for a flight frame is not a joyrider, but the chain/motor idea can be adapted to it.
    @Pit , I recall you did a similar chain/motor setup for your seat mover?
  15. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    Hello, bsft.
    sure, I known and basically designs by acesim corrrect? and yes, chain/motor designs for BFF. ;)
  16. bsft
    yes and yes
  17. Pit
    30,510Coins
    My chains are only driving the pots, so my winches are direct driving. @value1 build a chain driven joyrider.
  18. bsft
    Ah ha! thanks, I knew someone had done it
  19. Jugle
    Jugle New Member
    Bored Witless
    43Coins
    I'll post a video and some images that detail the motor and pushrod connections shortly... sorry, sim is in my office at work, no space at home!
  20. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    Hello, Jugle. :)
    That is no problems sir.
    your so kindness. ;)
    by the way, maybe those sim is in the your office at work, usually no one can imagine in the South Korea. :grin
    at least where I work is impossible it.
    I envy you a lot. :thumbs
    I have a question to you, what are you using the motor? :D
    Thanks a lot, Jugle.
