Projet 3 dof vertical selon willaupis
Discussion in 'DIY Motion Simulator Projects' started by hellpanzer, Mar 17, 2015.
  1. hellpanzer
    hellpanzer Member
    93Coins
    3DOF, DC motor
    Salut je voudrai partager mon projet 3dof selon willaupis
  2. hellpanzer
    hellpanzer Member
    93Coins
    3DOF, DC motor
    voici ma structure
  3. hellpanzer
    hellpanzer Member
    93Coins
    3DOF, DC motor
    pose des support moteurs
  4. hellpanzer
    hellpanzer Member
    93Coins
    3DOF, DC motor
    Les bielle qui seront utiliser
  5. hellpanzer
    hellpanzer Member
    93Coins
    3DOF, DC motor
    Mise en place de l arudino et sabertooth et alim 24v
  6. hellpanzer
    hellpanzer Member
    93Coins
    3DOF, DC motor
    Potard utiliser
  7. hellpanzer
    hellpanzer Member
    93Coins
    3DOF, DC motor
    Test de position du support mobile
    • Creative Creative x 3
  8. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
    Nice concept.
    Nice thought to keep your wooden support suspended.
    It woud not be stable at all if you had placed your wooden support over the motors.
    You still have to expect some unwanted twist though.
    To be more clear ... when you conect all four rods ... just try to move the wooden support and you will notice some sideways movement.
    As it is not clear in your pictures ... will you use only one power suply unit for all four motors?
  9. RacingMat
    21,040Coins
    Super ! ça a l'air très propre et costaud
    merci pour les photos
  10. hellpanzer
    hellpanzer Member
    93Coins
    3DOF, DC motor
    Jai les condensateur d un moteur quo a cramer .je vais les changer par des condensateur equivalent
  11. hellpanzer
    hellpanzer Member
    93Coins
    3DOF, DC motor
    Voila les condensateur d un moteur neuf
    Ce sont des 1u f. 63vcc
  12. Cataron
    Cataron Member
    305Coins
    Tiens je vais suivre ta construction, hâte de voir le final, ça commence très bien en tout cas
  13. hellpanzer
    hellpanzer Member
    93Coins
    3DOF, DC motor
    L'idee de ce 3dof vertical sans cardan viens de willaupis , j ai suivi son tuto sur le fofo de Pcshm
  14. hellpanzer
    hellpanzer Member
    93Coins
    3DOF, DC motor
    Pour la rigiditer de l ensemble je verrai a la fin
  15. hellpanzer
    hellpanzer Member
    93Coins
    3DOF, DC motor
    Voici quelque photo de l alim sabertooth et arduino
  16. hellpanzer
    hellpanzer Member
    93Coins
    3DOF, DC motor
    Donc les moteurs sont des smolka 24v 16Nm 48tours\m je les aient mis sur equerre renforcer mais biensur a revoir la rigiditer en soudant des angles
  17. hellpanzer
    hellpanzer Member
    93Coins
    3DOF, DC motor
    J ai acheter ce kit complet grace a l idee des menbres du fofo Pcshm (wanegain ,willaupis et d autres) qui fournisse toute la partie moteur et carte a un prix interressant
  18. hellpanzer
    hellpanzer Member
    93Coins
    3DOF, DC motor
    Jai fais un test simtools sur gtr 2 et utiliser virtual axis a l arret de la voiture les axes s affole comment faire pour evitet ca
    151,504Coins
    +11,041 / 56 / -2
    I am not sure if you mean you are having problems with SimTools settings or not, as Google translate was not clear. If you are then please post some pictures of all of your settings and members will help you get it working.
    Je ne sais pas si vous voulez dire que vous rencontrez des problèmes avec les réglages de SimTools ou non, que Google translate ne était pas clair. Si vous êtes alors se il vous plaît poster quelques photos de tous vos paramètres et les membres vous aidera à le faire fonctionner.
  20. Cataron
    Cataron Member
    305Coins
    Je sais, j'y suis également ;)
