just another 2dof 2 motomonster seat...
Discussion in 'DIY Motion Simulator Projects' started by Piilukirves, Mar 18, 2015.
  1. Piilukirves
    Piilukirves Member
    Laukaa
    288Coins
    Hi!
    Here is my way to 2dof...
    Arduino uno R3
    2x motomonster
    2x 1:50 180W wormgear
    Sparco evo II
    logitech G27
    @RacingMat preset
    @RacingMat Ultrasonic PWM
    http://www.xsimulator.net/community/marketplace/ultrasonic-pwm-with-arduino.102/
    Overallview of my messy carage.
    motors and connection rods (60mm arms)
    old quad Battery to prevent my modified ATX power to shutdown
    modified atx power , gives +40Amp no sweat...
    Arduino uno and motomonsters under the overkill cooler...
    Link to video.
    https://www.dropbox.com/s/agng3aro3gou15v/VIDEO0037.mp4?dl=0
    PWM at 155
    Its still kinda crude but going to polish it ...
    Sorry for bad English...
    151,979Coins
    +11,061 / 56 / -2
    Nice job there @Piilukirves, thanks for sharing the details and photos of your motion simulator.
    If you get the chance members here would really appreciate a video of your motion simulator in action.
    No need to apologise, your English is just fine.
  3. bsft
    joined today, has only 40 coins, has simtools displaying on the computer, need 250 coins to get simtools and plugins, hasnt bought gold membership......interesting.......
  4. Piilukirves
    Piilukirves Member
    Laukaa
    288Coins
    LFS plugin is in simtools and simtools only 10coins...
  5. Piilukirves
    Piilukirves Member
    Laukaa
    288Coins
    Added video...
  6. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
    you should switch to ultrasonic pwm arduino code.
    then the motors are very quiet.
  7. Piilukirves
    Piilukirves Member
    Laukaa
    288Coins
    I realy need to look for that, Thanks
    other thing that anoys me is that center drift/constant correction of center position.
  8. Pit
    30,490Coins
    Where do I find this code? Thanks.
    151,979Coins
    +11,061 / 56 / -2
  10. RacingMat
    21,047Coins
    @Piilukirves : you're riding your simulator! congrats!!
    Well done
    @noorbeast : you're as fast as ultrasonic PWM!
    @Pit : I wrote this code to allow the Arduino to send 20kHz PWM (instead poor standard 490Hz PWM)
    hence the motors are really quieter (I made a comparison video in the post)
  11. Piilukirves
    Piilukirves Member
    Laukaa
    288Coins
    Upgraded to ultrasonic, I like it :D a Lot.
    Still problem with constant correction on straights, bad CG?
    151,979Coins
    +11,061 / 56 / -2
    Can you post a video of your sim in action, it would help to better understand what you are trying to describe.
    Did you find the CG with yourself and all peripheral included, like this:
  13. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    Could also be the way you have mounted the potentiometers, try not to have them too far out on the shaft. You would also need to reinforce the bracket that the potentiometers are mounted on.
    It looks like they could have a bit of flex. Maybe take a video of the potentiometers while you are playing and see if they have any unwanted movement.
  14. Piilukirves
    Piilukirves Member
    Laukaa
    288Coins
    151,979Coins
    +11,061 / 56 / -2
    Can you please describe how you came to the CG settings you are using.
    Have you tried it on the smaller CTC lever setting?
    Can you post your SimTools and Tuning Center settings, particularly for heave.
  16. Piilukirves
    Piilukirves Member
    Laukaa
    288Coins
    i did that pipe trick for CG.
    I made my rods littlebit longer and it helped alot so i think im back heavy...
    i try with 40mm arms leght now...
  17. Roy
    Roy Member
    Marine Engineer
    Saint John, New Brunswick, Canada
    1,142Coins
    I see you have a PC power supply, with all the 12v lines joined together as well as the grounds. Are you using the pwr supply to charge the battery...and the battery to pwr everything else.
  18. Roy
    Roy Member
    Marine Engineer
    1,142Coins
    One other thing, the motors that you have, how do you like them. Friend of mine wants to use wiper motors to build a full sim but unsure if they would stand up. Where is your pivot point under the seat, it looks farther front then it should be?? From what I read, it should be in the center of the seat....??
  19. Piilukirves
    Piilukirves Member
    Laukaa
    288Coins
    Only meaning of the Battery is to keep ATX powersuply up and running , they tempto shutdown when current goes near to zero...
    4lines of atx is in series (not recommended)...
  20. Piilukirves
    Piilukirves Member
    Laukaa
    288Coins
    I dont hawe any opinion about my motors , newer seen wiper sim...
    but they are strong.
    Pivotpoint depends very muts how heavy is it build...
