2 "froggies" in Vietnam
Discussion in 'New users start here - FAQ' started by digitrax3d, Mar 28, 2015.
  1. digitrax3d
    digitrax3d New Member
    Saigon (Vietnam)
    494Coins
    We are 2 french friends, living in Saigon (Vietnam).
    We are very bad in mechanics, electronics and software but we are still starting our first 2DOF simulator.
    Our "road" will be long and difficult, but we thank you in advance Xsimulator and his member for all their help.
    However, we have a relative advantage :
    Here, everything is cheaper than in the West, in case of failure, we can start again several times
    Kindly
    • Funny Funny x 2
    152,971Coins
    +11,115 / 56 / -2
    Welcome @digitrax3d
    You have come to the right place for motion simulation software, information and support from a very active community.
    Have a look at existing member builds for ideas and inspiration, it could well help you refine what you may like to do for your own project: http://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
    You will find the FAQ section covers some more specific topic areas, like types of simulators, designs and motors: http://www.xsimulator.net/community/faq/
    Do ask questions after getting an idea of what you would like to build, there is a lot to take in but the community is good at giving tips during planning, reviewing planned purchase lists, giving feedback and encouragement during the build and providing advice on actually sorting out motion profiles.
    Do take a moment and add yourself to the Member Map: http://www.xsimulator.net/community/memberMap/
    Good luck with your project.
    • Friendly Friendly x 2
  3. Baptx
    Baptx Member
    Employé
    Haute-Savoie
    405Coins
    3DOF, SCN5, SCN6
    Welcome back!
    Two french compatriots!
    Are you looking for 2DOF simulator with what type of engine? MEG, Cylinders ...?
    Bienvenue parmi nous !
    Deux compatriotes francais !
    Vous voulez faire un simulateur 2Dof avec quel type de moteur ? MEG, Vérins ... ?
  4. momoclic
    momoclic Active Member
    Retraité
    Nantes - France
    2,767Coins
    DC motor, Arduino
    Bienvenue, ne soyez pas inquiets les français sont bien représentés sur le site...
    Et beaucoup d'autres aussi sont disponibles pour vous et nous aider.
  5. RacingMat
    21,066Coins
  6. digitrax3d
    Saigon (Vietnam)
    494Coins
    Thanks for your support messages.
    If we can find cheap parts or works to help you ... you're welcome !
    In Vietnam, it's very difficult to find linear actuators.
    We have some contact with China companies, but till now we don't yet found actuators with a minimum of 12/15 Nm.
    Therefore we will start with 24V truck wiper motors.
    First configuration:
    Assetto Corsa > Sim Tools > Arduino > Sabertooth > 24V Wipers motors
    Our first motion base (with car wiper motors):
    152,971Coins
    +11,115 / 56 / -2
    You will not have a lot of leverage so close to and level with the pivot point. In other words I suspect it will struggle to maintain snappy motion with weight on it.
    Try it as it is and see how it goes. Worst case you can just recycle the motors and do a shoulder mount seat shaker, as those motors would do that.
    In some rare cases wiper motors are earth isolated but most often are not, so be aware they need to be: http://www.xsimulator.net/community/faq/wiper-motor-mandatory-ground-isolation.25/
    I am looking forward to the next update.
  8. digitrax3d
    Saigon (Vietnam)
    494Coins
    Thank you Noorbeast for your precious advice.
    We start completely, and it's sure that we will make many mistakes.
    This first plateform will be modified several times.
    For removing the ground contact of the wiper motors, I had already read informations.
    But before disassembling, I'm waiting to receive my driver cards.
    Moto monster card for testing with car wiper motors, and 1 Sabertooth for 24V truck motors.
    I hope this week.
  9. momoclic
    Retraité
    Nantes - France
    2,767Coins
    DC motor, Arduino
    +1 avec l'avis de Noorbeast
    Voici un schémas de la cinématique souhaitable :
    L'usage de 4 ressorts, sur la course descendante seulement, diminue les efforts pour remonter la plateforme.
    En gros, ils éliminent les forces statiques, mais ne sont pas indispensables si les moteurs on suffisamment de couple et la plateforme est légère.
  10. digitrax3d
    Saigon (Vietnam)
    494Coins
    Merci Momoclic pour ton aide.
    J'avais effectivement vu que certains (pas tous) mettaient des ressorts de rappel.
    Je me demandais si ces ressorts n'allaient pas faire justement l'inverse, c'est à dire, augmenter la charge lors de leur traction.
    Ici, j'ai trouvé des moteurs chinois en 24V - 100W pour 60$ l'unité, ca devrait aller, non ?
  11. momoclic
    Retraité
    Nantes - France
    2,767Coins
    DC motor, Arduino
  12. digitrax3d
    Saigon (Vietnam)
    494Coins
  13. momoclic
    Retraité
    Nantes - France
    2,767Coins
    DC motor, Arduino
    Désolé mais ici en france 47,39 euros + le port, c'est très correct et comparable au 60$.
    Sans doute tes moteurs chinois feront l'affaire, même s'ils sont un peu moins puissant.
    Les ressorts ne sont pas obligatoires. Personnellement je pense qu'avec des moteurs peu puissants et des pignons en plastique soulager la mécanique n'a que des avantages.
  14. digitrax3d
    Saigon (Vietnam)
    494Coins
    Je m'étais mal exprimé : Les moto-réducteurs chinois sont à 60$ la paire
  15. digitrax3d
    Saigon (Vietnam)
    494Coins
    Thank you, everyone, for all your advice.
    We are still waiting for our driver cards from USA to test our configuration
    We are blocked
    Warmly
  16. digitrax3d
    Saigon (Vietnam)
    494Coins
    I just found the specifications of IBT2 driver which is much cheaper than sabertooth.
    Is the IBT2 performs as well as the Sabertooth?
    Someone have the wiring diagram : Arduino Uno > IBT2 driver > 2 wiper motors ?
    Thanks a lot.
  17. Pit
    30,501Coins
    Which Ard code you are using? Each code has a different wiring for the most part.
  18. digitrax3d
    Saigon (Vietnam)
    494Coins
    Sorry, but I know nothing.
    Which code you recommend for 2 wiper motors
  19. Pit
    30,501Coins
    You should ask which code supports IBT2...did you order the IBT2 already?
  20. digitrax3d
    Saigon (Vietnam)
    494Coins
    Not yet.
    This morning going to an Arduino distributor, I discovered IBT2
    While I have already ordered Sabertooth, but they have not yet arrived.
    The IBT2 card is much cheaper.
