Tutorial MotoMonster Dual Half Bridge - 60A Continuous and 120A Peak (12V)
Discussion in 'Motor actuators and drivers' started by Pit, Mar 2, 2015.
  1. Pit
    30,497Coins
    Correct!
    Arduino -------- Monster Moto1
    2 (Motor 1 H-Bridge ENA) ---------------7 and 8 (INA1 and INB1)
    3 (Motor 1 H-Bridge ENB)----------------4 and 9 (INA2 and INB2)
    9 (Motor 1 PWM) --------------------------5 and 6 (PWM1 and PWM2)
    Arduino -------- Monster Moto 2
    4 (Motor 2 H-Bridge ENA) ---------------7 and 8 (INA1 and INB1)
    5 (Motor 2 H-Bridge ENB)----------------4 and 9 (INA2 and INB2)
    10 (Motor 2 PWM) --------------------------5 and 6 (PWM1 and PWM2)
    Pot 1 of Motor 1 is A0, Pot 2 of Motor 2 is A1 (always middle output of the standard pots)
  2. Pit
    30,497Coins
    PS: remember my suggestion, I would begin with one MM first (standard Dual Channel), then as a half bridge (two channels combined). At least as a dual half bridge described in this thread :) Perhaps it sounds complicated to you but it isn't. IMO it is important that you are familiar with the steps for future use.
  3. Rocket man
    Rocket man Member
    Canada
    - 325Coins
  4. Rocket man
    Rocket man Member
    Canada
    - 325Coins
    Amazing!
  5. Nur
    Nur New Member
    36Coins
    2DOF, 3DOF, Arduino, JRK, 4DOF
    I 24V motors. Moto Monster voltage max: 16 v. What can you advise what to do?
  6. Pit
    30,497Coins
    Hi @Nur let me explain what I I have found so far from SparkFun ( I am NOT a electronic guru, other know it way better than me ;) ): the nominal working voltage of the VNH2SP30 is around 12 - 13.8 V (automotive use). The 41 V limit is an “absolute maximum rating” specification for VCC, that is the maximum sustainable supply voltage by the internal H-bridge. As you can see in the data sheet, the shutdown protection voltage is pretty much lower. Normally the driver is going in protection mode already by disabling the output when VCC raise over about 16 V.
  7. Nur
    Nur New Member
    36Coins
    Withstands 24V. Do I understand correctly?
  8. BlazinH
    16,671Coins
    No. Maximum voltage is 16v.
  9. Pit
    30,497Coins
    Here you go: http://users.elite.net/runner/jennifers/no.htm
    Along to the specs - as far as I can read and understand - not possible.
  10. Nur
    Nur New Member
    36Coins
    Are all bridges can be connected through your scheme? Or so it can only be connected MotoMonster? If no exception is the parameters for what to look for? Help to choose at least some sort of option. Thank you!
  11. Pit
    30,497Coins
    I do not understand. Even If I advise you, probably you will not understand (like the 16V limit which has been explained earlier this day.
    From where are you? If you are German speaking I can help you (despite of my offer I do not believe that many Germans are here :p )
  12. Nur
    Nur New Member
    36Coins
  13. Pit
    30,497Coins
  14. Nur
    Nur New Member
    36Coins
    I have the same engine, only 24V. I try to understand the other bridges can be connected to you, 1 double bridge on 1 engine.
  15. Martin van Hagen
    Martin van Hagen not trying brings you nothing! SimAxe Beta Tester Gold Contributor
    Instrument Engineer
    The Netherlands
    881Coins
  16. Pit
    30,497Coins
    yeah if you need any cheap samples Aliexpress is your friend.
  17. RacingMat
    21,059Coins
    @Martin van Hagen : just test it quickly when you receive it! I didn't and I accepted a faulty MM once... it's too late to open a dispute in Aliexpress
  18. Pit
    30,497Coins
    Same here, did not test it before building in, got two faulty samples and no refund...
  19. Martin van Hagen
    Instrument Engineer
    The Netherlands
    881Coins
    @Pit & @RacingMat Thanks for the advise! I read the T&C´s and it states to test and claim within 3 days after receiving the shipment. I am travelling a lot so that will be impossible to comply with. However the price of $12,00 a piece if I need 8 order 10 and find 2 failing it will still be cheaper than the Sparkfun MMs á $69,95 a MM. Just started to compile some parts to build 4 12Vdc 640W servo controllers containing 2 meanwell 320 12 PSUs (parallel with schottky diodes (40CTQ150)) connected to a "DC busbar", which will supply the MMs... t.b.c. on a new thread but like to have you guys on board for further advise and ideas? :thumbs
  20. tailele
    tailele Member
    italy
    349Coins
    My expecial thanks for the great job..thanks to you i could made my first dinamic seat...compliments
