DIY 2DOF
Discussion in 'DIY Motion Simulator Projects' started by Daguru, Dec 12, 2014.
  1. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    Nice, I have one TM1638 lying around, totally forgot about it since I left X-Sim3 software and never got opportunity to test it with Simtools since dashboard functions were enabled..
    I need to check how it's done in Simtools. Although I see this code from Assetto forums works good, it is only available for AC and iRacing, I believe with Simtools would be more games supported..
  2. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Yeah that's my plan I'm not sure how to set it up for simtools yet but when i figure it out the list of games will be awesome can't wait !! :grin
  3. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi
    I'm hoping that my crazy life will calm down a bit so I can get on with this project
    here is a couple of pictures of my static rig that I plan to convert to motion
    I built it about 4 or 5 years ago and use it for Racing, FPS and Apache Air Assault but mainly Rally
    but I have to say Assetto corsa is drawing me into track racing more and more these days;)
  4. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi all
    As a starting point for the levers on the motor what would be the best CTC on a shoulder mount rig?
    I can make two for test and drill a few different centres but what's normal starting point ( I have read so much for so many different styles I can't remember lol )
    Regards
    Dag
    153,716Coins
    It depends a bit on what motors but with wipers you could try 40, 50 and 60 CTC.
  6. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi @noorbeast thank you
    I'm going with 60:1 worm drive motors
    153,716Coins
    In that case you may want to try 65, 75 and 85 CTC.
  8. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
  9. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    quick update
    made a start on the seat frame
    a pair of levers
    drilled and tapped M8 bolt in rear of shaft for pot mount
    its a nice feeling getting stuck in for a few hours :cool:
  10. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi
    I've mocked up the wiring and motors loaded the arduino with SMC3 ran through the tutorial a bingo I have motion
    set up SimTools as per tutorial and bingo I have motion in games, 3 games tested so far so to my question
    how does the SMC3 Utils settings look to you guys
    im using 2 monster motos with 90zyt 155 with 60:1 I have left the settings im guessing on the low side so I didn't blow anything right away
    I am using very cheap pots and think that might be why the feedback is not spot on is that correct ?
  11. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi guys,
    Good news and bad I got rig mocked up, tested it and it seemed to be working ok so started to setup some profiles and then noticed the one motor would stop working intermittently so took a screenshot of smc3 utils
    any ideas?
    I swapped the power supply's over and it still the same.
    Also swapped the pot for a new one and ran a fresh wire from pot to arduino.
    Just quickly tried a car battery to power it and still no joy.
    kind regards
    Dag
  12. Blame73
    Blame73 Well-Known Member
    8,313Coins
    check monster motor solderings, the power ones, I had a similar issue and it was due to a bad soldering
  13. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Ok thank you will check all connections and report back ;)
  14. Rocket man
    Rocket man Member
    Canada
    - 325Coins
    I always love getting free stuff! Got a free 42" plasma that wasn't working, turns out it was a 25 cent fuse.:grin
  15. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    little update
    seat frame painted
    arms painted
    and my brother printed me a mug lol
    going to paint main frame now ;)
  16. prodigy
    Croatia
    6,698Coins
    Nice mugshot :grin
    • Funny Funny x 2
  17. Baptx
    Baptx Member
    Employé
    Haute-Savoie
    405Coins
    3DOF, SCN5, SCN6
    Yesss !! Nice mug
  18. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    been away for few days but made a bit of progress today
  19. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Ok guys need a bit of help my rig is now in full test mode working with motion very happy (massive thank you all the helpful members of this site);)
    Ok so my question after about an hour or so of profile setting I keep getting the one motor stopping, I've tried a range of different kp and pwmmax settings from low to hi, strange that it seemed to work fine for the first hour.
    things I've noticed one motor gets a bit warmer than the other but it's the cooler motor that cuts out the heat sinks on both MM are cool to the touch so I'm thinking it's not a heat related issue.
    im away from pc right now so if you guys need any screen shots etc let me know
    Thanks in advance
    Dag
  20. Pit
    30,510Coins
    @Daguru great rig you have build so far! Please can you share more information, some more details, when it happens, which tracks of which racing sim you are using, which SMC3 settings you are using etc. Please post only information about any issues which has been confirmed.
