German 2dof arduino uno moto Monster
Discussion in 'DIY Motion Simulator Projects' started by martin falz, Jun 7, 2015.
  1. martin falz
    martin falz Member
    Deutschland
    228Coins
    Hello community . I 've started a simulation project with 2DOF .
    I have finished the frame . Now I have Arduino UNO and MotoMonster bought and wired shild . So far so good. But now the problems begin .
    Have taken from me the racingmat instructions .
    Have the max and min set potentiometers . Then the motors rotate at the start ever in one direction .
    The motors I ground away .
    I then sironame of the Arduino data recorded https://github.com/X-Sim/X-PID-Arduino-PID-motor-control
    Thus the engine can not be cranked at startup. But get sent to the motors with XSIM no data .
    I despair .
  2. martin falz
    martin falz Member
    Deutschland
    228Coins
    This are the images
  3. martin falz
    martin falz Member
    Deutschland
    228Coins
    Sry that I wrote XSIM. Now I have downloaded the software from this
    Site. But I need tipps to install the components poti etc.
  4. tombo
    tombo Active Member
    2,443Coins
    DC motor, Arduino
  5. Pit
    30,490Coins
    Hi Martin, welcome here and have a nice stay ;)
    What did you do so far? I cannot advise you if I know rather nothing about your gadgets. We need:
    • HQ photos from the Ard and MM
    • You could take a video to show us what you are doing and what exactly happens
    (muss ich sicher nicht übersetzen...)
    • Friendly Friendly x 2
  6. martin falz
    martin falz Member
    Deutschland
    228Coins
    thanks for answer. ihave only a bad camera .
    i have make what tombo said. thanks.
    the motors and potis run.
    but the plugin is what i need that the game give the signals to moto monster.
    or iss this wrong thinking?
    i have new pictures from the setup smc3.
    thanks at all
    and sry for my bad english
  7. martin falz
    martin falz Member
    Deutschland
    228Coins
    the signal from arduino to shild is okay.
  8. martin falz
    martin falz Member
    Deutschland
    228Coins
    Hallo habe da noch eine frage sonst kann ich nicht schlafen. Beim smc3 wie stelle ich da den max bzw min Werte ein? Das der Motor nicht mehr als 180grad dreht.
    Habe die Befürchtungen das es mit dem plugin wieder weiter dreht.
    Hi have another question or I can not sleep . When SMC 3 How do I set as the max min values or a ? The engine does not turn over 180Grad .
    Have the fears that turns it on again with the plugin
  9. martin falz
    martin falz Member
    Deutschland
    228Coins
    Hi
    Can I test the Simtools with not plugin?
    That I can see what the motors make.
    Hallo kann ich in Simtools ohne plugin die Motoren arbeiten lassen?
    Dann kann ich wenigstens schon einmal sehen wie sich die Motoren verhalten.
    152,027Coins
    +11,062 / 56 / -2
  11. martin falz
    martin falz Member
    Deutschland
    228Coins
    Thanks. I reed it after work.
  12. martin falz
    martin falz Member
    Deutschland
    228Coins
    so habe das alles hinbekommen. nun habe ich auch das Plugin von projekt Autos.
    alles nach anleitung eingefügt und gepatcht. aberrrrr
    Wenn ich nun Ausgangsprüfung im simtools gehe, keine Funktion.
    im Spiel das selbe!
    habe ich noch irgendwas vergessen?
    habe available mit Raceroom Versucht. Genau das selbe.
    eigentlich müsste es doch ohne Plugin Auch beim Ausgangstest gehen oder nicht?
    so all have hinbekommen . now I have the plugin of project cars .
    All inserted after instruction and patched . aberrrrr
    Now, when I go in the output testing simtools , no function .
    the same in the game !
    I forgot something ?
    I also tried it with RaceRoom . exactly the same .
    Actually, it should go without plugin even when output test or not ?
    I glaucbe I'm doing tomorrow it the PC times flat and everything is new .
  13. value1
    15,028Coins
    Did you define some axes in the interface settings:
  14. Pit
    30,490Coins
    no support without screen shots of all your settings, including SMC3, Simtools, Game Manager, Game PlugIn etc. :)
  15. Pit
    30,490Coins
  16. martin falz
    martin falz Member
    Deutschland
    228Coins
    so da haben wir die Bilder.
    ich denke das ich das setup richtig eingerichtet habe.
    hoffentlich:)
  17. Pit
    30,490Coins
    I found the fault...
  18. Pit
    30,490Coins
    Du verwendest Leerzeichen, da dürfen aber keine stehen.
    you are using blank spaces, but they must not to be used here...
  19. Pit
    30,490Coins
  20. martin falz
    martin falz Member
    Deutschland
    228Coins
    Super geil.
    Werde es morgen testen.
    Du bist en tier:thumbs
