Game Engine Fails
Discussion in 'SimTools DIY Version' started by jsmith2307, Jun 1, 2015.
  1. jsmith2307
    jsmith2307 Member
    Respiratory Therapist
    Corpus Christi, Texas
    324Coins
    2DOF, DC motor, Arduino, Joyrider, Motion platform
    Greetings,
    I’m having a problem with Flight Sim 2004 and I am running Win7 64. The game engine keeps shutting down. I’ve re-installed Win7, and all of the necessary Flight Sim 2004 equip. joysticks, rudders . I even tried reinstalling sim tools 1.2 and 1.3 several times. Still the same.
    On the other hand I’ve got a lap top running the exact same set up and a fly hours at a time with no notification!
    jsmith2307
    152,700Coins
    +11,091 / 56 / -2
    I am guessing something is going out of range, what are you settings and simulator hardware?
  3. jsmith2307
    jsmith2307 Member
    324Coins
    Greetings Noorbeast,
    Thank you for responding. The computer is a homemade one utilizing a ASUS M5A99FX PRO R2.0 mother board and a Nvidia Geforce GTX 600 graphics card. CPU is a AMD FX-4130 quad core processor with 2 of the 4 processors shut down. Installed memory DDR3 16.0 GB. System type: Win7, 64-bit operating system. It was built two years ago, and is “bare bones” except for a DVD burner and USB ports. I am running no anti-virus at this time!
    jsmith2307
    152,700Coins
    +11,091 / 56 / -2
  5. jsmith2307
    jsmith2307 Member
    324Coins
    Forgive the miscommunication. I'm using serial communication. The photos should tell the story! I'm using Dimension Engineering devices: Syren 50 + Kangaroo 2 + DeLink per axis. Also have FSUIPC placed in my modules.
    jsmith2307
    152,700Coins
    +11,091 / 56 / -2
    Is your rig a traditional 2DOF or something else?
    Are you following the manual: http://www.xsimulator.net/simtools-complete-documentation/
    I ask because you would normally have the same axis, say pitch, on DOF2 for both axis in the Axis Assignment tab, with the forces running to extra columns, like this:
    but yours are set like this:
  7. jsmith2307
    jsmith2307 Member
    324Coins
    My simulator is based on the joyrider concept! A basic 2 dof, one axis for pitch the other for roll.
    Just to clarify, the game engine is shutting down! Not the game manager or Flight Sim 2004.
    jsmith2307
  8. jsmith2307
    jsmith2307 Member
    324Coins
    Greetings,
    I believe my registry is corrupted due to the fact I've done multiple installs of simtools 1.2.and 1.3, all of them end with the same ending. Does SimTools have a registry cleaner like the competitor Xsim ?
    jsmith2307
  9. yobuddy
    51,255Coins
    SimTools does not use the registry at all...
  10. jsmith2307
    jsmith2307 Member
    324Coins
    Greetings,
    I believe the situation is resolved.........I think. In Game Engine, I had the Axis Assignments at 100% . Roll and pitch, surge, and sway all at 100% I turned roll and pitch to 20% and 10% and it works.
    jsmith2307
