2DOF motion simulator build
Discussion in 'DIY Motion Simulator Projects' started by Ville Pesonen, Jan 14, 2015.
  1. noorbeast
    152,111Coins
    +11,065 / 56 / -2
    Great progress @Ville Pesonen :thumbs
    I am guessing that is a screen mount over the pedals. If so have you balanced the rig with the screen on it, along with the seat and yourself in in?
  2. Ville Pesonen
    Ville Pesonen Active Member
    857Coins
    It's not a screen mount. It's meant for the Oculus Rifts tracking camera.
    I remember you saying that vibrations might become an issue in driving games with the Rifts camera mounted on the sim. If / when that is a problem I'll mount the camera on a tripod off of the sim. I'm hoping that Elite Dangerous would not induce too much vibrations as I'd imagine it would be more pleasant to play it without "moving" too much around the ship when the sim moves.
    152,111Coins
    +11,065 / 56 / -2
    My mistake @Ville Pesonen.
    Elite is pretty gentle compared to racing simulation.
    I am waiting on a part to test an idea around Rift camera mounts, so hopefully I can advise further soon on the outcome.
  4. Ville Pesonen
    857Coins
    very little progress on the frame this weekend. Finished the motor mounts and the lever stick thing on the motors. The ctc:s are 8 and 4,5 cm.
  5. Pit
    30,490Coins
    little progress is progress...looks great so far!
  6. Ville Pesonen
    857Coins
    The sim is nearing completion!
    The connection rods are finished so the sim looks like a sim now.
    I'm not sure about the width of the connection points of the rods and the frame. I might have to make it a little narrower to get more roll on the sim. We'll see how this works.
    The rods are made from a solid metal rods (can't remeber the width). I drilled holes in both ends and welded a M10 threads to the ends to attach the joints.
    152,111Coins
    +11,065 / 56 / -2
  8. Ville Pesonen
    857Coins
    I printed couple of hand knobs for m8 bolts to make the wheel adjusting a bit easier. Now I don't need a wrench to adjust the wheel.
    Too bad that I can not test them, as my simulator is at the "construction" site 20km away.
    here's a time lapse video of one of them printing for your amusement.
  9. Ville Pesonen
    857Coins
    I was on a 5 week holiday trip but now I'm back home. I'll continue the build probably next week as this week is already booked.
    If I remember correctly, the next thing on the to-do list is to see if I can make it move. After that it's time to paint it.
  10. Ville Pesonen
    857Coins
    Yesterday I soldered a shield for the arduino to make it easier to connect it to the H-bridges and potentiometers. Now it's easier to swap the arduino if it breaks. The shield only has connectors soldered and wired to it.
    it's an improvement over the wire mess that I had earlier
  11. Ville Pesonen
    857Coins
    All parts are now painted.
    Pretty soon it will be finished and I can bring it home!
  12. Ville Pesonen
    857Coins
    I blew the other H-bridge while I was testing the electronics. The motor only spins to one direction so I guess the other half bridge got fried on the board. Well, I can only blame myself for putting 12 volts to wrong pin on it :D I should have double checked the wiring....
    Anyway, I ordered 2 more H-bridges and hopefully I get them soon. in the mean time I hope to finish everything else on the sim so it's ready to move when the H-bridge arrives.
  13. mrbeginner
    What ever come in my way
    Finland Niinisalo
    - 10Coins
    I know that feeling when you don't double check wires.. I try it with car battery once and after that i check everything at least twice. Hope you get those H-bridges soon and get sim running without other problems. It's good to see other members in Finland in this page. Keep up the good work!:thumbs
  14. Ville Pesonen
    857Coins
    @mrbeginner That car battery incident sounds like it did some damage?
    Some progress today. I assembled the sim today, well at least the parts that I had with me. Now I have a bass shaker attached to the bottom of the seat.
    I also got the sim moving for the first time today! The potentiometers were not connected to the motors, but I got the motors to turn manually
    I had some problems with my H-Bridge also. It seems it's overheating and shutting down. I'll have to add a fan to cool it down and see if it helps.
    Next on the list is to make holders for my Saitek X52 stick/throttle and attach the seatbelt somewhere on the sim. I also have to see if I have to redo the pot connectors. After that I think it's ready to come home.
  15. Pit
    30,490Coins
    No worry, this is an expected behavior. Stick some coolers on the chips and use some fans to avoid any shutdowns.
  16. Aaron450
    Aaron450 New Member
    tasmania
    357Coins
    Nice looking good
  17. André Vasconcelos
    André Vasconcelos Member
    Engenharia mec.
    Barretos, Sao Paulo
    61Coins
    2DOF, AC motor, Arduino, SimforceGT
    good set
  18. Adam A
    Adam A New Member
    IT Manager/ Operations Manager
    Phoenix, AZ USA
    310Coins
    great looking sim. Gets me excited to start mine!
  19. Ville Pesonen
    857Coins
    today I got the SIM home. It found a nice little corner for itself.
    I'm still waiting for the h-bridge so I can get it to move. In the mean time I'll see if I can get it to move via computer one motor at a time.
  20. tombo
    tombo Active Member
    2,443Coins
    DC motor, Arduino
    nice to see you have your project finished. Looks very clean. I hope the parts will arrive soon so you can go for a ride :)
