3DOF for the Motion Flight Simulator
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by hunijjang, Feb 2, 2015.
  1. Jugle
    Jugle New Member
    Bored Witless
    Bairnsdale, Victoria, Australia
    43Coins
    DC motor, JRK, Joyrider
    Hi hunnijang, motors are DC gear motors I purchased here in Australia. I'm trying to remember where I got them, will let you know when I find the receipt. :)
    Meanwhile, I have posted more details of my build here:
    http://www.xsimulator.net/community/threads/jugles-flightsim.6470/#post-71641
  2. hunijjang
    hunijjang She is my wife :) Gold Contributor
    Operator
    Seoul, Korea
    1,164Coins
    Hello, Jugle. :)
    Thanks so much to you.
    always, you was kindness to me.
    Thanks again. :D
  3. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    Hello all. :)
    @noorbeast How are you today?
    Can I ask something? ;)
    Cloud you recommend to Hall Sensor for the JRK 12v12?
    News, Universal Joint with Spring is manufacture completion, made by from Joint manufacturer and Spring manufacturer. :cheers
    153,746Coins
  5. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    153,746Coins
  7. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    Hello, @noorbeast Thank you and How do you think about this frame working with 2 seats, 3x 12 250w motor?
    maybe, I don't think it always use to be with the 2 seats. :)
    just sometimes... ;) I am not a very fat but I want to lose some of my belly fat. anyway, I need to check it for my weights. :D
    153,746Coins
    Triple monitors and 2 users, what weight do you think it would be, my guess would be 200+ kgs. That is a lot to move, particularly with heave.
    What type of flight/aircraft do you plan to use, commercial heavies, recreational aircraft, aerobatics, or fighter planes/jets, or some combination of all of them? I am asking so we have some idea of how responsive it needs to be.
    There are some useful insights regarding the use of springs starting on this page of @cthiggin's build, with the spring being crucial: http://www.xsimulator.net/community...-ac-platform-it-begins.5141/page-4#post-51380
    I do think more leverage would be needed to drive the weight of 2 persons than just connecting to the bottom of the seat. I would be interested to know what @cthiggin, @BlazinH, @eaorobbie and others think about the design challenge.
  9. Nick Moxley
    2 people, Triple monitor's, Your gonna require some VERY precise balancing And or need to ditch the 2nd seat.
    How are you planning to balance it when you Dont have a passenger ?
  10. Pit
    30,510Coins
    The second seat is for your wife on the photo?
  11. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    @noorbeast Hello. Thanks. :)
    I am not sure, Those maybe about max 200kgs.
    The point is light sports aircraft. ;)
    153,746Coins
    Some have already given you design things to consider, like how to keep it balanced for 1 and 2 seats and maximising leverage. Hopefully others will add some more ideas and concerns.
    So do have a think about the challenges already raised and see if you can update your build plan with possible ideas or potential solutions, and keep asking members to give their views.
  13. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    @Nick Moxley Hello. Thanks. :)
    you're alright.;) but I just will be where center of gravity on under the frame.
    If not fit on passenger, I will be keeping some on 2nd seat likes my weights.
    How about wood frame? it is works for that enough?
  14. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    @Pit Hello. Thanks.
    First, yes then anybody(nieces or...) ;)
  15. Nick Moxley
    Sorry im not understanding "but I just will be where center of gravity on under the frame." can you explain further
    same with "If not fit on passenger, I will be keeping some on 2nd seat likes my weights." Darn language barrier. :grin
    Yes a Lumber frame will work, but must be build strong enough with enough supports for the weight required. Glue and Screw everything possible.
  16. noorbeast
    153,746Coins
    @hunijjang what I think you mean is that you intend placing your weight over the center of gravity and plan adding some sort of weight on the second seat for balance if nobody is using it. Is that correct?
  17. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    @Nick Moxley Hello. Sorry about you don't understanding What I mean... :)
    I still in contemplating the frame material.
    I am never once weld and Also, I don't have a welding machine.
    If the iron to make about in Where to producing... about 800$ but not at all.
    Yes, it is expensive than aluminum profiles. but I think so, that is not Huge price difference.
    so, There are several choices.
    a. wood.
    b. aluminum profiles with glued laminated. or only aluminum profiles with aluminum sheet.
    c. iron frame.
    :sos
  18. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    @noorbeast Hello, Thanks and that is correct... :)
    153,746Coins
    Have you investigated what the properties of the spring would need to be and where it could be made?
  20. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    @noorbeast Hello.
    Joint and the spring has been completed by joint manufacturer but I didn't calculated of the COG or something. :(
    I'll upload thats picture, tomorrow in the evening...
    Thanks to you again.
