  1. SilentChill
    20,601Coins
    Hello everyone,
    Today I start my second motion sim after my first very successful 3DOF sim.
    I have made a little sketch, which took 3 weeks as I didn't know how to use sketchup but im getting there and at least I have something to show you all.
    I will be using my current motors off my rig which have not had any problems over the past 9 months. I think I will be trying a 13cm CTC lever (15cm overall) if that is too long I will shorten it down.
    Some of the parts I have already to get me going,
    Powered USB Hub
    12 x Ball Joints
    6 x Flexible Shaft Couplers
    6 x 360 Hall Effect Pots
    6 of these bad boys
    6 x 670w PSU's eeeeek
    5 x Arduino Uno clones which I have not had any issues with so far.
    I will be soon making my base which will be out of wood and the platform also will be out of wood, might sound crap and cheap but for weight reasons I'm gonna try and see what happens.
    I will be using my G27 Steering Wheel , Pedals and Shifter and also my Saitek x52 HOTAS. There will be no screens as I will be using my Oculus Rift DK2.
    Think I may just reuse the seat I have as it has the Transducers under it or I may splash out on a new lighter one, and connect the transducers straight to the platform.
    I am still trying to do this as cheap as possible but hopefully it wont look as ugly as my first rig :)
    Thats all for the moment and I will be back soon .
    • Like x 30
    • Winner x 1
    • Informative x 1
    • Useful x 1
    • Optimistic x 1
  2. Leo Burton
    Leo Burton Active Member
    London, UK
    2,639Coins
    Amazing. Love your 3 dof rig. Can't wait to see this thing running!
    Looking forward to seeing its progression. Good luck!
  3. Wanegain
    Wanegain Active Member
    Bruxelles
    2,018Coins
    Very nice project ! I will follow it !!
    Can you please give the link of where you buy your motors ?
    I really love your videos with sketchup moving with Simtools, is that hard and do you need a special version ? Very amazing...
    For me I think that with a 6 dof sway and surge are useless...
    2 questions :
    Why buying 360° pot or hall effect if you will mount them with no reduction ? You can buy directly 180°, it will be more precise.
    Why 6 power supply and 5 Ards ?? You can easily use one of this power supply for 3 motors at least, and instead of bying 5 Uno, 1 Mega would be enough (even a chinese copy)...
    153,764Coins
    +11,149 / 57 / -2
  5. tougemonster
    tougemonster Member
    Systems Integrator
    422Coins
    Are you going to be mounting the DK2 tracking camera to the platform?
  6. SilentChill
    20,601Coins
    @Wanegain the motors I am using will still trip those psu's out if I put the power up to full in scn with a single motor on each.
    Sway and surge are there and as good as any surge table that you may have seen.
    www.transtecno.com are the motors manufacturer
    The angle of the camera does not show how much it actually moves in that video.
    I am using Ards because that's what I know how to use the same with the POTS it's just what I used before so I will use them again. 3 Ards for the motors and 1 for my fans and then u have a few more to do what I want with .
    @noorbeast I using the latest 2015 version of sketchup I just had to suss out how to get it working with simtools which I can tell you was not that easy to start off with.
    153,764Coins
    +11,149 / 57 / -2
    Good to know 2015 works @SilentChill, I was not aware of that and have always used Version 8.
    What part did you find difficult to get Sketchup going with SimTools. Does the guide need updating in any way or do you have any tips and tricks to add while it is fresh in your mind?
  8. SilentChill
    20,601Coins
    @tougemonster yes the camera will be mounted above the fans somewhere.
    @noorbeast the socket.rb file which you create needs to go into the ruby folder inside the sketchup main install folder.
    You don't need to move the socket.so file either and just use the one that is already installed.
    • Like Like x 5
    • Informative Informative x 3
  9. momoclic
    momoclic Active Member
    Retraité
    Nantes - France
    2,773Coins
    DC motor, Arduino
    Wonderful project, bravo!
    Could you please tell me what tool Sketchup you realized the animation. Thank you.
    Magnifique projet, bravo !
    Pourriez-vous s'il vous plait m'indiquer avec quel outil de Sketchup vous avez réalisé l'animation. Merci.
    153,764Coins
    +11,149 / 57 / -2
  11. Paul Shortland
    Paul Shortland Active Member
    Northampton - UK
    317Coins
    2DOF, AC motor
    Serious build going on here :grin
    Looking forward to the updates!
  12. SeatTime
    Nice, those motors must be pulling some power (hopefully not too much) and the price was right:thumbs. Seems like you have everything ready to go. Look forward to seeing a working video in the near future.
  13. telfel
    telfel Active Member
    4,739Coins
    Hi @SilentChill
    would it be possible to let me have a copy of your sketch up drawing files and any files used for the motion,
    I just want to experiment with the layout, especially the top moving platform using 3 mounting points.
    regards Terry
  14. SilentChill
    20,601Coins
    It's started :D
    I have myself , well ermmmm a hexagon lol
    • Like Like x 9
  15. SilentChill
    20,601Coins
    @telfel to be honest you would be better off just doing it from scratch as it's not easy to just move things around . The amount of moving and reconnecting you would have to do it would take longer .
    The files you need are all in the tutorial and FAQ section
  16. SilentChill
    20,601Coins
  17. Leo Burton
    London, UK
    2,639Coins
    Loving it! Have you seen this guys rig? Similar in size and design with yours.
    I am 'well jel'! ;)
    I wonder if the motors I've used could be used for this sort of rig. Smolka 24vs?
  18. SilentChill
    20,601Coins
    @Leo Burton yes I have seen that video :) I have no idea if my motor s will work yet Im just hoping they will. Im afraid I cant give advise on your motors.
  19. Wanegain
    Bruxelles
    2,018Coins
    Hi @Leo Burton, @zigzag49 is building a 6 dof using same motors than yours. You can follow the thread here.
    These motors are not as powerful as those of @SilentChill is obvious but it can work well if it meets all the theory calculated by @momoclic (very good and interesting work).
    FYI, I am building a 4 dof with such engines. I will share all my work here when it will be done :thumbs
  20. SilentChill
    20,601Coins
    Oooo new parcel arrived :)
    Only weighs 6.7kg so should help a little.
    • Like Like x 5
