2DOF Arduino Monstermoto build
Discussion in 'DIY Motion Simulator Projects' started by Mitchell, Jun 2, 2015.
  1. Mitchell
    Mitchell Member
    Netherlands
    87Coins
    Hello Guys, My name is Mitchell and i am from the Netherlands.
    I am a production engineer at a company which sells meteo equipment and vision stuff, so i finally got my hands on 2 used wiper motors that where laying around over here. these are 24V 30 NM.. i tested them on 12 V and felt quite strong..
    After a lot of reading on this forum i started to make a prototype.
    I got everything working now with an Arduino Nano clone and a simple L298N motor driver i had laying around.
    The monster moto is on his way from china haha, so for now i can test without load because this motor controller can only handle 4A.
    Check the pictures!
  2. Mitchell
    Mitchell Member
    Netherlands
    87Coins
    Also check out the video :
    153,836Coins
    +11,151 / 57 / -2
    Thanks for the description and photos @Mitchell.
    The setup does not have a pivot so I am interested in what load it is expected to carry. I would also like to understand how the the lever plates attach to the top board and motor shaft, I just can't tell from the angle in the photos.
  4. Mitchell
    Mitchell Member
    Netherlands
    87Coins
    That is correct haha.
    The prototype board and the seat are 2 different things, i still have to get a pivot from somewhere.
    Suggestions ?
    Here you can see the brackets for motor/board connection.
    153,836Coins
    +11,151 / 57 / -2
    That clarifies it then, a prototype is a useful thing to do and you gain experience with SimTools. And thanks for adding the video.
    A universal joint is much better than a CV joint for the pivot and you should plan to have it attach as close under the seat as possible. I like many others have used a uni joint from a car tailshaft, some have used the uni joint from a car steering column. Others have made a pivot joint from heim rod ends.
    I look forward to following your project as it develops.
  6. Mitchell
    Mitchell Member
    Netherlands
    87Coins
    Nice! Just came from the car scrap yard!
    I'm happy.
  7. Mitchell
    Mitchell Member
    Netherlands
    87Coins
    I will pickup the 2 plates tomorrow so i can start welding :)
  8. GTHQ_koop
    GTHQ_koop Active Member
    Something with airplanes..
    Lakehills Texas USA
    1,786Coins
    2DOF, SCN5
    And a Big mac on the way home :D
  9. Mitchell
    Mitchell Member
    Netherlands
    87Coins
    Hahaha i was lucky i left that in the car from the day before.
    Funny to see so many dutch people over here by the way.. Where do you live ? i'm from Rotterdam
  10. GTHQ_koop
    Lakehills Texas USA
    1,786Coins
    2DOF, SCN5
    Hoofddorp :)
    Have fun building ;)
  11. bruce stephen
    general contractor
    michigan
    9,115Coins
    very cool cant wait to get mine started
  12. Mitchell
    Mitchell Member
    Netherlands
    87Coins
    Ok, good new.. bad news.
    I put everything together except the monstermoto's, still on their way :(
    Welding went OK, did not do that for 5 years haha but looks solid.
    I tested the motors without a motor controller, just connected it to a 12V car battery and this was the moment i got sad..
    The motors are not strong enough, these are 24V motor which now are getting 12V..
    Please see : http://www.b-hepworth.com/assets/images/Manuals/30Nm.pdf
    So... problem.. i don't want to spend 200+ euro's on new motors, so i ordered 2 of these drivers : https://www.olimex.com/Products/RobotParts/MotorDrivers/BB-VNH3SP30/open-source-hardware
    These should be able to run on a higher voltage then the monstermoto's, just have to keep an eye on the current.
    I think i will fuse them with 20A
    So, the controllers from olimex should be coming in this week.. can't wait to test
    If this isn't enough it's becoming a seat mover probably haha
  13. noorbeast
    153,836Coins
    +11,151 / 57 / -2
    Just a thought, you could change the base board position and do a foot mount of the motors like @Archie's rig, that way you would have much more leverage for your full frame sim and a lot less strain on the motors compared to the current design.
  14. Mitchell
    Mitchell Member
    Netherlands
    87Coins
    Yeah.. good one..
    Will do some tests when i got my motor controllers ;)
  15. Mitchell
    Mitchell Member
    Netherlands
    87Coins
    Nice, just got my controllers.
    Going to do some tests tonight.
    Also made a flexible coupling for my pot's
    I noticed the motors move a a little while operating so a flexible coupling should increase pot life.
    • Creative Creative x 3
  16. noorbeast
    153,836Coins
    +11,151 / 57 / -2
    Having a flexible pot coupling will certainly aid pot life.
    I am looking forward to your tests to reduce the strain on the motors.
  17. Mitchell
    Mitchell Member
    Netherlands
    87Coins
    Yes, i will test tonight!
    Just mounted the controllers :)
    ( another productive day at work hahaha )
    Gotta keep em cool :p
    They are small btw!! 30A .. Really
  18. Mitchell
    Mitchell Member
    Netherlands
    87Coins
    OK, after 1 hour of thinkering i finally got my motor controllers working, i had to feed 5V to pin 2 of the controller otherwise it doesn't work. Found it in the datasheet.
    Then i finally tested the full platform, i tested on 16V and 12V and found that 12V is more realistic. When i use the system at 16V the movement are alot more jerky. 12V feels nice but isn't very quick.
    The controllers don't even get hot! i really recommend you guys these MC's!
    Anyway, i already noticed i have alot of configuration/tuning to do.
    Any suggestions to get smooth movements ?
    @ Noorbeast, placing the motors at the foot end really helped alot!
    Will post a video tonight.
  19. Mitchell
    Mitchell Member
    Netherlands
    87Coins
    After some tuning i like dirt3 best with my sim.
    I think its because there is alot of movement..
    I also play grid2 alot but in this game the movements are a little bit to jerkey i think to feel natural.. Somebody any suggestions ?
    I also tested the rollercoaster sim game, alot of fun! Feels good.
    153,836Coins
    +11,151 / 57 / -2
    You would have to post all your settings so members can advise on trying to smooth it out.
    I suspect part of the issue is design, low linear speed plus trying to move a lot of mass, which includes the screen in a full frame design.
