SimTools 2DOF with TL SCN5 + SimVIBE
Discussion in 'DIY Motion Simulator Projects' started by clarkii, May 29, 2015.
  1. clarkii
    clarkii New Member
    Hong Kong
    792Coins
    3DOF, SCN5
    I am about to finish my conversion of Frex 2Dof to 2Dof + traction loss running Simtools & addition of bass transducers running SimVIBE. Appended are some photos for the WIP:
    SCN5 150mm actuator for TL
    Front pivot for TL
    Ball wheels for TL frame
    Seat base frame on TL frame
    Pedals & Steering Wheel
    Will upload more photos in coming days after installing seat & the bass transducers. Comments are welcomed. Thanks!
  2. Cluclu
    Cluclu Member
    443Coins
    Wow impressive structure
    153,944Coins
    +11,158 / 57 / -2
    Thanks for sharing the pictures, I will be looking forward to your updates.
    Have you got the actuators running with SimTools or is that planned after your motion simulator has been put back together?
  4. clarkii
    clarkii New Member
    Hong Kong
    792Coins
    3DOF, SCN5
    Hi, they are running with Simtools already. I took a video for the testing of the initialization in Simtools
    153,944Coins
    +11,158 / 57 / -2
    Brilliant job @clarkii, I am really looking forward to following your thread and seeing your sim complete :thumbs
  6. Cluclu
    Cluclu Member
    443Coins
    Very good, it is highly reactive and quiet
  7. clarkii
    clarkii New Member
    Hong Kong
    792Coins
    3DOF, SCN5
    Just installed the seat and the tactile transducers.
    One installed under seat
    Four more for vibrations from four corners
  8. GTHQ_koop
    GTHQ_koop Active Member
    Something with airplanes..
    Lakehills Texas USA
    1,786Coins
    2DOF, SCN5
    Wow, those are big :D
    Looking good though ;)
    153,944Coins
    +11,158 / 57 / -2
    Looking good :thumbs
    Can you give some details and links to the transducers and amp(s) you are using @clarkii?
  10. clarkii
    clarkii New Member
    Hong Kong
    792Coins
    3DOF, SCN5
    I am using two Clark Synthesis TST209 and two TST239, for the amplifier I use four Yung 100W class D plate amplifier.
    http://www.parts-express.com/clark-synthesis-tst209-tactile-transducer-bass-shaker--300-861
    http://www.parts-express.com/clark-synthesis-tst239-silver-tactile-transducer-bass-shaker--300-863
    http://www.parts-express.com/yung-s...ofer-plate-amplifier-module-no-boost--301-500
    For the shaker under seat I use Aurasound AST-2B-4. I also have shakers to be installed under the pedals and steering wheel.
  11. clarkii
    clarkii New Member
    Hong Kong
    792Coins
    3DOF, SCN5
    Shakers installed under pedal on steering wheel
    153,944Coins
    +11,158 / 57 / -2
    So you have Dayton Puck tranducers as well. Is that the grand total now, or do you plan on adding more?
  13. clarkii
    clarkii New Member
    Hong Kong
    792Coins
    3DOF, SCN5
    Hi! Yes, that's all. I run SimVIBE Chassis mode using the four Clark Synthesis transducers and run SimVIBE Extension mode using the others.
  14. RacingMat
    21,082Coins
    Good job indeed
    I like your pedals! :cool:
    Did you build them by yourself?
    Where is your brake sensor? Can we have more details ans pictures?
    I'm curious about the vibration motor: do you manage it with SimCommander?
    153,944Coins
    +11,158 / 57 / -2
    Some say pick one mode or the other, I gather you have got both to play nice together and if so do you have any tips?
  16. clarkii
    clarkii New Member
    Hong Kong
    792Coins
    3DOF, SCN5
    Hi, I bought the pedals from FREX a couple of years ago. It comes with a pressure sensor. From this sensor a threshold pressure can be set above which the brake rotor will turn on.
    Some photos are as follows
    I will upload some more photos/video after u hook up all the connections.
  17. RacingMat
    21,082Coins
    I see...
    Thanks for having taken some more pictures
  18. clarkii
    clarkii New Member
    Hong Kong
    792Coins
    3DOF, SCN5
    Hi, I have the four big transducers generating suspension and collision, road surface condition effects while the shakers under the pedals, steering wheel and seat for car engine effect and some others.
    The pedals and steering wheel are not bolting to the main cockpit frame directly but via some neoprene rubber for 'vibration' isolation.
    For the four big transducers I mount them to the four 'corners' of the seat rather than the to the four corners of the whole cockpit. For the latter which I tested before I found I could not distinguish where the vibration comes from because the seat is connected to the base frame via a single pivot which is this part:
    Also, seems the low frequency signals do not transmit through aluminum very well. For my current mounting scheme I can feel the directions of the forces.
  19. RacingMat
    21,082Coins
    That's informative!
    it seems logical once it has been said :D
