Showroom DIY 2DOF simulator
Discussion in 'DIY Motion Simulator Projects' started by Erwan960, Sep 27, 2013.
  1. Nath Older
    Nath Older Member
    Laboratory Supervisor
    United Kingdom
    271Coins
    Damn this looks good, well done :thumbs
  2. alexis67
    alexis67 Member
    288Coins
    your sim look nice !
  3. Atlas974
    Atlas974 old school
    Physics chemestry
    Reunion island
    358Coins
    Really good DIY
    Vraiment très beau!
  4. Martin van Hagen
    Martin van Hagen not trying brings you nothing! SimAxe Beta Tester Gold Contributor
    Instrument Engineer
    The Netherlands
    881Coins
    A salute to your well built rig!
  5. Mitchell
    Mitchell Member
    Netherlands
    87Coins
    Nice sim!
    What kind of springs did u use ? around the pivot i mean.
    What kind of value do i have to look for
  6. Erwan960
    Erwan960 Active Member Gold Contributor
    3,832Coins
    I used to add springs but they are no needed anymore. I advise you not to use them neither.
    In fact if your structure is well balanced, they are useless.
  7. Mitchell
    Mitchell Member
    Netherlands
    87Coins
    Really..
    It looks useful to me.. But ok will try without :)
  8. WowaDriver
    WowaDriver Waldemar Jost
    Bachelor of Science and Engineering
    Hannover
    1,127Coins
    Hi Erwan960,
    really, i mean really good and nice clean work you do! Wish everyone to have your skills to build professional lokking simulators like yours!!
    Best regards
    Waldemar
  9. townnet
    townnet New Member
    Singapore
    400Coins
    Very clean and adorable design, well done man! But make the paddle move with chair will it bring more immersion?
  10. Erwan960
    3,832Coins
    I tested the two alternatives : move only the chair or move the whole.
    As far as I'm concerned, I REALLY prefer when the entire cockpit is moving. This observation is true as in triple screen configuration as with the oculus.
    I have been reproached not to feel "small" effects. But it is not true because they are simulated by the platform as well as with the four buttkickers installed at the ends of the frame.
    When the engine is off and you have to switch on the ignition before you press the power button engine, the seat starts to feel the rhythm of the engine vombrissement. When I put two wheels off the track in the grass or gravel, and the frame will vibrate or jump by the speed at which all this takes place. When in contact with a vehicle in front, behind or on the side ...
  11. Erwan960
    3,832Coins
    I have been asked to post some pictures of the mounting system of motors and potentiometers as well as the control box. It's done !
    • Like Like x 7
    152,553Coins
    +11,086 / 56 / -2
    Beautiful workmanship :thumbs
  13. RacingMat
    21,059Coins
  14. stamer57
    stamer57 Member
    963Coins
    Vraiment très bien
    Very good
  15. Erwan960
    3,832Coins
    Yes, all parts were laser cut.
  16. Claudemir
    23Coins
    pretty! simulator
  17. muxximess
    muxximess New Member
    Australia
    327Coins
    Hi Erwan960,
    I wanted to say that your build is exceptional, quality of workmanship and attention to detail is remarkable.
    I'm tossing up whether to build just a seat mover or cockpit mover like yours. Please excuse my ignorance if you've already mentioned this previously in your thread, but I couldn't seem to find the answer. Out of curiosity, would you mind telling me approximately how heavy your cockpit is including the seat, wheel etc. My cockpit will weigh approximately 55 kg's after seat, wheel etc and I was wanting to get a gauge of whether it would be viable to create a a cockpit mover with such a heavy starting point?
    Thanks!
  18. hunter03
    hunter03 New Member
    472Coins
    Very good work
  19. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    The sheer beauty of symmetry in design never gets old. Very, very nice build!
  20. Erwan960
    3,832Coins
    I have no idea of the exact weight, but it must be in the same range as yours.
