RFR steering wheel - direct drive by RacingMat
Discussion in 'Direct Drive Wheels' started by RacingMat, Feb 7, 2015.
  1. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    awesome tuto racingmat. I am on the second batch of the accuforce (unfortunatly or maybe not... ) :)
  2. kopper
    kopper Member
    Kansas
    3,343Coins
    Man, there is a LOT of terminology in this thread that I completely do not understand. Something tells me I may someday though since cool projects like this are like crack to me. Let me know when you guys get it all figured out - haha!
  3. RacingMat
    21,059Coins
  4. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    looks like the IONO will be around 200 USD....looks like a PIC-E board....do you know @RacingMat if its supposed to have something it plugs into? Im trying to decide on the IONI for the VSD-E. IONI is less expensive but looks to need more bits to put it all together....Im also leaning towards the tutorials...im good with pictures and instructions....and I know the IONI wont have much of that for a while.
  5. RacingMat
    21,059Coins
    Connector is standard PCI-E 8X ;)
    Yes of course, no tutorial on Ioni yet...
  6. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    But where do you connect the motor? From the picture of IONI it seems it doesn't have any connectors?
    It looks to me one will need that IONICUBE motherboard too, with connectors for motors and connect to PC.. Using only one board as one axis (one motor) to control?
  7. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Right, that does 4 though. I didnt know if I could just use the pc or would need a brekout board like the one above...then Im thinking about how you would send power to this thing,..woudl I need wires hanging out the back of my pc?
  8. RacingMat
    21,059Coins
    I think you should avoid to use this into a computer...
    Use it with a socket: you gather some pins for power supply and use some other pins to encoder reading and communication with Disco or Core.
    Just like VSD
  9. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    The only pics I see are those on the board that would fit in the pci slot....doesnt feel like a good solution to get stable power in. I think I am back to leaning against the Argon.....just looked at the schematics...o crap....im scared im going to blow up something expensive
  10. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Does this require a 220 volt outlet?
  11. Bobsyouruncle187
    Bobsyouruncle187 New Member
    71Coins
    2DOF, DC motor, AC motor, SCN6
    @RacingMat
    Firstly, thank you and the whole sim community for the wealth of information you guys have provided! Can't wait to jump in and build.
    Would I be correct in understanding that -
    The STM board CORE407V is used to directly wire up buttons too - so in essence a DIY shifter and pedal (mixture of buttons and pots) could all be hooked to this board along with the servo driver.
    Thanks again! (and the rest of you guys!)
  12. RacingMat
    21,059Coins
    @Bobsyouruncle187
    yep! you can wire pedals, shifter and button box with the disco or core :)
    shifter in H mode is possible with the firmware as it uses 2 pots.
  13. RacingMat
    21,059Coins
    news on Granite Device Facebook :
    The final IONI drives are here and alive! Sales can begin the next week. Stay tuned for introductory IONI Pro campaign!
  14. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    I grew impatient and figure there will be time needed for configurations and firmware so I just bought the Argon. All Parts should be here by next week.....did I really just Pay this much for a FFB WHeel?.....yup....I really hope its worth the hype...I believe! I believe!
    • Optimistic Optimistic x 1
  15. Pit
    30,497Coins
    @shannonb1 my optimistic button should be not negative the direct drive wheel is on my whish and I hope to see you succeed at least.
  16. Swinny290925
    Swinny290925 New Member
    Uk
    110Coins
    2DOF, SCN5
    thankyou very much for posting this,a new project me thinks :)
  17. RacingMat
    21,059Coins
    Do you make any difference between a toy and a car?
  18. Swinny290925
    Uk
    110Coins
    2DOF, SCN5
    It's getting a thinner line :)
  19. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    So remember when @RacingMat shared his STL file for a 3d print.....I didnt have a 3d Printer.....well I bought one for that....and other stuff too, but mostly for that...and now I started the mods...ordered rasberry pi 2, 7"Touch Lcd Screen and Im building out an L angle aluminum case with PLexi to store it in and I have some saucy blue led lights to fancy it up......next stage will be adding a secondary extruter and upgrading the primary that came on it. Where there is a will there is a way.......and finally have shipping info from Granite and the Argon should be here end of week and the discovery breakout board is on the way too...oh exciting times.
  20. kopper
    kopper Member
    Kansas
    3,343Coins
    And I thought I had a lot of "toys"! -haha
