VM110 wireing?
Discussion in 'SimTools compatible interfaces' started by 94za4, Jan 27, 2007.
  1. 94za4
    94za4 New Member
    0Coins
    I just got my RnR and the VM110 card in. I have tested the RNR wusing the serial connection, now I would like to try to hook up the VM110. I am not clear on how to wire it, the VM110 has 8 input ports, but I count 16 wires to the original board, is one a common ground? I am not real clear on the schematic. If anyone can give me any details it would be helpfull.
    Andrew
  2. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    Ich glaube ihn verwirrt, dass er 8 Anschlüsse an der VM110 hat, aber 16 Kabel;
    Er weiss nicht, was er mit den übrigbleibenden 8 Kabeln anfangen soll.
    Ich habe solch eine Karte nicht, aber ich denke mal, dass jedes Ventil zwei Kabel hat; Also Plus und Minus.
    Werden die Minus Kabel vielleicht an einem Anschluss an der Karte gebündelt?
  3. 94za4
    94za4 New Member
    0Coins
    You got it egoexpress, I am not sure if they all have a common ground or what. I am also confused by the drawing, maybe it because of the German language, but I just cant seem to make hed or tails of it.
    Also, is the VM110 powered only bey the USB, or do you need to hook power in to it as well?
  4. egoexpress
    421Coins
    Please wait for Renoboss's reply; I'm not familiar with this board
  5. 94za4
    94za4 New Member
    0Coins
    OK, I think I am close. I now get the card to respond with lights. When I enable the Profiler and Sender I can see that it is sending data to the board and out, the output lights light up when I move the stick. The chair still does not move though, and I am not sure why. I have the original RnR power supplu hooked up to the clamp terminal with a 1N4007 diode in line. I have the negitive going to the ground' right next to it, also this is where the second wire from the actuators goes as well. Is this correct or did I hook it up wrong. Like I said, the card does respond, but the chair does not move.
    Andrew
  6. 94za4
    94za4 New Member
    0Coins
    OK, I will give that a try. I am sorry for all the confusion on my part. The Germa to English translation is iffy at best. Most of the time it makes no sense whatsoever. I have read and re-read, but most of it still does not make a lot of sense.
    Andrew
  7. 94za4
    94za4 New Member
    0Coins
    OK, I got it working!!!! One quick question. When pitchi9ng forward it pulses only, not a steady rush of air like full deflection on the other axis. Is tis normal, can it be changed? I would like quicker response time to forward movement.
    Andrew
  8. egoexpress
    421Coins
    Congratulations! You havent destroyed the valves :mrgreen:
    Its because the forward movents normally go faster because of the weight of the monitor. I assume you have a TFT.
    I think there is a way to change that, but dont know how
  9. 94za4
    94za4 New Member
    0Coins
    Yes, I have a flat pannel on there. Maybe I can add some weight someplace so it moves a little faster.
    Also, if I try my larger compressor at 3-4 bars, will that make it move faster?
  10. Nima
    Nima Member Gold Contributor
    Glaser
    Bad Zwischenahn
    531Coins
    hallo
    ich würde ein zusatz gewicht unter den monitor setzen. bei mir habe ich ohne monitor 10 -12 kg dazugenommen.ohne steht er in der null position zu hoch.
