3DOF ALU
Discussion in 'DIY Motion Simulator Projects' started by glumph, May 16, 2015.
  1. glumph
    glumph New Member
    FRANCE (76)
    816Coins
    3DOF, AC motor, Arduino
    Bonjour,
    Voici mon projet 3DOF.
    Full aluminium.
    3 ecran 24"
    J'ai commencé depuis 1 mois, il avance doucement mais surement !
    Hello
    Here's my 3 DOF project.
    Full aluminium.
    3 screen 24"
    I started from 1 month, he Advanced slowly but surely!
    • Like Like x 5
    153,691Coins
    Welcome @glumph and thanks for sharing the pictures of your rig. The craftsmanship really shows.
    Can you explain what is to be mounted over head and what motors, PSUs and control boards are you planning to use?
  3. glumph
    glumph New Member
    FRANCE (76)
    816Coins
    Hello
    The structure is made to be rigid and light, that is why the top bar will join the front.
    I install 3 worm gear motor 60NM 24v 54 rpm + arduino + sabertooth + SimTools.
    Steering wheel/pedals: Thrustmaster TX Racing Wheel Ferrari 458 Italia Edition
    The audio kit 5.1 will beinstalled on the structure.
  4. glumph
    glumph New Member
    FRANCE (76)
    816Coins
    Salut,
    Merci pour les conseils.
    J'utilise du tube Alu de 40x60 ép:3mm
    Presque tout est soudé.
    Si ça bouge je renforcerai ;-)
    Thank you for the advice.
    I use Alu tube 40x60 e: 3mm
    Almost everything is welded.
    If it moves I will strengthen;-)
  5. Wanegain
    Wanegain Active Member
    Bruxelles
    2,017Coins
    Can you please give me more information about your motors (link, price ?) ?
    Peux-tu s'il te plait me donner plus d'informations concernant tes moteurs (un lien ou quelque chose) ?
    Belle réalisation en tout cas, c'est original cette structure, j'espère que ça ne te posera pas de problème.
  6. francky foor
    francky foor Member
    france (nord)
    347Coins
    2DOF, SCN6
    jolie projet:thumbs
  7. glumph
    glumph New Member
    FRANCE (76)
    816Coins
    Bonjour,
    Pour les moteurs je pense prendre chez "Motion Dynamics" .
    Mais j'aimerais trouver un vendeur en Europe, car les frais de port sont tres élevé.
    Avancement du week end :
    For engines I think take in "MotionDynamics" .
    But I would like to find a seller in Europe, because the shipping costs are very high.
    Progress of the weekend:
  8. francky foor
    francky foor Member
    france (nord)
    347Coins
    2DOF, SCN6
    quelle genre de moteur ?
    je suis impatient de voir ton projet avancer;)
    what kind of engine
    I'm anxious to see your project progress;)
  9. glumph
    glumph New Member
    FRANCE (76)
    816Coins
    Celui la :
    That the:
  10. zigzag49
    zigzag49 Active Member
    726Coins
    je pense que c'est celui-ci.
    https://www.motiondynamics.com.au/320w-12v-24v-worm-drive-21-256-rpm-25-75nm.html
    Il y en a d'autres a moin cher mais ce sont les fdp qui monte vite.
    I think this is it.
    There are others has moin expensive but it is the pdf that goes fast.
  11. glumph
    glumph New Member
    FRANCE (76)
    816Coins
    Je l'avais vu sur EBay, mais il n'y en avait pas de dispo.
    Vais regarder de nouveau ;-)
    Tu a son nom !?
  12. Martin van Hagen
    Martin van Hagen not trying brings you nothing! SimAxe Beta Tester Gold Contributor
    Instrument Engineer
    The Netherlands
    881Coins
  13. zigzag49
    726Coins
    thank you for the link .
  14. EFFalcon
    EFFalcon New Member
    512Coins
    that top bar really makes it look serious.
  15. glumph
    glumph New Member
    FRANCE (76)
    816Coins
    Bonjour,
    Merci pour le lien, le ZYT90-199 n'est plus en stock, je lui est demandé un délais .
    Hier soir j'ai fabriqué le support du volant, il me reste quelques renforts a fabriquer sur la partie vertical et en bas.
    Thank you for the link, the ZYT90-199 is no longer in stock, I was asked for a delay.
    Last night I made the wheel of the support, I have a few reinforcements to manufacture the vertical portion and below.
  16. glumph
    glumph New Member
    FRANCE (76)
    816Coins
    Bonjour,
    La premiere partie est terminé.
    C'est déjà tres sympa a piloter sans les mouvements !
    Je vais maintenant faire la partie inferieur du simulateur, tout ce qui est mobile et electrique.
    J'avais prévu des moteur DC, mais j'ai peut'être trouvé des motoréducteurs AC.
    Mais je ne sais pas comment les brancher.
    Il faut un variateur de vitesse, mais quel model est compatible ?
    Et pour la carte ARDUINO, est elle compatible avec ce genre de montage ?
    Merci pour les infos :)
    The first part is completed.
    It's already very nice to drive without movement!
    I will now make the lower part of the simulator, everything is mobile and electric.
    I had planned the DC motor, but I can 'be found AC gearmotors.
    But I do not know how to connect them.
    It takes a variable speed drive, but what model is compatible?
    And for the Arduino card, is compatible with this type of installation?
    Thank you for the info :)
  17. Seth2Christ
    Seth2Christ Member
    216Coins
    Oh yeah! It's look great!
    Do you know how many weight the structure?
  18. noorbeast
    153,691Coins
    @martin falz I can find Longwaymotors in China, are there European distributors and price lists somewhere?
    • Disagree Disagree x 1
  19. glumph
    glumph New Member
    FRANCE (76)
    816Coins
    Thank you.
    Regarding the weight, I have not weighed, but I wear the structure itself without problem.
    @martin falz and @noorbeast , have you a link to find ZYT90-199 24v in China?
    153,691Coins
    Thanks for that @martin falz.
    Google translate -
    The price you need to ask . I have a price of 300 € for zyt90-155 - wog102122 including shipping and PayPal . I think it is a good price . A transmission gear left right
