2 DOF Seat Mover - GIB
Discussion in 'DIY Motion Simulator Projects' started by GIB SimRacing, Feb 21, 2015.
  1. GIB SimRacing
    GIB SimRacing Active Member
    Barossa Valley, SA
    983Coins
    Thanks mate, I have read through that manual and found that part.
    You are correct, I am using the 600PBS power supplies. I have changed the psu over to see if that makes a difference. No luck. I can't see any evidence of any short anywhere on the controller. No stray strands either.
    I have also cleared all the settings from that jrk multiple times. Unfortunately that did not fix it.
    I have set up the first jrk without any problems and then went on to do the second one.
    I'm not sure if it will help you but here are the settings I put into the controller:
    Maybe I need to get this one jrk replaced...
    152,615Coins
    +11,087 / 56 / -2
    I have had one JRK DOA, so it can happen. Pololu will want you to trouble shoot first anyhow.
    I am hoping that there is no chance you crossed the power and earth wire for the pots.
    Can you post a picture of the problem JRK and how it is wired up. Are the wires to the pots on the pins closest to the large chip?
    A bit of a stretch but have you tried a different USB cable for the problem JRK?
    Just some setting stuff to try. You can increase the integral limit to 10000, Max Current to 0 (unlimited), Current Calibration 130.
  3. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    Just my 2cents... are you able to re-apply Firmware 1.4 just to fully reset all the logic??
  4. GIB SimRacing
    Barossa Valley, SA
    983Coins
    @noorbeast - This is how it is wired. The wires for the Pots are: AUX (Red) on 1, FB (White) on 2 and GND (black) on 3. This is the pot http://au.rs-online.com/web/p/potentiometers/1642661/
    Again, even without pot and motor connected, the issue remains. I have also tried a different usb cable.
    @Archie - worth a shot too. I will look at doing that.
  5. bsft
    send an email to pololu about it
  6. GIB SimRacing
    Barossa Valley, SA
    983Coins
  7. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    Have you tried connecting pot's red wire to 5V pin instead AUX?
    I actually never used AUX, don't know what it does, it was always 5V, GND, FB..
    EDIT: Nevermind, I've missed your sentence where you said you're having same problems without the pot..
  8. value1
    15,079Coins
    Just FYI:
    The AUX line is an output that is generally high whenever the jrk has power. The line will only go low for two reasons:
    1. If the jrk’s microcontroller goes to sleep (because there is no VIN supply and the device has entered USB suspend mode), the pin is tri-stated and pulled low through a resistor.
    2. If the Detect disconnect with AUX option is enabled for either the feedback or the input, then the jrk will drive AUX low for about 150 μs each PID period to check if the feedback and/or analog inputs are disconnected
    So with the AUX you can check, if a pot is connected or not.
    Selecting the Detect disconnect with AUX option activates an extra feature that allows the jrk to detect if the FB pin becomes disconnected from the analog voltage input device or shorted to 5 V. This option is intended for use in analog voltage feedback mode with a potentiometer connected between AUX and ground. When the option is selected, the jrk will periodically drive the AUX pin low, verifying that this results in a 0 V signal at FB. If the line does not respond as expected the Feedback disconnect error will occur.
  9. bsft
    Just a question and I may have missed it?
    Why do you have extra wires soldered on? like I have circled?
    The green, black, yellow, and red?
    I can see the alligator clip wires would be for the pot
  10. GIB SimRacing
    Barossa Valley, SA
    983Coins
    I used the AUX pin because that's what was recommended in the Jrk manual I believe. I have also tried it connecting to the +5V instead.
    The soldered on wires are for a status LED's and a reset switch on the dash board. Just like @Archie has done here - http://www.xsimulator.net/community/threads/jrk-reset-switch.6642/
    I have contacted pololu about the problem and am now waiting to hear back.
    152,615Coins
    +11,087 / 56 / -2
    Fingers crossed Pololu will come up with a resolution.
    My biggest concern is unshielded terminals for the pot, as there is a real risk of some movement and a short. A 3 pin terminal block from radio controlled gear is a much better and neater option.
  12. Archie
    Wollongong, NSW, AU
    3,797Coins
    Hey @GIB SimRacing - While this won't solve your issue, something I did on my JRK to ensure nothing shorts at the terminal block is put the GND in the middle.
    So on the JRK you have VIN, GND, A, B - The motors don't care, so I made A my motor's GND so that I don't get any short from the terminal blocks when everything is neutral.
    Of course the motors go both ways, so the potential is always there during use, but in initial power up, the chance is minimised / zero.
    See Pic:
  13. GIB SimRacing
    Barossa Valley, SA
    983Coins
    @noorbeast - I agree with you. I will get those isolated.
    @Archie - I also thought about that initially, but then like you said, it will change while operating anyway.
  14. GIB SimRacing
    Barossa Valley, SA
    983Coins
    Still waiting to see if this can be solved. I am in contact with pololu so hopefully this can get sorted without the need for a new Jrk. I'm not holding my breath though.
    In the mean time, more building.
    I started putting things back together.
    This is how the motors ended up getting mounted. I welded the lever directly to the axle. Safes having to rely on nuts holding things together. I know it's more work if I have to replace parts as I have to make them again, but I think it's worth it.
    The potentiometer is mounted directly to the end of the axle. Where the shaft of the pot goes into the axle it is held in place with a grub screw.
  15. GIB SimRacing
    Barossa Valley, SA
    983Coins
    While I had everything apart, I changed the Screen positions slightly. So I thought I better go for a monitor test fit...
    It ended up exactly as planned!:D
  16. noorbeast
    152,615Coins
    +11,087 / 56 / -2
    I am really looking forward to the video of you rig in action @GIB SimRacing, it looks superb, great job :thumbs
  17. GIB SimRacing
    Barossa Valley, SA
    983Coins
    @noorbeast - I'm looking forward to recording that video!:D
    There are still a few things to do before it will be "finished". But at least it looks like a simulator again at this stage.
    I still have to get the problem Jrk sorted so I can start setting things up motion wise. But it looks like I may need to get a new one...:(
    What size fuses do you use in your 12V circuit? I am thinking to wire a 30A fuse in between the PSU and Jrk. I know the Jrk is only rated for 12A continuous but has a peak current rating of 30A. But then again, the motor has a stall current of 32A...what is your experience?
    I just want to be extra cautious now, since I ran into problems with the motor control side straight away before even getting to use the sim.
  18. Archie
    Wollongong, NSW, AU
    3,797Coins
    Excited!!!
    • Funny Funny x 3
  19. GIB SimRacing
    Barossa Valley, SA
    983Coins
    ...to say the least!
    152,615Coins
    +11,087 / 56 / -2
    You can go the trial and error blow a fuse route or you will need a shunt to measure what your rig actually draws: http://www.xsimulator.net/community...-meter-to-test-current-loads-no-problem.6064/
