DIY 2DOF
Discussion in 'DIY Motion Simulator Projects' started by Daguru, Dec 12, 2014.
  1. Daguru
    Kitchen installer
    Wales uk
    461Coins
    Motion platform
    Hi guys,
    Just starting on the electronics going to run SMC3 with 2 x MMs I have 2 x HP DPS600 server power supply's the 12v line runs at 47A and the motors I have are 23A is it ok to just power both MM/motors with 1 PSU? Or should I use the both PSU's one for each MM/Motor ?
    Regards
    Dag
  2. Pit
    30,490Coins
  3. Daguru
    Kitchen installer
    Wales uk
    461Coins
    Motion platform
    @Pit Thank you Sir :thumbs
  4. Daguru
    Kitchen installer
    Wales uk
    461Coins
    Motion platform
    Still not had much time for this project just getting bits done here and there.
    got a couple of pics nothing major just small update.
    first pic of motor was going to use
    new motors
    these are monster motors lol side by side
    I have seen people say they cant believe the size of these worm drive motors well WOW !! is all I can say.
  5. Daguru
    Kitchen installer
    Wales uk
    461Coins
    Motion platform
    Got my flexi couplers
    jumper wires
    ball joints with threaded bar joiners to slide into the tube for welding
    and cant forget the heat shrink makes a normal wire job look pro lol
    152,069Coins
    +11,065 / 56 / -2
    The new motors are in a whole different league @Daguru. What ratio are the gearboxes?
    Have you settled on a design for your sim, shoulder mount seat shaker, full frame or something else?
  7. Daguru
    Kitchen installer
    Wales uk
    461Coins
    Motion platform
    @noorbeast i have changed my mind so many times but now I think I'm going for shoulder mount seat mover which is going to be a cut and re weld of my static rig and as for gearbox ratio I have a choice the ones in the pic is 60:1 and some second hand 50:1 came up on eBay so I grabbed them also :grin
    152,069Coins
    +11,065 / 56 / -2
    There are plenty of good examples of member shoulder mount designs to follow. By the sounds of how many motors you have you could could consider adding traction loss as part of the build, or at some later time as an addition.
  9. Daguru
    Kitchen installer
    Wales uk
    461Coins
    Motion platform
    Yes @noorbeast traction loss is a future plan, im going to mod my static rig just because of the lack of time i have right now but i do plan a full 3DOF maybe for the summer:)
  10. zigzag49
    zigzag49 Active Member
    723Coins
    There is a big difference in size between the two engines, one does not believe like that. The gear reducer is what the matter?
  11. Scratch
    Scratch Active Member
    281Coins
    Good picture comparing the motors, omg! :eek: "My Mommy always said there were no monsters, no real ones... But there are" -Newt
    • Funny Funny x 2
  12. Daguru
    Kitchen installer
    Wales uk
    461Coins
    Motion platform
    Does anyone know if these motors be taken apart and swap the handing of the gearbox ?
    I have two the same hand and want to make a pair
    cheers in advance
  13. noorbeast
    152,069Coins
    +11,065 / 56 / -2
  14. Daguru
    Kitchen installer
    Wales uk
    461Coins
    Motion platform
    Thank you @noorbeast I will split the box and see if it can be done and post some pictures of my findings :)
  15. Daguru
    Kitchen installer
    Wales uk
    461Coins
    Motion platform
    Thanks again @noorbeast gearbox hand swap was a great success:grin
    split the box
    press out the shaft and bearing
    cleaned and re greased
    pressed back together job done :cheers
  16. RacingMat
    21,050Coins
    well done! nice pics!
    i'm surprised it's nylon made... but it has been proven to be solid, no?
  17. Daguru
    Kitchen installer
    Wales uk
    461Coins
    Motion platform
    Not used it under load yet just tested on the bench (I picked these up cheap off eBay ) so had no choice with what hand they were .
    So I have 2 pairs of motors 1 pair of 60:1 and 1 pair of 50:1 which set should I run with on a shoulder mount seat mover I'm about 200lbs (90 kg) ?
    Thanks in advance
  18. noorbeast
    152,069Coins
    +11,065 / 56 / -2
    Either would work fine.
  19. Daguru
    Kitchen installer
    Wales uk
    461Coins
    Motion platform
    Cool thanks
  20. Daguru
    Kitchen installer
    Wales uk
    461Coins
    Motion platform
