  1. SilentChill
    20,598Coins
    Yeah @momoclic you are clever with all your numbers and stuff what's he talking about ?? Lol
  2. momoclic
    momoclic Active Member
    Retraité
    Nantes - France
    2,767Coins
    DC motor, Arduino
    I think the focal point of the rods faiseau is under the platform ???
    This should be above ???
    This is my interpretation, but I do not understand.
  3. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    @SilentChill not sure too but i remembered watching something similar in the past. look at his video here and in the 6 dof graph you will see a yellow ball 4:05 in video probably that's the COG @tronicgr is talking about.and if i am right your build has this yellow ball lower near the upper frame and must be higher.
    BTW great job waiting to see your build in action with you on it
  4. SeatTime
    What he is talking about is the center of rotation of the rig. Not so easy to get right without using the proper 6DOF math. But keep at it.
  5. momoclic
    Retraité
    Nantes - France
    2,767Coins
    DC motor, Arduino
    Right, on the video it seems that the center of gravity converges with the tray rotation center.
    This has the effect of limiting the dynamic forces.
    Well done!
  6. Pit
    30,502Coins
    now we are coming back to the maths, very interesting view about the COG. Did not know that before.
  7. momoclic
    Retraité
    Nantes - France
    2,767Coins
    DC motor, Arduino
    I rather think, physical or kinematics ;-)
  8. SilentChill
    20,598Coins
    so i need to chop my arms in half that should lower it enough nearly :)
  9. momoclic
    Retraité
    Nantes - France
    2,767Coins
    DC motor, Arduino
    Under reseve have understood that Tronicgr said:
    Extending your rods converging towards the ground.
    They should converge towards the sky.
  10. SeatTime
    • Optimistic Optimistic x 1
    153,045Coins
    +11,116 / 56 / -2
  12. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    • Informative Informative x 3
  13. momoclic
    Retraité
    Nantes - France
    2,767Coins
    DC motor, Arduino
    Bizarre "center of gravity" I would speak more gladly of "center of rotation"?
    We can not shift the center of gravity of the mass ...
  14. telfel
    telfel Active Member
    4,739Coins
  15. SilentChill
    20,598Coins
    I have not got a clue what all this means but im just gonna crack on and see what happens, COG where ever it is aint gonna stop me so I aint worrying about it. He mentioned about some 47000uf caps aswell that I would need but guess what ?? I dont need any...............
    He always playing down anything that doesn't use his beloved Thanos board.
    Ok back on track now got some more fans installed over the MM's and all heatsinks in place although I am 2 MM's short only had a spare 3 so awaiting replacements.
  16. BlazinH
    16,677Coins
    Ideally the COG and the COR are the same or close to it in order to minimize the off feelings from rotational accelerations. We are talking about the COG of the person on the rig here though and not necessarily the COG of the rig and rider. My feeling is that somewhere between a person’s waist and their belly button is the ideal COG and high enough up.
    I agree with your sentiments on Thanos last comment. One could look at it as being informative until you consider the fact that he rarely posts anything and then this one deals with 6dof math. It was really just an opportunity for him to take another cheep shot at others successes!
    Btw, you probably won’t know if you need to add any large capacitors until you have a fully working loaded platform so you can see if you have enough available current to handle the peak draws. If not using large capacitors in parallel with you psu's may be enough to help supply the necessary current thru the peaks.
  17. SilentChill
    20,598Coins
    Thanks @BlazinH something I understand :)
    Its all early days for me with this rig so improvements are on going but early tests tonight give me good confidence that its going to work ok. Movement wont be anywhere near the big AC motors but for what I want hopefully it will be enough.
  18. tronicgr
    tronicgr
    Sorry guys that you see it like that. I was only trying to give some advice and good luck. I'm really interested to see if this will work, as everyone else here does.
    And excuse me if you think that "my design" motion controller is more commercial than the arduino, or less DIY.
  19. madgino
    madgino New Member
    1,122Coins
    @tronicgr Maybe you could give some suggestions, I suspect there will be quite a few people who will try and design something similar.
    What can be done to help with this "COG" that you talk of.
    Can you please explain in simple terms for us newbies here.
    Thank you
  20. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,945Coins
    It is a mechanical adjustment I guess ...
    As any stewart platform only uses a " 90 degree rotation" for each crank arm ...
    So you have to set the center of this " rotation range" as your COR is needed ...
    1- Horizontal crank arm rotation center gives an exact top platform COR .
    2- Pointing down crank arm rotation center gives a lower COR than the top platform .
    3- Pointing upward crank arm rotation center gives a higher COR than the top platform .
    @SilentChill ... Try that with your Sketchup design and SimTools ...
    • Informative Informative x 5
