News 3dof linear acurator with steper motor 12Nm
Discussion in 'DIY Motion Simulator Projects' started by misoswan, Apr 8, 2015.
  1. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    for 3 dof linear actuator looking strong engine 1 linear acturator lifts 100kg 150mm/s i have page for construction the need to recommendet motor . https://simulatortech.wordpress.com/
    if this is not possible second alternative is
    How strong
    Worm Drive Motor
    requires for 100 kg .recommendet
    152,553Coins
    +11,087 / 56 / -2
    It takes a lot of Newtons to move 100kgs at simulation speed around 400 - 700 m/s, as unlike a 2DOF there is often no post to take the weight. Hence powerful AC motors tend to be the norm in traditional 3DOF heave designs.
    I would suggest going the AC route. @speedy has already suggested 1/2hp 3phase motors with VFD inverters.
  3. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,797Coins
    There is 1NM needed to move 100kgf with an 1605 ballscrew.
    For a speed beteen 400/700mm sec you need a 1610 balscrew (500mm sec @3000rpm)And 2NM.
    I recomend a 1hp motor To get that speed and force.
    For tech.stuff and formula,s about DIY actuators see www.roton.com
    Sorry for the bad english.
    Regards Ad
  4. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    http://www.automationdirect.com/adc...peed_Reducers)/Dual_Shaft_Output/WG-262-060-D
    http://www.automationdirect.com/adc...-Phase_Motors,_56C_(0.33_-_2HP)/MTR-P75-3BD18
    expensive deliveri on united kingdom :(
  5. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,210Coins
    I'm using the Automation Direct for my inverters and my 1hp MicroMax motors.................THESE MUST BE INVERTER DUTY Motors, not merely induction type.
    Inverter Duty will hold up to the massive amount of start/stops - induction motors will do it, but not last nearly as long..............
    The Automation Direct "Inverters" state that for "our" use in motion sims, frequent forward/reverse movements, that an "Inverter Duty Motor" is required.
    Good luck,
    Tom
  6. Pit
    30,498Coins
  7. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,944Coins
    @misoswan ... I recommend you the above 3DOf crank arm concept ... and for a good lifting/moving power use a center spring with a U-joint .
    see our friend @cthiggin 's project ... It's really perfect that way :thumbs
    3DOF - AC Motor Platform
  8. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    just crazy thrown away hard earned money down the drain :popcorn
  9. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    That's what I was looking for.thank
  10. misoswan
    1,032Coins
    3DOF, Arduino, JRK
  11. Pit
    30,498Coins
  12. speedy
    Alexandria , Egypt
    7,944Coins
    those motors are not ready for a front mounting flange ... so there is no way you can mount such gearboxes to them even the correct size .
    I prefer the SEW motors as they are ready assembled and the gearbox can provide enormous torque in the output shaft (crank arm) with a minimum motor HP .
    there are tones of such used with good condition motors in UK ...
    http://www.ebay.co.uk/itm/SEW-SA47D...719?pt=LH_DefaultDomain_3&hash=item43da2bb69f
    here is a 3/4HP faster motor ...
    http://www.ebay.co.uk/itm/SEW-Eurod...068?pt=LH_DefaultDomain_3&hash=item4d2cbb6b94
  13. speedy
    Alexandria , Egypt
    7,944Coins
  14. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,797Coins
    Those moters can be ordered with the right flens B5
  15. DanielDk
    DanielDk Member
    386Coins
    Depending on how much you want to spend, I would definitely go with a servodrive (not a vfd) and matching servo motor with a light core, made for rapid position changes. A motor in the 80 framesize range should be perfect.
    Pros:
    Easy setup - turnkey solution.
    best precision (encoder included directly in the motor)
    best acceleration / direction-changes
    huge selection to choose from.
    built in powersupply available.
    Cons:
    price..
    ps: if you are adventurous, ebay may be you friend - but do your homework - there are lots of pitfalls and incompatibility between products, which is why i would recommend contacting an automation company and get a package deal.
    Cheers
    /daniel
  16. DanielDk
    DanielDk Member
    386Coins
    Something like:
    http://www.servocomponents.co.uk/rotary-motors/brushless
    The XBR34 is an 80 size frame and looks like a good contender. I'm shure you can contact them directly to get exactly what you eed.
    http://www.servocomponents.co.uk/servo-amplifiers/copley
    Here the "xenus" drive seems like a good fit for the above motor. And it takes 240v ac directly so no need for a powersupply...
    I have no idea if the above company is is good/cheap it just an random example from the uk - do your own digging :)
    Cheers
    /daniel
  17. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    what engine speed look? first have 19 rpm second 129rpm .thanks
  18. speedy
    Alexandria , Egypt
    7,944Coins
    That is related to your mechanical design of your sim as they are all can be used ...
    just start your design ...
    Or maybe you can go with DC motors with similar designs like this ... @prilad has done it very good and very simple ...
  19. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    I found these
  20. speedy
    Alexandria , Egypt
    7,944Coins
    What [base and top plate-form design] are you going to DIY or use ?
    with or without a center spring ?
    you haven't confirm that choice yet ... you may need 1hp more or less .
