2 DOF arduino , sabertooth , moteur essui glace 24v
Discussion in 'DIY Motion Simulator Projects' started by zigzag49, Feb 16, 2015.
  1. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    Nice movement :thumbs
    I myself, would probably ease up on the braking force - but this is only a personal preference what I usually do, like to feel more of acceleration but a bit less of braking force, not hard. It's something to play with in the Tuning Center, after capturing min/max values, I'm writing out different values of Min/Max for Surge force to balance braking and acceleration. You just need to find out which value represent braking and which acceleration (Min or Max) and test it out..
    Here it is for Project Cars in example, the bigger the number you put - the less force you will feel. The "Max" value in pCars was for braking so I've put a bigger number for less feeling..
    And in Dirt3 for example the "Min" value represented braking force so I've put bigger number there..
    Each game has it's own values, each car, each airplane.. It's all about personal taste and a lot of testing, testing, testing :sos :grin
  2. leaedman
    leaedman Active Member
    Valenciennes, France
    470Coins
    The effects are not too strong? Personally I put the values +3 and -5 with value 8 for smoothing but we do not have the same facility :confused:
    (Les effets ne sont pas trop fort ? Personnellement j'ai mis les valeurs +3 et -5 avec la valeur 8 pour le smoothing mais nous n'avons pas la même installation)
  3. bsft
    he did say its personal taste when it comes to tuning centre numbers and how the profile feels
  4. zigzag49
    zigzag49 Active Member
    726Coins
    Thank you prodige, that's exactly what I did, increase the minimum value for me and feel less braking compared to the acceleration.
    Leaedman Although the effects are too strong, I exaggerate to see the felt.
    "Merci prodige, c'est exactement ce que j'ai fait ,augmenter la valeur min pour moi et moins ressentir le freinage par rapport a l’accélération.
    @leaedman bien sur les effets sont trop fort,j'ai exagérer pour voir le ressenti."
  5. zigzag49
    726Coins
    153,884Coins
    +11,154 / 57 / -2
  7. leaedman
    470Coins
    Cool ! Very nice :thumbs
  8. zigzag49
    726Coins
    Thanks you
  9. zigzag49
    726Coins
    Video of all 5 effects
    sway
    surge
    pitch
    roll
    heave
  10. zigzag49
    726Coins
  11. Fabgen
    Fabgen Member
    575Coins
    Nice job and maybe lot off time fun on playing
  12. Cataron
    Cataron Member
    305Coins
    I love your building zigzag, very impressive.
    Where did you find the fans for the motors, I'm thinking about getting some for mine
  13. RacingMat
    21,082Coins
    They are Smoka NIDEC 24V truck wiper motors (link in the tuto in my signature)
  14. zigzag49
    726Coins
    Hi Thank you, the motors are wiper motors heavyweight, I recovered they had a lot of hours, his must be the same as the smolka give link racingmat.
  15. Cataron
    Cataron Member
    305Coins
    Thanks guys
