RFR steering wheel - direct drive by RacingMat
Discussion in 'Direct Drive Wheels' started by RacingMat, Feb 7, 2015.
  1. RacingMat
    21,006Coins
    Nice! what is the printer's name?
  2. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Lol...right now its POS because the firmware is jacked up lol. Im working to get it fixed.
  3. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Sending that thing back. Its a pain in the arse.
    So i ordered this...
  4. telfel
    telfel Active Member
    4,738Coins
  5. RacingMat
    21,006Coins
    @telfel : I know that STM32F401 does not work
    and that only STM32F407 works
    Nucleo is STM32F401 and STM32F411 I bet it would not work... but only MMos coudl answer to you
    Why are you looking at this references? Do you have one? Are they much cheaper?
  6. telfel
    4,738Coins
  7. RacingMat
    21,006Coins
    Hi!
    The driver you linked cost 300$... the IONI from Granite Device will be much more cheaper!
    About motor, the torque 20N.m is fine.
    You have to check the inertia: if it's over MIGE's, it's not worthy... I haven't see this information on http://www.leadshine.com
  8. ericRacer
    Pilot
    Canada, Quebec
    949Coins
    @RacingMat
    Very good idea to put a tutorial here to benefit more people.
    Can you help me how to use the API BBerger. Since I have my DD servo wheel I find the FFB of AC a bit unrealistic (spring effect too strong) and I think the BBerger API uses telemetry and should be more realistic.
    I wonder if I need to change the firmware of my discovery ?
    I also know that I need to add a plugin.
    Does it only works with argon or it works with VSD-Xe too ?
    thank you
    Eric
    http://www.assettocorsa.net/forum/index.php?threads/self-aligning-torque-sat-why-so-high.19485/
  9. RacingMat
    21,006Coins
    hello @ericRacer
    As I have no experience about BBerger API, I cannot advise you... sorry
    Argon and VSD are only the driver which drives the motor: the API deals with the USB board. It should work in both setups.
    You should ask him on his dedicated topic: http://www.xsimulator.net/community/posts/69321/
  10. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
  11. Bobsyouruncle187
    Bobsyouruncle187 New Member
    71Coins
    2DOF, DC motor, AC motor, SCN6
    Any idea if the pro is better suited or the standard ioni is enough? @shannonb1
  12. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Not certain. But I would go pro for the resolution and the encoder rate. The indi project will get you the pro for less then the standard. I think the standard is good for CNC milling but not an expert.
    comparison
    http://granitedevices.com/wiki/IONI_vs_IONI_Pro
    FeatureIONIIONI Pro
    Max encoder count rate0-4 MHz0-18 MHz
    Encoder resolution100-65535 P/R100-15000000 P/R
    Pulse/dir setpoint frequency0-4 MHz0-8 MHz
    Quadrature setpoint frequency0-1 MHz0-2 MHz
  13. Bobsyouruncle187
    71Coins
    Thanks, took the safe option and went for the pro.
  14. ericRacer
    Pilot
    Canada, Quebec
    949Coins
  15. slingshot
    slingshot New Member
    478Coins
    Hi Racing Mat,
    I have been following this project on iRacing with the Argon.
    I have just made a deal for a VSD-E and I already have the small mige and disco.
    Is your wiring diagram between the VSD-E and the Disco for the same disco that I have attached a pic?
    Also the breakout board that you have on the 25 pin connector. Where did you purchase that?
    Thanks,
    Joe
  16. RacingMat
    21,006Coins
    @slingshot you bought a Disco
    (I recommand a Core because it's simplier: only 1 cable)
    but Disco is fine and here is wiring diagram!
  17. slingshot
    478Coins
    Hi RacingMat,
    Yes I already had bought the Disco for the Argon or the IONI.
    The VSD-e control project ended up happening before the others!
    Thanks for your quick response!
    Joe
  18. RacingMat
    21,006Coins
    hello!
    yes, pinout is different but pins serve the same function
  19. Rkulp89
    Rkulp89 New Member
    240Coins
    Does the servo motor require 220VAC? If so, what if any options are available for 120VAC?
  20. RacingMat
    21,006Coins
    The servo motors require tri-phases power supply.
    This is given by the driver:
    - VSD or IONI
    The driver itself is supplied in 48v DC
    - argon (in 230v)
    If you choose IONI you have to find a 120v PSU. It should be the cheapest.
    If you want to go argon way, maybe check in its spécifications if it can be supplied in 120v
    Yours
    Mat
