sequential shifter house
Discussion in 'DIY peripherals' started by zigzag49, Feb 21, 2015.
  1. zigzag49
    zigzag49 Active Member
    723Coins
    Good Morning
    I will present a sequential shifter that I make there a while, now it is no longer used as a box H / sequence is in progress.
    Initially the joystick buttons (sears) have been used but there was a malfunction on the report went wrong suddenly have the simple switch replacement with at Smallcab card.
    The little mechanism system can be interesting, here are the photos.
    Here after the change of the buttons by addition of contacts and the card.
    • Creative Creative x 2
  2. bsft
    Great job and thanks for the photos. You can certainly wood work better than me.
  3. bsft
    How did you put the paddles on the DFGT?
  4. zigzag49
    723Coins
    I think you're talking about this.
    The gates have been directly welded to the platinum T500RS at the outlet of the pallets.
    Connect like this with a RJ45 cable.
    ps:a big thank you for your gift :cheers
  5. Daguru
    Kitchen installer
    Wales uk
    461Coins
    Motion platform
    Nice I do love a bit of wood work thanks for sharing :thumbs
  6. zigzag49
    723Coins
    Thanks daguru.
  7. Scratch
    Scratch Active Member
    281Coins
    Nice! And beautiful case you have built!
  8. leaedman
    leaedman Active Member
    Valenciennes, France
    470Coins
    Great job zigzag49 ! Congrats :thumbs
  9. zigzag49
    723Coins
    hi
    leaederman thank you
    A dding a video showing the operation of the mechanism, it no lever stop, it should not be proud that it has run.
    [ytv]Y4Am1UGNeoc[/ytv]
    152,069Coins
    +11,065 / 56 / -2
    Sorry @zigzag49 but the video url is messed up and hence does not work.
  11. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,796Coins
    Corrected link:
  12. leaedman
    470Coins
    C'est mieux :grin Thank you :D
  13. zigzag49
    723Coins
    Arff !!! Not wake up this morning. Thank you
  14. Luc1gnol0
    Luc1gnol0 New Member
    Itala, Italy
    246Coins
  15. Nath Older
    Nath Older Member
    Laboratory Supervisor
    United Kingdom
    271Coins
    Great work, thanks for the photos, makes it so much easier to help make my own, thanks
  16. zigzag49
    723Coins
    thank you, it's a pleasure.
