News 3dof linear acurator with steper motor 12Nm
Discussion in 'DIY Motion Simulator Projects' started by misoswan, Apr 8, 2015.
  1. francky foor
    francky foor Member
    france (nord)
    347Coins
    2DOF, SCN6
  2. raidho36
    raidho36 Member
    829Coins
    I know it's highly off-topic, but I just don't want to create a whole thread to ask this:
    Just how powerful are car wiper motors? If I attach it with gear ratio 1:16 or so, how powerful would it be?
    I'm dissatisfied with my steering wheel FFB power and seeing how "soft" methods only yield minor improvements, I want to give it a radical motor upgrade, along with complete PCB upgrade (I'm pretty much replacing all internals, only keeping frame, shell and the wheel). Will it be just powerful enough to maybe simulate real forces? Or would I need two of those? Or more?
  3. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    My plan. is to do this like on picture:
  4. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    I do not have anything new we are waiting for deliveries....:blush
  5. raidho36
    raidho36 Member
    829Coins
    You think your belt is a little loose and needs tightening? Just for the sake of more accurate actuator position readings. Would be best if it was directly connected to it via gears.
  6. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    It is not mine. I will do alike.I thinks it's sufficient.
  7. raidho36
    raidho36 Member
    829Coins
    Just make sure there's means to adjust it.
  8. misoswan
    1,032Coins
    3DOF, Arduino, JRK
  9. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,948Coins
  10. speedy
    Alexandria , Egypt
    7,948Coins
    Have you bought this lever for both sides of each motor and the Axes ?
    your motor gearbox have hollow axe .
  11. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    So far I've bought Aluminium Flat Bar
    Width 50 mm
    Thickness 25mm
    Length 1000mm
    It's still not ready...
    It should look as follows .I do not have determined length.
  12. speedy
    Alexandria , Egypt
    7,948Coins
    Where did you get the idea of the limit switch ?
    thanks
  13. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    somewhere on the forums ....
    I feel like here something.... listed in forum within for @cthiggin but I'm sure.
  14. tronicgr
    tronicgr
  15. misoswan
    1,032Coins
    3DOF, Arduino, JRK
  16. speedy
    Alexandria , Egypt
    7,948Coins
    Hi :) @misoswan ... Feel free my friend to ask and know as much as you can for what is the best for your chosen platform ... and for information about the limit switch :
    They are used where there is any possibility for a mechanical damage if the control system fails .
    Look at this video and pause at the 00:05 & 00:08 for the upper and lower limit switches ...
    There are 2 black switches like the photo below placed up and down the motion range and connected to the VFD to stop the motion and prevent any mechanical damage ... which is not needed in your platform .
    • Optimistic Optimistic x 1
  17. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    hi @speedy
    hello thank you for the explanation, and now I understand from video.
  18. tronicgr
    tronicgr
    You can connect the limit switches to the stop function of the vfd drive but then it won't auto recover the motor position. The method I mention on the link above actually just blocks the motion beyond that particular direction towards that limit switch while allowing the vfd drive to remain activated to drive the motor back to other direction with no "error flags" to lock the vfd drive.
    • Old Old x 1
  19. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    my small upgrade
  20. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    upgrade
