My 2DOF Kit Build
Discussion in 'DIY Motion Simulator Projects' started by Paul Shortland, May 15, 2015.
  1. Leo Burton
    Leo Burton Active Member
    London, UK
    2,639Coins
    Sounds like exactly the problem I was having, and it was simply swapping the pots in the arduino.(A1 A0) That fixed it for me. It sounds like the motors are hunting.
  2. Paul Shortland
    Paul Shortland Active Member
    Northampton - UK
    317Coins
    2DOF, AC motor
    Yeah I hoped that would be the issue but it is the same with A1 A0 as it is with A0 A1.
    Feel so close now too!
  3. Pit
    30,490Coins
    Try to switch the polarity of the pots OR of the motors. The pot has to work in the "opposite" direction meaning if I turn the pot left the motor turns right (no coupler connected).
  4. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Have been advised to amend my Ard code. Seems the Ard and Saber boards are trying to communicate at different speeds. Will be tomorrow before I can test this but I am feeling hopeful :thumbs
  5. Pit
    30,490Coins
    Of course that would be a completely different issue. I am sure you will sorting it out :)
  6. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    It lives! :thumbs:thumbs:thumbs
    I changed the Ard code as it was connecting to the sabertooth at 9600 whereas the sabertooth was connecting at 115200. Also a dip switch on the sabertooth was wrong.
    Only tested with the game engine output test so far, hope to get iRacing running tomorrow :grin
  7. Leo Burton
    London, UK
    2,639Coins
    Congrats!!! Its such a good feeling when it kicks into life!
    Now comes the long process of tuning it to your liking!
  8. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    iRacing works too :grin:grin:grin
    Setting the settings is 'interesting'!
    How do these look?
    152,027Coins
    +11,062 / 56 / -2
  10. Wanegain
    Wanegain Active Member
    Bruxelles
    2,003Coins
    Just to be sure I understood what you mean @noorbeast : you recommend to lower the Max/min value in order to lower % from each DOF to get 100-120% for all the DOF for one axis ? Very interesting !
    By doing that you will reduce the data range and big movements will be shaped ?
    When I start a new profile, I try each force one by one and I try to find the perfect value and then I lower from 10-20% to mix all effects. I am more than 100% for sure !
    This evening, I'll try your method and see if I can feel a difference.
    152,027Coins
    +11,062 / 56 / -2
    It is a bit of a balancing act. As @eaorobbie explains "motion cue is lost because it pasts 100% of the Axis Total Movements".
    There are both design element that can affect allocations, for example a compact sim has more possible pitch percentage than roll, plus there can be a degree of cancellation between forces allocated to one axis.
    It would seem to be that problems start to really kick in if the total is 130+%, but best to get as close to 100% total axis allocation as possible.
    You can fine tune the effect in the Tuning Center. For some forces, such as heave, it is not unusual to have a setting less then 1 and in some of mine heave is 0.2- 0.5. I think the smallest possible Tuning Center setting is 0.001.
  12. Wanegain
    Bruxelles
    2,003Coins
    Thank you for this explanation.
    So the % near to each DOF is a % of the axis and not the power of the effect o_O:confused: ?
    The things is that I was thinking the value in tuning center was representing G-force and all my profiles are based around +/- 5-6 for sway, heave and surge :think
    I have to review all my profiles :mad:. I spent so many hours to find the best settings :(...
    Anyway it's good to know, thanks again ! :cheers
  13. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Mine is improving, nearly threw me off the chair!
    However my pitch and roll are the wrong way round.
    When I accelerate the chair leans right, braking leans to the left.
    Also turning right pitches it forward and turning left pitches it back.
    Is there an obvious thing I did wrong? ( I only have Roll, Pitch and Surge set at the moment)
  14. Wanegain
    Bruxelles
    2,003Coins
    If it leans right when you accelerate, it means your left motor is going up instead of down. Just clic on Dir next the surge DOF for your left motor (Axis1 I guess ?).
    If it pitches forward when turning right it means your left motor is going up instead of down. Clic on Dir next the sway DOF for your left motor.
    Edit : don't forget to Save settings...
    :thumbs
    152,027Coins
    +11,062 / 56 / -2
  16. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
  17. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    I was using roll and pitch but pointing me the right way :thumbs
  18. noorbeast
    152,027Coins
    +11,062 / 56 / -2
  19. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    :cheers all working now, quite violent at times! Now waiting for my custom made wheel and pedal attachment to arrive. Might be here today or tomorrow.
    152,027Coins
    +11,062 / 56 / -2
    Great, please do shoot and post a video when you can :thumbs
