JRK reset switch.
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Archie, Mar 13, 2015.
  1. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    I am not sure if this will be of any use to anyone, but with the way my rig is setup I can't really see what the JRK's are doing and I also can't reach my USB cables easily to unplug and reset them if anything happens to my motors / JRK board etc once I am seated in my Sim.
    I made this simple switch box to show me when the JRK's are plugged into the USB and when power is present at the motors. It also has a toggle switch to reset the JRK's which, to the PC, appears as a USB unplug/plug. It filled a need I had, so thought I would share.
    It's real simple wiring. Common ground for each JRK and then connect + of RED led to ERR pin, then + of GRN led to 5V pin. Connect Switch between GND and RESET. Job done.
    (You may need a resistor on your LED's depending on the make to stop them being so bright!)
    Note: The RESET just resets the USB bus, it does NOT factory default your JRK ;)
    I used ethernet cable as it has just enough wires.
    Some pics:
    Both JRKS connected to the PC, but no power to the motors.
    JRK in "RESET" mode. (USB unplug) - Left JRK
    JRK in "RESET" mode. (USB unplug) - Right JRK
    JRK running mode. Power to Motors all OK. (Red goes out)
    The RED will flicker while playing games if your get a motor driver error. If one fails (power to motor stops) the RED led comes on.
    Before this I've been happily playing on the sim, not realising one of the JRK's had wigged out.
    Now I hit my Sim killswitch, flick the two toggles and everything is reset to try again.
    • Like x 7
    • Winner x 6
    • Informative x 2
    • Agree x 1
    • Useful x 1
    • Creative x 1
  2. GIB SimRacing
    GIB SimRacing Active Member
    Barossa Valley, SA
    983Coins
    That is a very good idea. And very useful too!
    • Agree Agree x 3
  3. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    This is pure awesome :thumbs
    • Agree Agree x 4
  4. Archie
    Wollongong, NSW, AU
    3,797Coins
    @Nick Moxley asked me for a wiring diagram. It is very simple and excuse my scribble. But it might be useful to others.
  5. Archie
    Wollongong, NSW, AU
    3,797Coins
    I just used a toggle switch as that is what I had lying around, but a momentary N\O will do the same thing. It only needs to be "shorted" for a second or two.
    • Useful Useful x 2
  6. GIB SimRacing
    Barossa Valley, SA
    983Coins
    Top stuff @Archie - I'm sure many will find this very useful.
  7. Archie
    Wollongong, NSW, AU
    3,797Coins
  8. Nick Moxley
    Ive had at least one of those too, Contacted the gentlemen and we had a laugh about it. BUT its still there and has yet to be "undone" , Lol
  9. AceOfSpies
    AceOfSpies Living the Dream!
    Kilwinning, Scotland
    19,614Coins
    Hi @Archie thanks for bringing this to my attention. I have undone the tagging. I can only apologise as I was not aware that I had tagged his post at all! Let me put it down to a lack of awareness!
    Mike
  10. Archie
    Wollongong, NSW, AU
    3,797Coins
    Hey @AceOfSpies - No problem at all mate. I was reading the post and was scratching my head wondering what there was to disagree with, so figured it was something like that. :)
    By way of a "Thanks" - You can have this: http://goo.gl/b78sM3
    :D
  11. Archie
    Wollongong, NSW, AU
    3,797Coins
    Just an update on this. My wiring was awful and rushed, but never got around to making it pretty. It worked.. why mess with it...
    .. and then I realised an Old PC case front panel has everything you need for this project.
    Two old PC's later, I have push buttons and LED's already pre-wired with the connector's attached and JRK header pin ready!
    You may need to split the pins to make separate connectors for the JRK headers. (Red and White wire in this pic - The plastic cover came off the pin.)
    • Like Like x 5
  12. Kranky Pantz
    Kranky Pantz Active Member
    Canada, Eh!
    1,288Coins
    Brilliant!
    Love the informative feedback from the LED's.
    I'll be adding this to my setup ASAP!
