Showroom My 2 dof simulation system
Discussion in 'DIY Motion Simulator Projects' started by tailele, Jun 11, 2015.
  1. tailele
    tailele Member
    italy
    349Coins
    Hi, i would show with everyone, my simulation system with 2 degrees of freedom. I use two motor with 1800rpm and 1,3 Nm with 12v; then i buy two gearbox 40:1.
    I regard the person who wrote the tutorial for assembly two motormonsters for 60A continuos and 120A peack, because that tutorial is very important for me for the construction.
    As suggest from the forum i bought an arduino one r3, and 10 m of bosh profiles.
    For the system druve i bought a trustmaser t500rs; and finnaly a sparco carbon seat to reduce the heavy. This forum was very very interesting for the moviment particulars' and a grat thanks for the user that wrote the SMC3 tutorial.
    For the moviments i use one motor for the roll and one motor for the pitch. Now i pubblic the photo with some construction step.
    153,830Coins
    +11,151 / 57 / -2
    Thanks for posting the photos @tailele :thumbs
    They are interesting looking gearboxes, where did you find them and what was their cost?
  3. tailele
    tailele Member
    italy
    349Coins
    i hope that this discussion could gives some points or ideas to construct a dynamic system. Then i hope that some kindless persons could give me some traces to resolve a little software problem that actualli i have.
    I explain the problem:
    When i launch smc3utils all go fine, i move without problem the two motors ( even if i have to calibrate very well the motors'force and other parameters).
    But when i launch simtools and i try to moove the motors, it fail. I have read all the discussion; infact i have set the arduino port for example the com port, the velocity, the comunication bits and everyone that i can found. The same step for the simtools where i have done the suggest in smc3 discussion....are there other parameters? thanks a lot
  4. tailele
    tailele Member
    italy
    349Coins
    hi noorbeast, the gearboxs are made in Italy from Bonfiglioli, the price is near to 40 euros from one piece
    153,830Coins
    +11,151 / 57 / -2
    Can you please post screen shots of all your settings, that helps enormously with trouble shooting.
  6. tailele
    tailele Member
    italy
    349Coins
    Thanks for the response, actually i don't take any screen, but this afternoon i 'll upload the screen. Thanks another time
  7. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    if i understood right sim works fine with SMC3 Utils , you have configured interface settings in game engine
    and when you try to move it with simtools you don't have any movements.
    are you using output testing or a game?
    if you are using output testing you have to create a profile(the default) save it and then use output testing mode.
    as @noorbeast said post some screen shots of settings @Pit has a eagle eye and will find it in no time
  8. tailele
    tailele Member
    italy
    349Coins
    Hi, as i promise, now i can upload the image:
  9. tailele
    tailele Member
    italy
    349Coins
    i think that that all sets are correct...maybe i have lost some passage...could you see anything wrong?thanks a lot
    • Dumb Dumb x 1
  10. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    @tailele BitsPerSec are wrong
  11. Pit
    30,510Coins
    And output bits range, too
  12. Pit
    30,510Coins
    errare humanum est...
  13. tailele
    tailele Member
    italy
    349Coins
    Ok... So i must set bit per sec to 500000 .. But my com 4 doesn 't have this speed. And output bit range to 10... This i think is correct..
  14. tailele
    tailele Member
    italy
    349Coins
    Ahahahaha... Tomorrow i ll try...
  15. Pit
    30,510Coins
    YES!
  16. tailele
    tailele Member
    italy
    349Coins
    Today i try with this configuration...but the risult is the same...no moviments...any ideas???thanks boys
      758.8 KB
      741
  17. Pit
    30,510Coins
    I assume (only) SMC3 works fine?
  18. Pit
    30,510Coins
    PS: you cannot use SMC3 and SimTools at the same time
  19. tailele
    tailele Member
    italy
    349Coins
    Another error.....damn now for test i'll wait this afternoon....ahahahaha
  20. Pit
    30,510Coins
    As long we are humans errors are part of our life ;) I am sure you are close to bring your rig to life.
