No movement in games
Discussion in 'SimTools DIY Version' started by jamiebird76, Jun 12, 2015.
  1. jamiebird76
    jamiebird76 New Member
    36Coins
    2DOF, SCN5
    So ive recently converted my Fex SCM to simtools and on the surface everything is running fine.
    Ive got the actuators moving after changing the ID of the right SCN but i cant get any motion working in any of the simulators when the games are running.
    The output testing DOF does not work at all but Axis output give left and right motion but no fowards and backwards.
  2. yobuddy
    51,666Coins
    Check the Axis Assignments for each game in GameEngine.
    If you fill out the default profile in Axis Assignments, all newly installed game plugins will have these settings as the default.
    If you installed the plugins before setting up a default axis assignment, then the new games have no axis assignments at all. And therefore you have no motion.
    What type of simulator do you have?
    154,460Coins
    +11,182 / 57 / -2
    For troubleshooting purposes it helps if you post screenshots of all of your settings.
  4. GIB SimRacing
    GIB SimRacing Active Member
    Barossa Valley, SA
    983Coins
    As noorbeast said, screenshots of your settings would help. Have you patched the game for motion within SimTools?
  5. jamiebird76
    36Coins
    2DOF, SCN5
    Ive attached my settings. I have a frex simconmotion converted using the guide on this site. Movement is working in game engine but there is no movement in game.
    154,460Coins
    +11,182 / 57 / -2
    You really need to supply more information about what you have and have not done.
    Have you followed the manual: http://www.xsimulator.net/simtools-complete-documentation/
    When you say "Movement is working in game engine" can we assume you have tested it in the Output Settings, if so have you verified the axis directions are correct?
    Have you patched the game for motion and what game is it?
    Is the status showing as connected for the game?
    Have you established base settings in the Tuning Center? http://www.xsimulator.net/community/faq/set-base-tuning-motion-values-in-the-tuning-center.122/
  7. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
  8. jamiebird76
    36Coins
    2DOF, SCN5
    Correct
    Yes. Project cars
    No idea how to check this.
    No. let me read the thread and try.
    154,460Coins
    +11,182 / 57 / -2
  10. GIB SimRacing
    Barossa Valley, SA
    983Coins
    Can we also assume that you are using only 1 PC? Not trying to go over a network between game engine and manager? If you are using 2 PC's make sure they both have a static IP address and that the correct IP is entered into the game manager.
  11. jamiebird76
    36Coins
    2DOF, SCN5
    OK i followed the guide and i now have some movement. I can hear the actuator moving but the movement is so slight its not really noticeable.
    The simulator is running on one pc only.
  12. GIB SimRacing
    Barossa Valley, SA
    983Coins
    Nice, one step closer. :thumbs
    You have to play around with the tuning centre now to set up the forces better. Try smaller numbers for your forces in the tuning centre and see how that goes. Not sure if there is a better way but that's what I did. I had the same thing when I first got motion working. The movement was very little until I started changing the numbers in the tuning centre. Or better yet, start pCars and click "capture min/max" within the tuning centre.
    http://www.xsimulator.net/tuning-centre/
  13. noorbeast
    154,460Coins
    +11,182 / 57 / -2
  14. jamiebird76
    36Coins
    2DOF, SCN5
    sorry for the delay in replying been busy with work. The tuning centre has helped but the side to side motion is lacking. When using the Frex software the feeling of changing direction was large and quite similar to the feeling in a real car, as was the feeling of chicanes. The simtools motion is lacking so id like to try and replicate the sideways G again. Ive ran the tuning centre in a bunch of cars from a mx5 to f1 car.
    On the good side the simtools is doing a great job replicating going up and down hills. Frex could never do that.
  15. GTHQ_koop
    GTHQ_koop Active Member
    Something with airplanes..
    Lakehills Texas USA
    1,786Coins
    2DOF, SCN5
    Sound a bit like my 1st "issues"..
    I changed the axis to sway and surge, then check the output testing. (bottom 2 options)
    Also check if it's on 10ms.
    Don't really know if I'm helping but those are just my 2 cents :)
  16. noorbeast
    154,460Coins
    +11,182 / 57 / -2
    Can you please post your full Axis and Tuning Center settings.
    From the limited info so far you seem not to have sway configured. Go back to your axis settings and turn everything off except surge, set that to 20% and test, adjust if needed until it feels right. Then turn it off and do sway by itself the same way, then heave. Try around 10% for heave in the axis settings and 0.5 in the Tuning Center. Then do roll and pitch last, keeping in mind that things like surge and pitch can somewhat cancel each other out when all axis are mixed. Refine in the Tuning Center when all axis are enabled.
  17. GIB SimRacing
    Barossa Valley, SA
    983Coins
    I agree with noorbeast. For starters, set up sway just by itself and get the side-to-side movement the way you want it.
    When I first started setting my sim up, I used roll instead of sway thinking that was the force for your side-to-side movement until I got pointed into the right direction.
  18. jamiebird76
    36Coins
    2DOF, SCN5
    here are the settings. I have two SCN5 actuators. Im not sure the difference between the axis and the DOF and how they limit movement. When you refer to axis set to surge and sway should that be done on the same axis or on each DOF?
    154,460Coins
    +11,182 / 57 / -2
    Set them like you have, make DOF4 sway and DOF5 heave. Then followed the instructions I already gave, set the percentage at 20% for surge test and adjust in The Tuning Center with the others off, then sway and so on.
    You can go slightly over but you want to be as close to 100% when you total the % allocations together. Some people do not use roll and pitch, which does allow a greater % allocation for surge, sway and heave, but it is personal preference, I use them all.
  20. FattySteve
    FattySteve New Member Gold Contributor
    YinChuan
    226Coins
    2DOF, 3DOF
    sorry for using this page asking my questions.
    i have similar questions about Sim tools.
    Set the Sim tools as the Guide and not Set up the interface part because i just don't make the arduino part (so there's still none com port)
    my question is,In this situation can I check the data such as roll or pitch catch from the FSX in the "virtual testing" in the output testing or see in the "tuning center“?
    for now,they data don't move as the plane move in FSX. Should i change some my set up? Or must build an arduino first.?
    I think its better check the data from game first. then check the output which will be the input of arduino and then check output from arduino which is input of motors.
    i think this progress may help me do less error in building one.
    Here's my setup picture.
    BTW open SIMengine and manager with admin
    Simtool have way to monitor the angle of plane in roll pitch and yaw?
