Hi there. So interesting forum you got here, that I had to do my own 2 DOF Full frame in stainless
Discussion in 'DIY Motion Simulator Projects' started by Ken50, Mar 29, 2015.
  1. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    • Like Like x 8
    153,697Coins
    Beautiful craftsmanship @Ken50!
    I see you plan JRKs and DC motors, what gearbox ratio are you using with the engines?
    It looks like you have a CV joint for a pivot. You may want to consider a cross brace with heim joint ends between the top and bottom frame to prevent unwanted torsional twist.
    I am looking forward to following your project as it progresses.
  3. SeatTime
    Nice work :thumbs Even though we talk about using a big uni joint from a car, unfortunately it is not obvious that ideally your pivot should not be able to twist at all - you will see why when you put it all together. Nice workshop to, metal lathe and mill - we can only dream...
  4. bsft
    Yeah, top job mate!
  5. kanuk
    kanuk If it ain't moving, it ain't simulating...
    Eng
    Melbourne Australia
    2,380Coins
    As previously stated, that is indeed a beautiful build. Well done on the design. I too will keep a progressive eye on your project. It certainly looks like one to behold.... :thumbs
  6. Baptx
    Baptx Member
    Employé
    Haute-Savoie
    405Coins
    3DOF, SCN5, SCN6
    Well Done!
    Nice job, clean, neat, well this early project!
  7. Pit
    30,510Coins
    HI @Ken50 what a work shop, what a superb craftsmanship! So far really great job. Only just one suggestion, you will run into a flexing frame. I have marked the photo which you have uploaded which weak point is to expect:
    • Agree Agree x 5
    153,697Coins
    To me it looked like the seat frame had been tack welded at all joints for setup purposes.
    • Agree Agree x 4
  9. XORExploit
    XORExploit
    Nice job on the frame and everything, keep us posted :)
  10. Nick Moxley
    Even if he did a Full weld, there will most likely be some flex in said joint.
  11. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    Don't worry, it will be reinforced the right places, this was very early in the build, I will upload some more up to date pictures asap! But hey,I joined up so that I could get benefit of your experience! I will need it soon enough, the sim/feedback part,that's where I'm on deep water! Thanks!
  12. Nick Moxley
    were here to help, Anything you need to know, just ask.
  13. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    As promised : DSC_0012.JPG
    • Like Like x 6
  14. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,210Coins
    Thought "me" could weld pretty good, but gee-whiz, that's some beautiful welding AND on stainless..........just beautiful friend!!
    Tom
    • Agree Agree x 4
  15. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    Sorry, my phone is killing me!(the pictures)
  16. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    Thanks, I've been working as a welder all my life, so...!
    153,697Coins
    And it shows in the quality of your work!
  18. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    Thanks again, picture of my first and present rig
  19. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
  20. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    You might find that your rose joints run out of travel pretty quick how they sit now. A conical spacer either side of the joint will give you about 30% more travel. I suppose it also depends on total movement of the rig but something to look out for.
