Yobuddy's 6DOF seat concept
Discussion in 'CAD / CAE - Outdated' started by yobuddy, Mar 3, 2008.
  1. yobuddy
    51,260Coins
    A simple base could be built out of 6 metal 60deg corner pieces, and wooden boards for the sides.
    And like ego said, belts for the gearing. Something like this:
    What do you guys think?
  2. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    Re: 1000Watt DC motors for platforms?
    @yobuddy
    nice to read something from you again :)
    Thats a really great idea imho! Are you familiar with this CAD application? Would it be possible for you to draw the entire platform? I really like that design, and it would be great to have it as a completed CAD file. I'd really like to see your CAD construction in our CAD section.
    Theres a question left, that Evan mentioned. The freewheel issue. I cannot say if the motors will hold the platform wheigt even with 60:1 reduction ratio and alloted wheigt to the 6 motors by itself without current. That means it should have to be ensured perhaps, that either the motors get current continiously to hold position, or the controller has to go into braking mode.
    A wormgear drive is the better but more expensive way.
    Would like to know Evans opinion.
    Regards
    Christian
  3. EvanF
    EvanF Member
    Multimedia Producer
    New Zealand
    423Coins
    Hi all,
    Yes I agree that is a start to a good simple design - even I should be able to weld those corners up! :happy:
    I am not sure if belts are the way to go for this design though unless they are toothed.
    Freewheel would most certainly be an issue and if gearheads were to be used electromechanical braking would probably need to be addressed. Fortunately these are supplied with motors salvaged from wheelchairs and mobility scooters, but they are slow to release braking.
    I have not had much joy locking my motors to a static point using PWM control without unwelcome jitter. I don't think even with higher resolution angle encoders I could remove all jitter to a smooth ripple. The mechanics of the rotor and brushes means the motor must move slightly to switch to the next coil. You would need amazing feedback to balance current on one coil and then also cater for different weights too... way beyond my DIY skills, and hence the assist central spring on my 3DOF platform.
    I would love to use my gearheads as they are quick but yet I still perservere with my linear actuator design. Simply because they don't have a freewheel issue.
    My gearheads are excellent for FPS because in FPS the movements aren't really position critical like they are in carsim or flightsim. The freewheel in FPS case actually assists in slow return washout.
    EvanF
  4. egoexpress
    421Coins
    @Evan
    What about integrating DIY wormgears drive into the construction?
    Perhaps If we could organise such threaded shafts and and suitable toothwheels.
    Though I dont have a clue either how much such parts cost nor if they are standard parts.
    Regards
    Christian
  5. yobuddy
    51,260Coins
    @ego – I was just playing with Google sketch-up, since its free. But as you can probably tell, I’m not very good at it.
    Also, I like the idea of a force dynamics like chair above the 6DOF platform rather than just a flat platform.
    I believe the chair idea creates a better center of gravity than a flat platform. But makes it really hard to draw – lol
    I thought that these motors are permanent magnet?
    If we can find a holding force on the motors, we should be able to figure out if they will free wheel or not.
    I would think that with 6 dc motors all greared 60:1 there should be some decent holding force.
    But maybe we need one motor too do some testing on.
  6. EvanF
    EvanF Member
    Multimedia Producer
    New Zealand
    423Coins
    @yobuddy
    Permanent magnet motors still require electromagnetic force to propel them otherwise you would have perpetual motion! :yes:
    I thought the same on my 3DOF and certainly with the spring assist there is some holding force, until a 200KG person sat on it and the spring sunk more. (A nut to manually adjust the spring tension is handy.) But the issue comes in when not all 3 cranks are of equal angle, ie: when the chair is angled one way more than the other, balance is out and weight is not evenly distributed. Without enough power to hold them the motors with more weight on them then spin backwards due to the extra weight and gravity. You have to consider power flowing back into your H-Bridges at this point due to the motors acting like generators.
    @christian
    Yes including worm gears in the design would be cool but would slow the impressive speed of the crank motor concept. If I were to go down this track and make a 6DOF I would mod more linear actuators for it as they seem ideal for simming.
    EvanF
  7. yobuddy
    51,260Coins
    Just for fun-
  8. tronicgr
    tronicgr
    Hi Evan,
    I will not mention here again my thoughts about PID driving of motors, but I can tell that the feedback is certainly takes a part in this too. If the position feedback is too low, then the steps in the positioning will produce jitter effects! When I drive my motors I leave a small area in the middle position to be used as brake area in witch I short together both motors leads to have it hold it self into position. This brake area is small around 10 values (in a 0-1023 range). But the most important is that the feedback resolution is 4 times bigger than the motor control resolution to avoid as much the stepping of the motor!!!
    I wish I could explain it better!
    Regards, Thanos
  9. tronicgr
    tronicgr
    Hi Yobuddy,
    Hehe, Nice concept! Now its a 6DOF force dynamics platform!! :highfive:
    It can work, but I don't know if there is enough space for the legs of the rider
    Regards, Thanos
  10. egoexpress
    421Coins
    @yobuddy
    I like its simlicity much! I hope we can get rid of the freewheel issue in your concept.
    Regards
    Christian
  11. egoexpress
    421Coins
    The shafts could be fixed with UCF bearings to the construction. Those bearings are able to fix the shaft against linear motion as well.
  12. EvanF
    EvanF Member
    Multimedia Producer
    New Zealand
    423Coins
    Hi Thanos
    Yes I think you have explained it well enough. Currently on my 3DOF the 10K pots are mounted on the output end of the 40:1 gearhead. The coupling to the pot equates to 1:1 ratio. I have intended to place the pots to the rear of the motor so the motor will have to spin 40x before it equates to 1 revolution on the gearhead output. This should give me enough 'sensitive' feedback don't you think? But it also means more fiddling around with reduction ratios to connect the 270 degree single turn Pot. I think I will have to get free turning optical quadrature encoders for this application. Do you think I would remove jitter this way?
    By going down this path do you think we will have solved the freewheel jitter issue concerning reduction gearheads?
    But can your current AVR board cater for 3 optical encoders? Perhaps I will need to try the gearheads with my 2DOF, but I am currently working on linear actuators with that. I wish I had more time to try all concepts at once!! :eek:
    EvanF
    EvanF
  13. yobuddy
    51,260Coins
    Here is another possible solution.
    Anyone know where we could get heavy duty worm gears?
    It may even be even easier to put together, if we could find a low cost solution.
    My only real problem with linier actuators is that you would need expensive string pot's for position feedback on a 6 DOF simulator.
    I also like the idea of equipping the simulator with both 10kpot's and encoders.
    pot's are easy to adjust and could be used for calibration during startup each time, what do you think?
  14. tronicgr
    tronicgr
    Hi Yobuddy,
    I don't think that such open worm heads will work. At least not for long before they start to wear as they will lack lubrication!!!
    As I said to Evan, I will develop an analog decoder for optical encoders. Its easy to add an ADC input on those to calibrate the encoder in center position when its powered up. But Evan's idea to use limit switches for the calibration is also attractive idea...
    Keep up this great CAD drawings! They are cool!
    Regards, Thanos
  15. tronicgr
    tronicgr
    Hi Evan,
    I think that a 40:1 gear down will remove much of the jitter of your gearheads typemotors.
    My current AVR board has only ADC inputs. But thanks to your idea for an analog Decoder I'll probably have it work with optical encoders very soon!!! :) I know Its not easy to work in more that one concept at time but you could just use a demo construction with a dummy load to test it if it keeps producing jitter effects.
    Regards, Thanos
  16. EvanF
    EvanF Member
    Multimedia Producer
    New Zealand
    423Coins
    Hi Thanos,
    In a previous video, possibly as far back as 16 months ago now!!, I showed a demo of an H-Bridge brake using something a bit like
    if < 254 then pin 1 high pin 2 low if > 256 then pin 1 low pin 2 high (in picaxe code) and on the test bench it worked well enough to stop the motor solid without jitter, but in practice with more body weight being used, instead of just my hand trying to move it, the jitter appeared. Mind you the pots are 1:1 with the crank and I allowed a 1 point difference 254/256 between. I will try again with 40:1 and try 10 increments like you suggested, but will need to use an optical encoder instead to avoid the 40x multiple turn issue. Thus a digital/analogue convertor chipset would be cool thing to have handy.
    EvanF
  17. yobuddy
    51,260Coins
    I am trying to figure out the relationship between the gearing and the length of the gearhead lever.
    quoting egoexpress: With a reduction of 1:60 it turns 1rps and should have a torque of 192Nm! If the lever is reduced to 250mm, it provides ~80kgf over a total travel length of nearly 500mm!
    So is it true that:
    With a reduction of 1:120 it turns 1/2rps and should have a torque of 384Nm. If the lever is extended to 500mm, it will still provide ~80kgf?
    Does this mean that both of these setups will provide 500mm a sec, but the second one will provide double the overall range of movement for the simulator?
    Anyone have any ideas?
  18. yobuddy
    51,260Coins
    I’m trying to figure out how the actuators would get assigned for a six degree simulator.
    Currently we have two methods:
    Normal – one axis per degree of freedom.
    FREX like – two motors that work together – both motors are restricted to ½ of the available movement. (½ for Roll, ½ for pitch)
    6DOF - ?
    While I know my bad picture is NOT right, I just wanted to show my dilemma.
    Viewing from behind sim
    If anyone can be of some help, it would be greatly appreciated.
  19. tronicgr
    tronicgr
    Hi Yobuddy,
    No your thinking is wrong. Same applies to the schematic you have draw...
    Just take for example the simple pitch - roll motions... To produce a roll motion all motors must cooperate together to lean on one side without resulting changing the pitch of the platform. Same thing happens to the pitch... When you want to pitch forward, all motors must cooperate to produce the pitch action without resulting in unwanted roll motion...!
    Same applies to the heave effect! All motors must also cooperate to uplift on down lift the platform while keeping it level! Now consider this... Say that you have the platform rolled to 45 degrees to one side, and you want to perform heave motion... Guess what! The half motors are in up position and other half in down position with no space left for heave motion. So in this case the only thing you can do is to limit the pitch - roll motion to, say, 25degrees and have the rest motor travel, free for the heave motion that must be done in cooperated motion of the motors to keep the original 25 degree bank!!!
    The motion is getting more complex when you want to perform also yaw motion since it will also need some of motor travel reserved, so the final pitch-roll motion limitation can go down to 15-20degrees!!!!
    And there are also other motions that can be performed in certain situations that can end up extending only one of the motors!!! I that case you can have strange positioning effect that can be used for example when you want to simulate the drifting of the rear end of a car!
    The best you can do is to make a small (hand moved) platform to see that effect have various positions of the platform to the motors-actuators extending. This is called inverse - kinematics!
    Regards, Thanos
  20. yobuddy
    51,260Coins
    Ok, so I finally got some time to play with this a bit. I have put together a truth table for a 6dof simulator. I would check my finding again but my wife thru away my cardboard, plastic drinking straw and toothpick model thinking it was trash. :uups:
    The conclusion I make from the data collected is that a 6dof simulator with modest specification, like the ones listed below, would need at least a 325mm arm (lever) for all of the forces to be able to max out.
    Roll 150mm (+- 75mm)
    Pitch 150mm (+- 75mm)
    Heave 125mm (+- 62.5mm)
    Yaw 75mm (+- 37.5mm)
    Sway 75mm (+- 37.5mm)
    Surge 75mm (+- 37.5mm)
    = (650mm total travel needed)
